Question about Carrier 1--2--3--4 Bike Rack Holder Bicycle
How to mount a Bell bike rack on a 2001 Chev Blazer which has a glass window completely covering the upper section of the rear hatch.
    Brigadier General:
  • 8,546 Answers
The picture in the manual for this typical rack shows it mounted on an SUV with the upper support right on the glass hatch. If you think about it, there isn't really an forward horizontal force on the loaded rack.
Here's a picture of it.
http://biketrunkrack.com/bell-triple-back-locking-3-bike-trunk-mount-rack/
I contacted Bell Sports and complained about the lack of downloadable manuals. They said they are in the process of developing the website which will provide them.
http://www.bellbikestuff.com/
It has some basic stuff about helmets and tire changing right now. Stay tuned and check it once in a while.
In the meantime, they sent me the manual for the Doubleback/Tripleback Car Rack in English since that was the one I used as an example.
If you post your email to this solution I will be notified and will send it to you.
Posted on Apr 21, 2011
Back defrost on 99 chev blazer not working
Has the rear glass been replaced? The wires to the glass are notorious for breaking near the upper most point of the hatch where the hatch opens and the harness flexes between the body and the hatch every time you open it.
Mar 27, 2014 | Chevrolet Blazer Cars & Trucks
The tail gate and rear window will not open although I hear the electric release motor operate
I had the same problem with my 2001 Blazer. Just remove the panel by the screws located on the side of the tailgate, the problem was a bad actuator which pulls the lever to open the glass hatch. Once you take off the panel, remove the metal shield on the tailgate and the actuator will be mounted on the back of it. There are several ways to open the hatch on blazers and jimmys. You can try to release by inserting a small screwdriver and pushing left using the entry hole in the rear hatch deck just below the plastic trim in the center. This works ok unless the latch is out of alignment. The quicker way to release the window lock is to pull the center of the plastic trim (where it rises) toward the inside of the car and break the plastic trim attachment. Remember first to remove the hatch handle.By pulling away from the window, you can then insert a finger between the two walls of the lock assembly and push down. The window will open immediately. Ignore the broken trim attachment as there is plenty of support for the top of the door trim piece. Unbolt the 9/32 panel screws and the two phillips head side screws and the panel will come off. Careful of the rods clipped to the panel. They come off easily as does the hatch door activator. Rather than have to buy an actuator because the blue piece of plastic broke, replacements are available at online auto supply stores. Remember to make sure that the lever of the actuator hits the window release mechanism squarly. A little bending with pliers will align these two pieces so they strike evenly.
Sep 18, 2011 | 2001 Chevrolet Blazer
Does the Bell Locking Three-Bike Rack work for crossovers such as the Mazda CX-7?
Probably. It's pretty versatile. The manual and this picture show it on the rear of an suv.
example:
Jul 14, 2010 | Bell Locking Three Bike Rack
1996 chevy blazer 4wd rear hatch and window does not open. How can I maually open the rear hatch without taking off the panel
owners manual page 2-9 peel back or **** the carpet locally to expose the access hole in trim panel on endgate use a thin screwdriver to reach through the access holes in both th trim panel and the hardware cover. pry the release lever toward the passenger side until the glass latch pops open.
Oct 15, 2009 | 1996 Chevrolet Blazer
Bulb replacement for 2001 Chevy Blazer
all the mounting bolts are inside the door. open rear hatch and remove the mouldings and trim to reveal the mounts then have at it. bring the bulb with you because its the best way to replace it.
Jul 28, 2009 | 2001 Chevrolet Blazer
2001 Ford Escape Rear Hatch won't unlock
The liftgate consists of the following components:
  • liftgate door lock actuator
  • liftgate lock cylinder (if equipped)
  • liftgate window glass
  • liftgate window latch/ajar switch
  • liftgate window glass release handle
  • liftgate latch remote control which consists of the following component:
    • liftgate release handle
  • liftgate latch, which consist of the following component:
    • liftgate latch door ajar switch
Liftgate Latch Actuator Removal and Installation
  1. Remove the liftgate latch remote control. For additional information, refer to Liftgate Latch Remote Control in this section.
SECTION 501-14: Handles, Locks, Latches and Entry Systems 2001 Escape Workshop Manual
REMOVAL AND INSTALLATION Liftgate Latch Removal and Installation
  1. Remove the liftgate trim panel.
  1. Disconnect the liftgate ajar switch electrical connector.
  1. Disconnect the liftgate latch actuating rod.
    1. Open the clip.
    1. Disconnect the actuating rod.
  1. Remove and discard the liftgate latch bolts.
  1. Remove the liftgate latch.
  1. NOTE: Make sure the liftgate latch release rod is not preloading the latch. It should be clipped in a relaxed state with no slack.
    NOTE: Position the liftgate latch release rod by pushing outboard to remove the slack.
  1. Remove the screws and the liftgate latch actuator
May 29, 2009 | 2001 Ford Escape
How do you remove rear hatch panel cover on 1998 chev blazer
There should be screws around the edge of the panel. There are plastic panel locks that need to be pulled out, really the only way you can do that is to gently/firmly pull up on the panel. I had to exchange my rear wiper motor. To put the interior piece back on, just pop the locks back into place and screw back down.
Apr 05, 2009 | 1998 Chevrolet Blazer
Carrier 1--2--3--4 Bike Rack  Holder Bicycle Logo
203 people viewed this question
Top Carrier Cycling Experts
Michial Gueffroy
Bill Boyd
Are you a Carrier Cycling Expert? Answer questions, earn points and help others
