Question about Zanussi ZHF470 Electric Double Oven
Zanussi convection oven will not heat up model no fm9231 oven might be 11 or 12 years old
4 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: main oven not heating.
You need to replace a faulty main oven element.
This is done by removing the rear cover in the main oven,
there you will see the element, disconnect and replace.
It is not a difficult job , and is not too expensive.
Plz frate my solution.
THANKS.
Posted on Jan 06, 2009
barkencoa
  • 3463 Answers
SOURCE: Faulty main oven
If the fan is working in the oven, and it is electrically heated, then it will be a faulty oven element.
This is located at the rear of the oven behind a removeable cover.
Posted on Feb 10, 2010
SOURCE: I have a zanussi built
If the red light is coming on when you turn on the oven control then the thermostat is ok.You will need to remove the grids from inside the oven then remove the inside rear panel 4 screws, be carreful not to damage the thermostat as you remove the panel.When you have removed panel you will see the ring element,now remove the 3 screws holding in the element and gently pull it towards you,remove the 2 cables off element but do not let them fall into the back of cooker or you will have to remove the cooker and gain access to the rear of the cooker.Once you have element check with a multi-meter for continuity and replace if blown. Relacement is a reverse of removal.
Hope this helps.
Posted on Aug 04, 2010
Why does the fan mode on the bottom oven on my zanussi Zou575 not working?
Because in Main Oven Cavity (large) around the convection fan is very powerful ring heating element 2500W (not visible) who works in the Fan mode. Therefore, it is not necessary that all heaters work because it will overheat the oven.
Dado
Aug 25, 2014 | Zanussi Ovens
I self-cleaned the convection oven on my sc302tw, and now it does not heat on any settings, convection, bake or broil. It is 14 years old.
Looks like the sensor has tripped... on my Bosch oven, I opened the back. Connected to the thermostat is a switch with a little button which pops out to prevent the oven from overheating... push in the button to reset it and it should work
Nov 06, 2013 | Thermador Ovens
Dacro Wall oven (electric) does not heat past 345 degrees on bake or convection bake but broiler works and bottom oven works fine (for bake, convection bake and broil).
it could be the oven temp sensor rod located near the top of the inside of the oven,or possibly the bake element has a hot spot on the element and can no longer pass enough current thru this spot to correctly heat to your settings a hot spot on the element will look discolored in this area
Jul 28, 2012 | Dacor Ovens
Dacor 1.5 years old convection oven...not heating
Flip both oven breakers HARD to the "off" position, then back on. If it did not help - you might have a problem with a relay on the control board or a failed bake element.
Grab a flashlight and check the element on the bottom (if you can see it). DO NOT TOUCH THE ELEMENT! If you find any bulging or cracking on the element - it'd out. Before removing the element turn the oven off on the breaker panel.
PS Model number is needed to find the part numbers.
Oct 22, 2009 | Ovens
Bosch HBN 642 -- single oven cycles and doesn't get above 325
WHAT WAS HAPPENING AT 1ST YOUR HI-LIMIT TERMAL SAFETY OR OVEN TEMP SENSOR FELT THAT THE OVEN WAS GET TOO HOT AND SEIZING OPERATION UNTIL SAFE TEMP WERE OBTAINED THIS IS GENERALLY A FAULTY OVEN TEMP SENSOR. I WOULD ADVISE YOU TO CONTACT A CERTIFIED TECH TO LOOK AT IT AND P.S. DON'T MENTION THAT YOU TOOK THE MACHINE APART MOST SERVICE COMPANIES WILL NOT SERVICE THE MACHINE IF IT BEEN TAMPER WITH BY THE CUSTOMER DUE TO INSURANCE AND LIABILITIES
May 28, 2008 | Ovens
Creda convection oven wont heat up
my ge profile double electric oven, bottome convection wont heat up
Feb 19, 2008 | Ovens
Bosch HBL 645 Convection Oven -- No Heat
first out put voltages measures,when output voltages ok , then see the control circuit.after tnat every thing ok. replace heating elements.
Dec 10, 2007 | Bosch HBN 442 / HBN446 Electric Single...
Gaggenau oven won't heat on convection setting
this could be due to more than one cause selector switch faulty elements faulty. however this would mean both elements gone - there is one at the top and one at the bottom also worth while looking at the wiring to the convection elements. does the thermostat neon come on when convection is selected?
May 18, 2007 | Gaggenau EB294/295 Electric Double Oven
Zanussi ZHF470 Electric Double Oven Logo
60 people viewed this question
Top Zanussi Ovens Experts
ashburton
Flipper
Level 1 Expert
Are you a Zanussi Oven Expert? Answer questions, earn points and help others
