Sharp Aphrody Auto Shut-off
The problem is it always shut-off automatically. I've already checked the cord but I think that is in good condition. I've also check the remote control but it is not in a sleep mode. What would you think the problem?
  • Anonymous Dec 19, 2008
    same problem with my sharp aphrody tv
  • rosc_18 Jan 31, 2009
Reduce the brightness of the picture to level 35 and observe,
Posted on Jan 30, 2009
My sharp aphrody 21v-fp90s is auto channel to fix it
Main system control memory IC fault. Check and replace it. If you wish to get some details; check the site linked here. Pull up older posts.
Oct 08, 2016 | Sharp Televison & Video
Copiers Sharp AL-1631 AL-1641CS
Toner save mode
Reduces toner consumption by approximately 10%.
Power save modes
The unit has two power save modes of operation: preheat mode and auto power
shut-off mode.
Preheat mode
When the unit enters the preheat mode, the power save indicator will light up
and other indicators will remain on or off as before. In this condition, the fuser in
the unit is maintained at a lower heat level, thereby saving power. To copy from
the preheat mode, make desired copier selections and press the start key
using the normal copying procedure.
Auto power shut-off mode
When the unit enters the auto power shut-off mode, the power save ( ) indicator
will light up and other indicators except the ONLINE indicator will go out. The auto
power shut-off mode saves more power than the preheat mode but requires a
longer time before starting copying. To copy from the auto power shut-off mode,
press the start key. Then make desired copier selections and press the star key using the normal copying procedure.
Auto clear
The unit returns to the initial settings a preset amount of time after the end of copy, or
scanner job. This preset amount of time (auto clear time) can be changed.
Stream feeding mode
For description of the stream feeding mode, see "Stream feeding mode".
Resolution of AUTO & MANUAL mode
You can set the copy resolution used for AUTO and MANUAL ( ) exposure
on Mar 14, 2010 | Office Equipment & Supplies
I have a D55168 Dewalt compressor. Since I've had it, it has never shut off automatically and I've always shut it off manually at 200 psi. If I leave it alone, will it automatically shut itself...
Your concern is very well placed, at pressures that high a lot of damage can be caused by a failure. According to the manual for this model air compressor the approximate cut-in pressure is 160 psi and the approximate cut-out pressure is 200 psi. Meaning it should pump up to 'about' 200 psi and shut off and not come on again until it gets down to 'about' 160 psi. They say approximate and I say about because it's not an exact science setting the pressure switch. Spring rates are not always exact, pressure guages are not that precise, etc. When turned on, it should shut off at 200 psi +/- 10 lbs. If it goes more than 10 lbs over that (220psi), I'd recommend you get the pressure switch and or guages checked or replaced.
Jun 16, 2011 | Dewalt D55168 1.8 HP Wheeled Portable...
I just bought a top-end MacBook Air 13.3" 4 GB/256 GB for presentations. I also have a Dell M410HD projector, also quite new (a few months old), which works great with the two PCs (one new, one old)...
They (Apple) might be right. It could be that the projector is damaged, like the bulb, or it could be incompatible with your computer, but I don't think that is the case. Try taking the projector to a computer repair place.
May 17, 2011 | Apple MacBook Pro Notebook
Head light problems sometimes they will not shut off sometimes they (low beams) come on by themself high beam will not shut off
Are you sure there not running in daytime running light, when you think high beams are on
Also, there is sensor on the dash, usally on the speaker grate, that senses night and day. In the daytime your headlights will automatically come on when your car is in drive, and be on the high beam bulb, but dimmer than regular. At night, or in low light conditions, your lights will automatically switch from daytime lights to regular low beams. And yes, even when your switch on the dashis turned off, your lights work automatically.
To turn of the auto setting, just push the override button for your dome light, in and out 3 times, you should hear a chime, and your lights should shut off. This setting resets everytime you shut your vehicle off. Or to turn the auto setting back on, push the over ride button 3 more times.
Apr 15, 2011 | 2002 Chevrolet TrailBlazer
Installed new thermo but it wont shut off when on auto
Auto mode will shut off automatically. If you want to check up your thermostat is in condition, keep " cool" or " Heat" mode and try.
Dec 07, 2010 | Honeywell Heating & Cooling
A/C light always comes on when I press Auto
yes dont use auto use manual i think auto automaticly turns on a/c. check manualy to be sure.
Oct 13, 2009 | 2009 Audi A3
Automatic Shut Off
I ended up returning the item for a replacement per the manufacturer. Wish I had an answer!
Apr 09, 2009 | RCA Televison & Video
Sharp TV 29V-J200S Schematic Diagram
what kind of schematic are you looking for? I did find this one here but i don't know if it is what your looking for. try this website:
it is a circuit diagram hope it helps you out
Dec 19, 2008 | Orion1934 19" TV
Televison & Video Logo
329 people viewed this question
Top Televison & Video Experts
