Question about Calvin Klein Bold Metal K2237120 Watch for Men
I took my C/K watch back off but cannot replace it,even with a watch makers vice! Help
  • dick_covingt Aug 31, 2010
    The last expert said try c/w or a/c/w but this isn't threaded,
    the back must clip in under pressure,which I have tried,with a watchmakers vice.
    President:
  • 2,047 Answers
Getting this done can be quite tricky as the part in the watch are a bit delicate and also you would not want to break the glass in front. Before trying to force the cover back on you should first check the inner components and make sure that they are all in their respective places as a shift in anyone could affect the back cover from closing. If all the components are properly fitted and the cover is placed at the proper angle then you should not have a problem closing the back cover back. Ensure that the indented part on the cover lining is aligned with the rod which is used for adjusting the time on the watch. Feel free to request any further assistance. Hope this solution has been helpful?
Posted on Sep 08, 2010
  • 843 Answers
By "watch-maker's vise" do you mean one of those adjustable wrenches with three pins that are used for removing a screw-on back? It's really a misnomer - they should call these wrenches, as they are useful for unscrewing or tightening the back, but aren't very useful for holding the watch. So, now I am wondering if you have a screw-on back or a snap-on back. If it is a screw-on back, put the wrench aside and get the back started by hand (assuming you haven't already cross-threaded it.) Carefully, with a very gentle touch, turn the back counter-clockwise (as if you were removing it) until you feel the soft pop that occurs when the ends of the mating threads pass by each other. At that point gently turn the back to the right to engage the threads. If that goes smoothly, use the wrench to tighten.
On the other hand, if you have a snap-on back, just use your thumbs to press the back on. But I have always found that very difficult, so I do the following - sorry, some hobby tools required--- Use an adjustable diameter hole cutter in a drill press to cut a hole in a scrap of wood where the hole is just larger than the crystal of your watch. Lay the watch face down on this hole. Open the drill chuck all of the way so that the three jaws of the chuck are withdrawn completely. With the drill turned off, use it as an arbor press to evenly snap the back of the watch into place. If it's a large watch and a small drill press, then the back of the watch will have a significantly larger diameter than the face of the drill chuck. In this case use another piece of scrap wood (hardwood or metal is best) between the drill chuck and the back of the watch. This works for me every time.
Good luck, Al K
Posted on Aug 31, 2010
  • Al Kupchella
    Al Kupchella Sep 01, 2010
    I saw your comment from yesterday. I covered both types (screw on and snap-on) in my solution. The second paragraph covers the snap-on solution. Please let me know if you need anything else.
    Good luck,
    Al K
    President:
  • 1,851 Answers
I'm not an expert at the watches but just an idea. Have you tried counterclockwise turn?
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
I found a watch and I am trying to look up the serial number but I can not find it can u help
Your best solution is to take it to a watch maker. Serial numbers, if it even has one are usually located on the underside of the back plate. I'm curious, who is the maker listed on the dial and is there any marks or writing on the back plate
Oct 10, 2014 | Watches
Battery replacement
I found a "battery" website that had some suggestions that should be typical of any snap back case watch.
http://www.online-batteries.co.uk/whichb...
specifically they said that when you try to press the back on it must be flat (not one edge down as I had been trying) Put the watch face down on a non scratch surface and press with both thumbs evenly. If that doesn't work a press will be needed. If you have a vice a couple of blocks of wood to distribute the load on the front and back may work, otherwise take it to a jeweler with the proper equipment.
The thumb routine didn't work for me. I have a vice but figured many wouldn't so I tried something else first. I put the watch face down on a piece of wood. I found a small 2" long scrap of wood (3/4" x 1.5" approx) that spanned the back. I centered the back (aligned properly) placed the block of wood squarely and centered across the back and tapped the end of the block with a hammer. First try didn't work, second one did. I used a rubber mallet as the hammer but a regular hammer or other heavy object would work. The trick, I think, is to get everything lined up and square so the blow is centered and even.
