Question about HP OfficeJet 6210 All-In-One InkJet Printer
Cartridge 99 does not fit
I am trying to replace my color print cartridge from a 97 to 99. The 99 does not fit. The top has a ridge that is on the left side and the 97 is on the right side. Because of this it does not fit. Is there some way to solve this? I don't get it.
    Genius:
  • 1,224 Answers
One cartridge goes in at a time the color first
i found out there are new cartridges comen out what they call a change over to 300's i can remember them right off hand
but these 90's versions you might want to stock up cause these might disapear soon and seems though the 300 versions are haveing compatibility detection error problems
this kind of print carts. site on seen and site on asked printer dealer for these newer cartridges
Posted on May 11, 2008
Large ink spill. Printer no longer recognized new black cartridge.
You can perform the Tap 41 Cartridge Health Diagnostics Test: [applies to HP Deskjet 6800/6900/9800]
http://inkjet411.com/?page_id=1741 (refer to 2nd video to understand how to read the printed pattern)
1. With printer power on, press and hold the POWER button.
2. Press the Cancel (X) button four (4) times.
3. Press the RESUME button (Down Arrow) once.
4. Release the POWER button.
5. The Diagnostic Test Report should print.
--- A good HP 93/95/97/99 color cartridge should display 600 good nozzles, while a good HP 92/94/96/98 black ink cartridge should show 672 good nozzles. If the results yield anything different then the ink cartridge is likely damaged and will need to be replaced. Refer to 2nd video on how to read the printout: http://inkjet411.com/?page_id=1741
---- If the printer attempts to print the diagnostic test pattern (1 page) then the printer is generally considered operational and functional, if nothing is printed, but the printer attempts to print the pattern, then the tri-color ink cartridge is either empty, clogged or severely electrically damaged (black ink cartridge is not used). You can remove the tri-color cartridge, reactivate the tap 41 test and the printer will print the diagnostic test print in black ink (special "ink back-up mode").
For information on North American ink refill services at a major retailer near you (should you wish to save ~50% on ink costs), general printing problem resolutions or advanced HP printer diagnosis procedures (advanced cartridge diagnostic tests/cartridge error bypass & printer reset methods, etc.), please visit Inkjet411: http://www.inkjet411.com
Aug 27, 2013 | HP Deskjet 6988 Inkjet Printer - Color -...
How to change ink in HP Deskjet F480 printer???
  • Check the ink levels by opening the HP Solution Center. Click on "Settings." Click on "Toolbox." Click on "Services." Click on "Service this device." Click on "Estimated Ink Levels." A graphic will appear showing the estimated ink level in each cartridge.
  • 2 Verify that the unit is on. Open the print cartridge door allowing the print carriage to move to the far right side of the unit. Once the print carriage has stopped, lightly press down on a print cartridge to release it. Pull the print cartridge toward you out of its slot. To replace the tri-color print cartridge, remove the print cartridge from the slot on the left. To replace the black or photo print cartridge, remove the print cartridge from the slot on the right. Place the cartridge in a plastic bag as it may still contain some residual ink and may leak.
  • 3 Remove the new print cartridge from its packaging. Remove the plastic tape by using the pull tab, being careful to not touch the copper-colored contacts or the ink nozzles under tape.
  • 4 Slide the new print cartridge forward into the empty slot. Gently push the upper part of the print cartridge until it clicks into place. The tri-color print cartridge fits into the left slot. The black or photo print cartridge fits into the right slot.
  • 5 Close the print cartridge door. If the print cartridge alignment sheet prints, load it on the left front corner of the scanner glass with the top of the page to the left. Verify that there is plain paper loaded in the input tray, and then press the "Scan" button to align the printer.
