Sir, Panasonic TV Model TC21FJ20C No Power on set goes in protection
Sir i want panasonic tv remote model number my tv model pc21psr
There is no Such model set for Panasonic Till time. Your set might have a duplicate one from China.
Aug 30, 2012 | Televison & Video
How do i get my panasonic tv out of protection mode
the set is shut down becuase of an issue. Does the power light blink a certain number of blinks/ If so let me know the number of blinks and I will assist with possible cause of the protective shutdown.
Feb 19, 2012 | Panasonic TH-58PZ850U 58 in. HDTV Plasma...
My set wont come on.
The tv power supply board is dead.That the board where,the power a/c cord plug into it.That the power supply board.Tries websites like Shopjimmy.com Ebay.com to buy a whole refurbish power supply board for the replacement.
Jul 16, 2010 | Panasonic Viera TH-50PX80U Plasma TV
My model is a WS-55511. I turn on the TV, the
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD “device” and “menu” buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC’s is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
Aug 08, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Power won't turn on; red lights blinks occasionally
It sounds like a bad PSU, or a bad solder joint on one of the boards.
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Apr 08, 2009 | Panasonic Viera TX-32LX70 32 in. LCD TV
STANDBY MODE FOR PANASONIC FLATSCREEN TV TH-42HD6
Your TV is in protect mode. A problem was detected and the set shutdown. Is there a pattern to the blinking?
Dan
Mar 21, 2009 | Panasonic TH-42PHD6UY 42 in. HDTV-Ready...
Program Code
DIRECTV Model D-10 00001, 00002
Hughes Network Systems (most models) 00749
Hughes Network Systems models GAEB0, GAEB0A, GCEB0, GCEB0A,
HBH-SA, and HAH-SA 01749
GE models GRD33G2A and GRD33G3A, GRD122GW 00566
Hitachi model HDS210R 00819
Mitsubishi HD models SRHD400 and SRHD500 00749
Panasonic models TZ-DBS01 and TZ-DRD100 00247
Panasonic models TUIRD10 and TUIRD20 00701
Philips models DSX5150R,DSX525R/I, DSX5350R, DSX5353R,
DSX5353X, and DSX5375R 01076
Philips models DSX5500 and DSX5400 00099
Proscan models PRD8630A and PRD8650B 00566
RCA models DRD102RW, DRD203RW, DRD301RA, DRD302RA,
DRD303RA, DRD403RA, DRD703RA, DRD502RB, DRD 503RB,
DRD505RB, DRD515RB, DRD523RB, and DRD705RB 00566
RCA models DRD202RD, DRD221RD, DRD222RD, DRD223RD
DRD225RD, DRD420RE, DRD440RE, DRD460RE, DRD480RE,
DRD430RG, DRD431RG, DRD450RG, DRD451RG, DRD485RG,
DRD486RG, DRD430RGA, DRD450RGA, DRD485RGA, DRD435RH,
DRD455RH, and DRD486RH 00392
Samsung model SIR-S60W 01109
Samsung models SIR-S70, SIR-S75, SIR-S300W, and SIR-S310W 01108
Sony models (All models except TiVo and Ultimate TV) 01639
Toshiba model TSR101DSS 00790
Uniden model UDS100 00724
Setup Codes for DIRECTV HD Receivers
DIRECTV Model H-10 00001, 00002
Hitachi model 61HDX98B 00819
HNS models HIRD-E8, HTL-HD 01750
LG model LSS-3200A, HTL-HD 01750
Mitsubishi model SR-HD5 01749, 00749
Philips model DSHD800R 01749
Proscan model PSHD105 00392
RCA models DTC-100, DTC-210 00392
Samsung model SIR-TS160 01276
Samsung models SIR-TS360 01609
Sony models SAT-HD100, 200,300 01639
Toshiba models DST-3000, DST-3100, DW65X91 01749, 01285
Zenith models DTV1080, HD-SAT520 01856
Setup Codes for DIRECTV DVRs
HNS models SD-DVR80, SD-DV40, SD-DVR120,
HDVR2, GXCEBOT, GXCEBOTD 01442
Philips models DSR704, DSR708, DSR6000,
DSR600R, DRS700/17 01142, 01442
RCA models DWD490RE, DWD496RG 01392
RCA models DVR39, 40, 80, 120 01442
Sony model SAT-T60 00639
Sony model SAT-W60 01640
Samsung models SIR-S4040R, SIR-S4080R, SIR-S4120R 01442
10
PROGRAMMING
Jan 26, 2008 | Directv RC23 Remote Control
Panasonic colour tv TX-29P150X (Made in Malysia)
sounds like you have a intermittant thermal condition and this could be the regulator IC the video jungle/sweep Ic. Anything in the switching poewer supply or sweep curcuit. This is a hard one unless your there with a meter and a schematic to measure voltages when the set goes out then you can use a can of freez sprasy to lightly spray on the supected part. Sorry i cant be of more help. Good Luck
May 17, 2006 | Panasonic TX-32PM1 32" TV
Televison & Video Logo
81 people viewed this question
Top Televison & Video Experts
Electro Med Services...
