Question about Intellinet Active Networking Computers & Internet
I have an Intellinet 150N (52445) that was sold and installed by a service tech. He did not use the installation disc, but went into dos, and installed from there. My router works, but loses connection to my satellite modem at least once a day. I have to disconnect both, then reconnect. My computer forum advised me to change the channel, which I did. I went from 11 to 6. If possible the disconnect is worse! Do I keep trying other channels or is there another solution? Thanks
mlake33
  • 427 Answers
SOURCE: Router seems to drop connection frequently
What a static ip is, is the ip address that the router automatically assigns to other equipment. (computers, xbox, ect.) Find D-links customer support line for help.
Posted on Apr 12, 2008
  • 16 Answers
SOURCE: Router Connectivity
It will be one of two things or both - either your computer is not setup for DHCP or your router is using the same IP address as your ISP or both.
To check ISP IP address connect your computer to your modem then: from start => run => CMD (hit enter after this)
a command window opens, type "ipconfig /all" without the quotes.
The line with "IP address" gives you your ISP IP addr.
Compare this with what you get from your router manual if they are the same then do the following:
To configure your computer to use a DHCP IP address, go to the Control panel => network connections => Properties (right click on your default connection) => double click Internet protocol (From general tab) => (a new window pops up) from the general tab ensure that "obtain an IP address automatically" is selected.
To change the IP address of your router check your manual and do the following:
IP Addr => 10.10.1.1
Sub net mask => 255.255.0.0
Default gateway => IP address from your ISP
Make sure to the router is set to act as a DHCP server.
You should be up and running.
Posted on Aug 10, 2008
ckdestroyer
  • 60 Answers
SOURCE: Belkin router problems with RCA modem
Do a powercycle. Make sure to completely turn off the modem, router, after 30 seconds, turn on the modem first then the router.
If that will still not work, perhaps there is a need to update the software of your router.
Posted on Aug 24, 2008
SOURCE: how do i change the channel on my router
put in the disc again and run the installation and when it asked me to run the installation it asked me what channel I wanted it on but the default was 11 so I kept it there, just try to set it up again
Posted on Jan 28, 2009
dante777
  • 623 Answers
SOURCE: Belkin F5D8236-4 v2 - disconnects
You can get the latest firmware here:
http://www.belkin.com/support/article/?lid=en&pid=F5D8236-4&aid=14396&scid=942
I don't think that it is a problem with your IP address settings.
I would disable all security temporarily, just to see if that makes a difference.
If you are using Windows Vista, take a look at this post and see if that could be one of the underlying problems.
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Posted on Jul 11, 2009
What is itellinet_xp service when im trying to connect to wifi
Looks like a wireless USB Adapter service
Intellinet Wireless 150N USB Adapter Specs - CNET
https://www.cnet.com/products/intellinet-wireless-150n-usb-adapter.../specs/View full Intellinet Wireless 150N USB Adapter specs on CNET. ... Requirements. OS Required. Microsoft Windows 2000/XP/Vista/7 ... Service & Support Details. intellinet xp service Google Search
Oct 14, 2017 | Computers & Internet
Intellinet wireless adapter malfunction
Wireless Zero Configuration (WZC) was introduced with Windows XP, it is also known as WLAN AutoConfig in Windows 7 and Vista. It is is a wireless connection management utility which dynamically selects a wireless network to connect to based on a user's preferences and various default settings. or most users the Windows Wireless Zero Utility is all that is needed to manage your wireless connections.
You can configure WZC as follows:
  1. Type services.msc in "run" and enter.
  2. Select wireless zero configuration from the list which appears in the next window.
  3. Double click on that option , and choose to Start or Stop the Wireless Zero service.
Here are steps to use Wireless Zero Configuration/WLAN AutoConfig in Windows 7:
  1. Click the Windows logo button
  2. Type services in the Start Menu's Search box and press Enter. Scroll to the bottom of the list and locate WLAN AutoConfig'. Double-click WLAN AutoConfig to open its Properties window.
  3. Click the General tab of WLAN AutoConfig service. Click the Startup type drop-down menu and click Automatic to have the service started automatically when the operating system loads. Click the Start button. Click Apply and then OK. Close the Services console window.
  4. Click the Windows logo button. Type cmd in the Search box and press Enter. In the Command Prompt window, type netsh wlan show settings and press Enter. Look at the last line of the Wireless LAN Settings entry to see if the message Auto configuration logic is enabled on interface or Auto configuration logic is disabled on interface appears. If the entry notes that it is disabled, type, set autoconfig enabled=yes interface=Interface Name and press Enter. Close the Command Prompt window.
Nov 25, 2011 | INTELLINET Wireless 150N USB Adapter...
Hi i have intellinet 150n i have it over a year but its not secure so anyone can use it how do i secure it please
To solve this problem, follow the link below and follow the instructions on the linked page on how to solve this problem. For me to give you instructions here, it would be too long so I set up this link that will take you to solve the problem you're having http://assets.mhint.s3.amazonaws.com/downloads/6362/524681_02.5_manual_eng.pdf
Sep 10, 2011 | Intellinet Active Networking Intellinet...
We purchased the Intellinet 150N-4 Port Router a couple of months ago. It was working fine up until last Saturday afternoon. I called our IP and they re set our modem and we still couldn't get...
The router comes with a lifetime warranty however Intellinet does not offer phone support but rather a ticket submission system on their website. It also refers you back to the reseller to get technical assistance. Normally you can get free technical assistance from all 3 parties the manufacturer, Internet Provider, and the Re-seller. You may just want to return the item if you still can. Quite a few other brands offer free technical assistance Netgear, Linksys, D-Link, etc... Seems more like the device is the issue here. If you can exchange and get a new router, I'd be happy to walk you through setting up your new router as well.
Sep 06, 2011 | Intellinet Active Networking Computers &...
Hi need help
reading more about the "problem will help , what exactly happends??? do u get an "error message tell us more about it please
Mar 17, 2011 | IC Intracom INTELLINET WIRELESS 150N USB...
P C does not recognise intellinet wireless 150 N USB adapter because it does not have microsoft logo approved is it safe to install
It just means that the manufacturer neglected to do some safety protocols when they designed your USB Adapter. You might have trouble obtaining proper support with the Windows operating system, if that's the case just reinstall the drivers from the manufacturer's website.
Jan 21, 2011 | IC Intracom INTELLINET WIRELESS 150N USB...
Driver won't download intellinet ethernet driver os 98
Try to manualy specify the path to your driver using driver update.
Oct 06, 2009 | Microsoft Windows XP Professional
I have just installed the driver for an Intellinet wireless G usb adapter from the disk it came with. In the instal guid it says once ive installed the driver and plug in the adapter, it should...
did you plug in the adapter before you installed the driver . best thing to do is uninstall and reinstall. as well as that ralink wireless lan card is not what you bought it should say intellinet when installed properly. reinstall thats my advice
Aug 31, 2009 | Intellinet Active Networking Intellinet...
Computers & Internet Logo
144 people viewed this question
Top Intellinet Active Networking Computers & Internet Experts
Terry
Prashant M
Prashant M
Tech support
Tech support
Are you an Intellinet Active Networking Computer and Internet Expert? Answer questions, earn points and help others
