Question about Garmin GPSMAP 398 GPS Receiver
When garmin gps/map 398 in powered up it will not aquire sattilite data, works ok in simulator mode and sounder functions ok. Has internal antenna, suspect a antenna or gps receiver problem.
marcelbakker
  • 174 Answers
SOURCE: cannot find my map data anymore
Have you checked the wrench menu, map info, the preinstalled map should have a check mark, if not tap on the check box, it should now show a detailed map screen when you go back to the main menu and select show map.
Posted on Jun 12, 2008
sharcnet
  • 2130 Answers
SOURCE: "No Map Data Available" - Garmin Nuvi 350
This is because your map file has either been deleted or corrupted and needs to be replaced. Please see this link for more info. Too much info to copy & paste here:
http://www.sharc.net/nuvi_lost_map.htm
- Jim
Posted on Dec 13, 2008
SOURCE: Garmin gps 72 not aquiring satelites
Press POWER ON and PAGE buttons at startup and leave for 20 minutes to initiate
Posted on Mar 24, 2009
RamTek
  • 377 Answers
SOURCE: garmin c330 has problem finding gps signal
power off the unit first then power on then go to map screen then tap the signal icon bar then wait for your unit to track signal then when you see 5 signal go back to the map screen and check the signal icon and then if there is a firmware update for your unit try to download it.
Posted on Jun 09, 2009
  • 1111 Answers
SOURCE: My garmin nuvi 360 goes in simulated driving mode
if you recently plotted a course and used the simulation mode, it will stay there either till you deactivate it, or you arrive at the destination. go to the simulation mode and see if its in simulation, if so, stop it.
Posted on Aug 06, 2009
Garmin GPSMAP 178C not boot
can we download india map?if tell me how to download and install the map in my device Gm4300?
Nov 20, 2013 | Garmin GPSMAP 178C Sounder GPS Receiver
Garmin c330 turns on, gets maps, etc., but will not aquire satilite.
1.) Plug in your GPS into a computer and see if there is any updates, especially Firmware update
2.) Make sure you are in a clear view area to sky to receive sattelite,
3.) Go to Tools....Settings.... on the gps simulator make sure it is On
Oct 21, 2010 | Garmin StreetPilot C330 GPS Receiver
I have used the Gpsmap 178c for about 3 years now. Recently I have started be unable to find satelites, wass on or off. Once in a while it works. presently I get no satelites I would buy a new antenna...
Based on the problems I have seen with this unit the problem is the reciever circuit not the antenna, so you should consider a new unit, Garmin charges a fortune to repair these.
Sep 22, 2010 | Garmin GPSMAP 178C Sounder GPS Receiver
Garmin c330 has problem finding gps signal and tracking sattilite.
Jun 09, 2009 | Garmin StreetPilot C330 GPS Receiver
GPSMap 172c Can not read Garmin Data Card
I have the Sounder 178C. It will only work with 128 Mb Cards (or smaller). It does not work with the 256Mb Cards - says "Reading Card" forever.
Per Gramin, I had to buy the 128 Mb card and DVD map update. Then program the card with a USB data programmer to make it work.
May 01, 2009 | Garmin GPSMAP 172C GPS Receiver
MAP 76 locks up in normal mode after acquiring and starting to track, three to four minutes. Screen goes blank except for vertical stripe, no keys work. Have to pull batteries to turn off. Unit works...
I had the same problem (blank screen, vertical line). After speaking with Garmin, I was told to turn off the WAAS function. Disable it for now, because the WAAS signal, coming from the satellite, has changed, and Garmin has not yet published a remedy to correct this problem. A fix should be out in a software update, sometime in the future, hopefully. Just so you'll know, I also did a software update, to the latest version 4.0. The unit performs perfectly now, however, the accuracy is not quite as good, due to the lack of WAAS.
What you said does make sense. When you have your unit in simulator mode, the GPS receiver is turned off, so it is not receiving signals from the satellites. The strange signal from the WAAS satellite must be what has been messing things up. Good Luck!
Sep 26, 2008 | Garmin GPS Map 76 GPS Receiver
Garmin GPS 168 Sounder
screen got stepped on while fishing on front of boat and need to find someone who can repair the unit. Thanks for any advice..
Aug 15, 2008 | Garmin GPSMAP 168 Sounder GPS Receiver
Garmin Nuvi 300 - SD problem
I believe your current location is somewhere in UK/Ireland, which means the Nuvi's last/current satellite fix is not anywhere within Spain/Portugal. If you need to use the maps features of that country where you're not physically there with the Nuvi, the Nuvi must be in Simulation mode first. Fold down the antenna to switch off GPS (not device) and enter Simulation mode.
Then, scroll the map screen (combinations of zooming out, browsing, and zooming in to the spot) until you find the location you want to simulate (it must be within the maps coverage). Then, tap 'Set Loc' at the bottom of the screen. At this point, as far as the Nuvi is concerned, this is the GPS location where you are at. Then you may proceed with Address Search, etc. using the other map's database.
Jul 26, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin GPSMAP 398 GPS Receiver Logo
44 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