  • Read more: How to Replace an Ink Cartridge in an HP Deskjet F340 ' eHow.com http://www.ehow.com/how_2303716_replace-ink-cartridge-hp-deskjet.html#ixzz16MAooFTf
    Nov 26, 2010 | HP DeskJet F380 All-In-One Printer
    Message says problem with tri color cartridge
    I don't think the date on the cartridge is the problem. It might be the electronic on your color cartridge. If there is an orange light flashing and the printer won't pull the paper to print, in 99%, the problem is one of the cartridges. Try removing the color cartridge and gently wipe out the electronic with a dry cloth. Put it back in and try to print. If that doesn't help, try removing the color cartridge and print (I am not sure if that will work, because all in one printers usually need both cartridges in order to print, but you can try that too). You can also try scanning something and see what the message on the printers display tells you. If there is an E an the color button is blinking, I think you should replace your color cartridge.
    Apr 04, 2010 | HP OfficeJet 7310 All-In-One InkJet...
    Insert HP color inkjet print cartridge 99 into HP OfficeJet 7410 I am replacing the HP 97 color print cartridge with th 99 print cartridge (both are color). The 99 will not go in all the way. I notice the...
    The HP 99 cartridge is used if you would like to print photos. The HP 99 replaces the HP 96 (black) cartridge in your printer. The HP 99 cartridge has black, photo magenta, and photo cyan inks in it. When you pair this with the cyan, magenta, and yellow in your HP 97 (color) cartridge you have the full set of photo colors represented.
    Jan 13, 2010 | HP OfficeJet 7410 All-In-One InkJet...
    Hp photosmart 2610 not recognizing new color printer cartridge (97)
    Print cartridge
    When the print cartridge contacts are dirty and the printer cannot detect/communicate with print cartridge.
    Clean the contact points on the cartridges with a dry, lint-free cloth.
    1. Open the top cover of the printer.
    2. Remove the print cartridges.
    3. Clean the copper-colored contact points on the cartridges with a damp, lint-free cloth. Use a dry, lint-free cloth to remove moisture from the contacts.
    5. Insert the cartridges back into the printer.
    6. Close the top cover.
    7. Try printing again.
    If you still cant communicate try with new cartridge .
    Aug 19, 2009 | Office Equipment & Supplies
    I installed a HP Cartridge -- 99 --. The first photo I printed was fine. The next three start out fine, but then about one inch into the print, in a straight line from top to bottom, the print takes on a...
    I had replaced the three-color cartridge with the photo cartridge. Then I remembered something the store clerk had said about replacing the black cartridge with the photo cartridge. When I did that, everything was fine.
    Apr 10, 2009 | HP Office Equipment & Supplies
    Color ink cartridge
    Backup mode means printing with one cartridge. If the printer tells you "cartridge failed", it probably doesn't recognize it. You can try removing it from the printer and gently wipe the electric contacts on the cartridge with a dry cloth. Turn the printer off, turn it back on and reinsert the cartridge. If the message is still there, I suggest you buy a new color cartridge. You can also go to the store where you refilled your cartridges and ask for their opinion, they may be able to help too.
    Oct 14, 2008 | HP Photosmart 8050 InkJet Printer
    HP 6310 Cartridge Error: Replace Cartridge
    well..did the printer cartridges come from HP?
    May 23, 2008 | Office Equipment & Supplies
    How do I print with the Photo 99 cartridge?
    We need to insert the 99 cartridge in to the black cartridge slot since it is a photocartridge. Once we insert the new 99 cartridge it will detect and then align the cartridge. If it does not, then clean the cartridges and then power cycle the aio and then try again.
    May 11, 2008 | HP OfficeJet 6210 All-In-One InkJet...
    Other compatable cartridges
    Cartridge Description
    Zone 1
    small black inkjet print cartridge
    HP 94
    small tri-color inkjet print cartridge
    HP 95
    large tri-color inkjet print cartridge
    HP 97
    photo inkjet print cartridge
    HP 99
    Jan 15, 2008 | HP PSC 2355 All-In-One InkJet Printer
    HP OfficeJet 6210 All-In-One InkJet Printer Logo
    57 people viewed this question
    Seeker5211
    Seeker5211
