My vrvd640g car stereo/dvd/cd player gives an invalid disc error each time a disc is put in. what can i do to fix this?
  • 3 more comments
  • jsword2 Jul 20, 2008
    my vrvd640g car stereo/dvd/cd player gives a loading error each time an mp3 memory stick or mp3player is put in. what can i do to fix this?
  • vincenguyen0 Sep 07, 2008
    i can not insert disc into my vrvd640g. everything work good just can not insert disc in. i need some help on this
    thanks
  • hokiefan Oct 08, 2008
    I am receiving an "invalid disk" message as well......i am getting this message regardless of whether a cd or dvd is inserted. any help would be great.
  • smizzel99 May 16, 2009
    how do i brighten the screen
  • TROltmanns May 11, 2010
    If you are having specific issues with your car receiver, contact Roadmaster support for your VRVD640G car receiver
I think you can reset by pushing a pen into reset hole on face (remove stereo face first.) Or try pushing the screen on all four corners at once. HTH!
Posted on Sep 03, 2008
My vrvd640g is is stuck on a loading screen i try everything for this item i have press the reset button.... what can i do for this item....
Posted on Jul 13, 2009
Toshiba Portable DVD will not spin upon start up
If the disc does not spin it will cause the optical reader to not read the disc, which will give you the "no disc" or "invalid disc" error. If a disc will not spin, the most common cause of this is due to a spindle motor malfunction. The good news is that it can be fixed on average of between $70-90 dollars depending on what service repair technicians charge in your local area. You can fix the problem yourself if you have the patience and a bit of knowledge, but I can tell you from first hand experience it is a pain to do this.
The pictures below provide you an idea of what you are looking at.
I hope this helps give you an idea of what the problem is and helps you solve the issue.
If you would not mind, please rate my help. I would greatly appreciate it. Thank you.
Feb 06, 2010 | Toshiba SD-P1900 Portable DVD Player
Disc shows loading then error on all dvd disc
Put a cd in the dvd player if it is marked that it plays cds... if it plays the cd your dvd laser is shot... cheaper to get a new unit. if it doesn't play a cd try cleaning the laser. and last but not the last thing try unplugging it for a short time then plug it back in... if nothing works get the one tool that fixs most everything...... take it to office depot and they can recycle the stuff inside and help keep the earth green...then onto wally world.
Nov 26, 2009 | Philips DVP5140 DVD Player
Vrvd640g dvd invalid disk but it will play music cd's flawlessly
sometimes a simple lens cleaner will fix the problem
Nov 04, 2009 | Car Audio & Video
Trak error or Disc error
look put the brake wire to ground
Jul 14, 2009 | Panasonic CQ-DVR909U Car DVD Player
CD player says error and spits discs back out repeatedly
If cleaning didn't help,then replacing is the way to go.You can go to a local stereo shop and see if they can fix it easily.they might know the trick on doing it.It's worth a try.Don't go to Best buy.I know you have seen one as you were driving around town,just pull in and see what's up,They may have fixed one as the same as your Nissan.
May 30, 2017 | 2000 Nissan Sentra
DVD gives an invalid Disc Error
This is quite easily, cause by ONE reason. The thing is, the lens is very very dirty, or had broken, try to replaec it if u can, or try cleaning it with cotton.
Mar 30, 2009 | Lite On LVC9006 DVD Player/VCR
Try to clean the lazer,and make sure the disc is clean.
The lazer will get dirty over time.
Feb 08, 2009 | 2000 Nissan Sentra
Error C:31:00
It seems this sort of problem is very common with this player. The fix I have is pick the player up, rotate it 90° give it a very light nudge, and then put it back. This has fixed the problem on mine each and every time. It will come back, but just do it again. It's probably best to put the dvd player in an easy to reach place cos you'll need to do it often once it starts making the noises and error messages.
May 16, 2008 | Sony DVP-F25 DVD Player
Dvd player
Not a disc cleaner you need but a lens cleaner. If that does not work then there are electronic or mechanical problems and most likly not worth repairing.
Sep 30, 2006 | Bush DVD2038 DVD Player
Televison & Video Logo
1,212 people viewed this question
Top Televison & Video Experts
