Question about Ruud UBHC Air Conditioner
What size filter do I need for a Ruud model UBHC-17J07SFE?
  • 455 Answers
Hello You will have to measure the old one for the size.If it is in the unit itself I think it's 20X25X1"
Posted on Aug 31, 2010
My system uses a permenant air filter. It's missing. It's a Ruud Model UBHC-14J11SFA. What size replacement filter can I put in this system?
You can measure what size and use any after market permanent filter. Measure the opening to the rear and across the opening. Should read as ?x?
Dec 03, 2014 | Ruud Heating & Cooling
Where is the filter in ruud model UBHC-21J11NFC
It depends upon configuration- or how it was installed.
In general terms, wherever the air from the structure is being drawn into the cabinet for air recirculation/intake- the filter will be in the vicinity of the ducting connecting to the Ruud heat pump/AC.. It will be before the "A coil" assembly (the copper tubbing with fins roughly the shape of an "A".
This assumes it was installed correctly. If not, the A Coil will collect a thick layer of dust on the side facing the incoming air flow.
The relevent Ruud documentation is here:
http://www.ruudac.org.ua/ubhc02.pdf
If there is any doubt about the integrity of the installation, contact an HVAC contractor familiar with your area to inspect and make corrections if needed.
Apr 11, 2012 | Ruud UBHC Air Conditioner
My system uses a permenant air filter. It's missing. It's a Ruud Model UBHC-21J18SHG. What size filter should I put in this system?
The Ruud UBHC-21J18SHG has a nominally 21" cabinet width. So the needed filter is 19.75" x 21" x 0.375" (502 mm x 533 mm x 9.525 mm). The Ruud part number for the filter is 54-23217-03 .
The specifications sheet for the Ruud UBHC series air handlers is available here: http://www.coburns.com/images/PDFs/h22-517rev1.pdf . The filter size information is on page 3 and page 12.
I've found the filter at one online vendor: http://www.patriot-supply.com/products/showitem.cfm/RHEEM_68_101807_03 . (This is a common filter that fits several manufacturer's air handlers.)
I hope this helps.
Sep 10, 2011 | Ruud UBHC Air Conditioner
I have a ruud ubhc-14j11sfd will a 17500 50 amp generator run without any problems
Look at the data plate on the unit, You need the LRA locked rotor amps, and RLA run load amps
It will also show max fuse size and min fuse size. A 3-4 ton unit should run on the gen, but starting is my question, this can be 3-7 times run load amps.
Aug 31, 2011 | Ruud UBHC Air Conditioner
My son has a Rudd air conditioner Model UBHC-17J11. Where is the filter located?
If you pull the bottom door off, or where the blower motor is, the filter should be with
sight.
Aug 28, 2011 | Ruud UBHC Air Conditioner
What size air filter fits model #UBHC14J06SFD? I was told by a tech that the original filter that came with the unit needs to be replaced. This was purchased back in 2004. The sizes that are sold in the...
Recommend a washable lifetime filter that can be custom fitted for your unit. There are many different brands of cut to fit and custom sized filters available.
The original filters supplied with the unit are usually washable as well although the manufactures are not including it all the time anymore.
Aug 21, 2011 | Ruud UBHC Air Conditioner
What air filter size fits a Ruud model UBHC Series?
well go to the forced air unite and open up the fan compartment and measure the size. or find out the air returns and there should be filter in there.
Jul 09, 2009 | Ruud UBHC Air Conditioner
Capacitor unable to read what size
If it's the condenser fan motor cap then look at the label on the fan motor for the size usally 3/5 mfd.
If its the compressor run cap then check the top of the compressor or the info. plate/sticker on the unit for the size of the cap. Let me know if you have any other questions.
Phil
Apr 10, 2009 | Ruud UBHC Air Conditioner
Ruud UBHC Air Conditioner Logo
169 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