Also, I'd suggest cleaning the back and the groove in the case and be sure the rubber gasket is properly positioned. This will give you the best chance of retaining the waterproofing. And remember to check that the watch is running before you do this. Some need to be reset (usually with a very small screwdriver or pin) after replacing the battery. There should be a small hole with some printing next to it. You may need a magnifying glass to see/read it.
Hope this may help you;
Sep 07, 2008 | Watches
How do I put the back cover on a Waltham watch?
Try hooking the edge furthest from the winder at first, then work toward the winder.
If that isn't enough... warm the back cover with a hair dryer while you chill the rest of the watch. Serious as anything - the warmed cover will expand JUST SLIGHTLY while the cooled watch will contract JUST SLIGHTLY, maybe enough to snap that cover on. You can cool the watch in a freezer, but if you do... quickly snap the cover on while you hold the watch in the still-open freezer. If you take the watch from the freezer and leave it open at room temperature, it'll get moisture condensate inside. Leave it cold until the cover's on.
It also helps to wear cotton gloves if you use the heat-and-cool approach - then your hands won't appreciably cool the warmed cover or warm the chilled watch.
The watchmakers have a special watch press that squeezes the back into place - it's padded to prevent damage to the crystal, and applies a little extra force to the center of the back to buckle the rim outward just slightly during pressing. Like the opposite of a wheel cover for a car.
Jul 30, 2014 | Waltham Watches
I cannot replace the watch back on my Perry Ellis watch
A watch press will be needed.
RECOMENDATION:
Seek professional help.
To find a registered repair person in your area.
GOTO:
http://www.watch-clock-makers.org/
Hope this tip helps.
r/ David
http://antiqueclock.clockstop.com/
May 14, 2010 | Nixon Manual NIX0031 Wrist Watch
I have a Geneve watch and need to change the battery. The case seems to have no way of opening it and seems to be one piece and I took it to the jewelers and they can't replace the battery. Is there any...
Of course, there is the way to change the battery, but for this you have to visit your closest watch repair shop. I do mean WATCH REPAIRS, not the jewellers. Decent watchmaker will definitely open your watch and will replace the battery. Your watch's case appears to be a monoblock. That means you'll need to lift the crystal first, pull the stem second and just then you'll be able to extract watch's movement for replacing battery. Do not forget: jewellers and watchmakers are under one roof, but their trades are completely different. No jeweller can do watchmakers job and vice versa. Rate me, plz.
Mar 19, 2010 | Watches
Putting back on timex watch
There is a press to put this back on.
RECOMENDATION:
GOTO
r/ David
Mar 11, 2010 | Bulova Watch
Cannot get the back cover on my eddie bauer watch after replacing battery
Watch makers/technicians use a special press to replace the back. You can get these presses but the cost can be more than it is worth.
Since the watch is most likely water resistant and you will have to go to a watch maker/technician to replace the back anyway I recommend having the rear seal inspected and replaced if needed and having the watch pressure tested to be sure that it is sealed to factory specifications.
Sep 24, 2009 | Watches
Stem of watch won't return to its original position
The winding crown is loose on the stem. Get the stem completely out of watch and while holding in vice or pair of pliers screw the crown back on tight. Do not overscrew it, as the stem may brake. Even better would be to unscrew the crown first, dip the threaded stem end in to the Superglue and then screw the crown back. It will prevent from the same problem in future.
Rate, please.
Jul 29, 2009 | Watches
How to remove links from timex ironman data usb wristband
Most metal bands simply need the folded edges bent upright and the link fasteners removed. They look like small staples. If you don't have this type, use a small paperclip, held in a pair of vice grips to push the pins out. Put them back in the way you took them out. the holes will loosen if you don't put them back in the way they were.
Jun 29, 2009 | Timex Ironman 30 Lap 53952 Wrist Watch
Replacement battery for DKNY NY1050
DON'T FORGET TO RATE:
Sep 05, 2008 | Watches
Calvin Klein Bold Metal K2237120 Watch for Men Logo
89 people viewed this question
Top Calvin Klein Watches Experts
aravind shet
aravind shet
Joseph Hoffmann
Are you a Calvin Klein Watch Expert? Answer questions, earn points and help others
