Question about LaCie External USB 2.0 500GB 7200 RPM 500 GB Hard Drive
No files in drive but disk half full
I have a LaCie External USB 2.0 500GB 7200 RPM 500 GB Hard Drive, and used it for about 2 years as an archive, mainly photos. Suddenly Finder or XP can open the drive, but the drive appears to contain no folders or files. Both, Windows XP on my PC and Finder on my Mac recognize the drive and describe the drive properties as more then half full, however no folders or files are visible. I am looking at recovery solutions, as the files are important to me. Can you recommend a particular software to reliably recover my files and folders? The drive was plugged into the Mac when the problem occurred. I am looking forward to your kind reply. Paul
  • rockinfreaka May 15, 2008
    i have the same problem
    when i clicked on the lacie back up icon on my mac it all appeared again not a solution but nice to know all my files are still there
  • paulserious May 19, 2008
    Thanks varungrover; I'll try that.
    Paul
    Champion:
  • 207 Answers
I hope u already tried unhiding the files and then then checked??as it xp a microsoft product which is know for bugs
it might have various reasons..
might be the drive is corrupted ..and the mc system is showing the drive files or temp files which are accumulated over the period of time !!!! if u think tht there are pics in it which are not showing up in xp try to run back up of tht drive on cd and then check if there are pics in it u can recover it but using the windows back up.... i hope it is computer doesnt freez wh u conect to drive threr is one one more way a soft ware from hp named data suit available on there website
which can recover data from a crashed drives also so u can try tht also and then format ur drive if there are bad sector format will fix it
Posted on May 19, 2008
I have the Lacie Minidisk Ethernet 500 GB that contains all my house PC backup. I both an USB Minidisk Lacie (1 GB) in order to use MySafe feature but it never worked.
Hello Elio,
Use MySafe to back up the files stored on the Ethernet Disk mini Home to an attached USB storage device. This way, if files on the Ethernet Disk mini are damaged or accidentally deleted, you can restore them to their original locations.
There are three main steps to using MySafe,Connecting an external USB hard drive,Backing up files to the external USB hard drive,Restoring files to the Ethernet Disk mini (if necessary)
Before you can back up files, you need to connect a hard drive to your Ethernet Disk mini via the USB port on the back. Use a hard drive that is USB 2.0 compatible.
While connecting an external hard drive make sure your Ethernet Disk mini is turned on and connected to your network.Turn on the external USB hard drive.Connect the external hard drive's USB cable to the USB port on the back of the Ethernet Disk mini, just like you would connect the external hard drive to your computer.Confirm that the drive is properly connected. Log in and click on the Administer HipServ link. Click on USB External Storage under System.
To back up files, navigate to the file or folder you want to back up to the external hard drive and click on the disk icon in the "Backup" column of the file list.When you back up files to MySafe, the Ethernet Disk mini duplicates the file path in MySafe so that everything you back up is organized in MySafe just as in its original location. So, if you copy a file from MyLibrary, a MyLibrary folder will appear in MySafe, with all folders leading to the backed up file.
Always click the Safely Remove Drive button on the USB External Storage before unplugging your MySafe external hard drive. Wait for the interface to change and for the Use Drive button to appear before disconnecting the USB cable from the Ethernet Disk mini. Failure to safely remove your external hard drive before disconnecting the USB cable can cause data loss and/or damage the drive. Always use the Safely Remove Drive feature when disconnecting an external hard drive.
Jun 03, 2011 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
Lacie ext hard drive, 500 GB, doesn't show files but 123GB used
you can always recover your files with the program undelete . exe
verry good working tool.
if you are interested
Feb 13, 2010 | LaCie External USB 2.0 500GB 7200 RPM 500...
I have LaCie 500 GB Exernal Hard Drive. I was transferring some data from my computer into the hard drive. The hard drive fell off and stopped working. When i connect it to power, the power light doesn't...
Sounds like the power supply in the external case has gone bad (or going bad)...
If you have another external case, AND the drive itself is not damaged, you can move the drive to an external case.. Alternately, depending on the connection (IDE/SATA) you can move the drive internally to your computer.
Jul 20, 2009 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
XP doesn't recognize 500GB external Lacie after almost 2 years
try it on different usb ports on your system
try replacing the cable which connects the hard drive with the usb port
if this does not works the problem lies in the portable hard drive and i think it would be under warranty period so get it checked
Jul 09, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
Opens some files, not all
Yes, it is. Try running a scandisk or other HD repair software you have on it.
May 20, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
LaCie External USB 2.0 500GB 7200 RPM 500 GB Hard Drive Logo
231 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
