Question about Hansol H550 15" LCD Monitor
Hansol H550 Monitor-when i switch the monitor on it flashes then goes off. I keep switching the screen on and it just keeps flashing then goes off again. I can do this for a while some times 15 minutes to 30 minutes yesterday it took 75 minutes of pressing the screen on and off before it did eventually come on. I believe it may be the back light , can this be easliy replaced or is it something dramatic that requires a new investment in a new monitor
4 Suggested Answers
  • 84 Answers
SOURCE: resolution hansol 730E
interesting, have you tried perhaps a monitor screen?
Posted on Feb 11, 2008
SOURCE: Hansol H950 19
Most likely the power supply, or the back-plane lamps, or the back-plane supply, or a defect on one of the processor boards is loading the supply too much, or any combinations of these are defective. You will have to have a source to try the boards to fix the monitor. I would suggest to find the authorized service rep for your monitor. They will have to service it for you. If the monitor is out of warranty, the fix will not be cheap!
Jerry G.
Posted on Apr 11, 2008
dj_relly999
  • 4070 Answers
SOURCE: no sound
Hi! Please do try to reinstall the driver. This may resolve the issue. Hope this helps and have a good one!
Posted on Jul 01, 2010
My samsung RV511 laptop won't boot and the monitor keep on flashing on and off but the power indicator still ligths on
The monitor keeps flashing on and off? Or does your system keeps trying to reboot which causes the monitor to go on and off. Does the screen turn Blue before it goes off?
Apr 10, 2012 | Computers & Internet
Hi, My Hansol H550 used to come on when my PC tower was booting up, but now I have to press the green on/off button. BUt unfortunately, after pressing the on off button the screen only comes on for a split...
Sounds like there is no input to the monitor. Check the video cable(the one with the screws). Even if it looks plugged in, unplug it and replug it at both ends.
Feb 27, 2011 | Hansol H550 15" LCD Monitor
Good Morning, My monitor keeps blinking and on the display you can see it keeps switching from analog to digital, i am using a dvi cable, and it is set to digital via the monitor, the weird thing is it...
My samsung monitor model 2233SW PLUS keeps flashing on and off and if i press the side button a menu type magic bright comes and shows whether to change in cinema ,custom ,text,internet mode etc,and when this option comes it doesn't flash and after 10sec this option goes off then again it keeps flashing in 5 sec. and the menu option doesn't come if by chance it comes than again for 2 to 3 min it stops flashing sometimes for 5 min .please help good-morning-monitor-keeps-blinking-orr1pjn3khwbyjvnsjgmppfg-5-0.jpg
Sep 03, 2010 | Samsung SyncMaster 213T 21.3" LCD Monitor
No sound in hansol h550
Jul 01, 2010 | Hansol H550 15" LCD Monitor
A menu keeps flashing on my monitor so fast I can not read it and it will not stop. Black box with grey edge. Compaq 5017M monitor
mrsrobins849, if monitor manufacturing date (on rear of unit) is anywhere close to 2003-2004 then trade unit for new wide screen only if problem of flashing "menu" goes away when you connect a borrowed substitute monitor to your pc. Will your monitor "act" same when connected to "known-good" "fully-booted" pc that will display the WIN-desktop?? Most problems with "cold-cathode-fluorescent-lamp" "back-lit" lcd monitors can be attributed to their internal or external "switch-mode-power-supply" DC voltages degrading over time with use.
12fixlouie
May 28, 2010 | Compaq FP 5017 15" Flat Panel LCD Monitor
I am thinking of buying a used Hansol 550 - three years old. Do they deteriorate with age ? Do all the old models have speakers fitted ?
3 years old will more likely to need new set of caps, not all monitors come with built-in speakers. See failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
I would not buy a 3 years old 15", save the money for newer and bigger monitor.
Feb 10, 2010 | Hansol H550 15" LCD Monitor
Monitor blinks
  • As soon as you restart your computer keep tap f2 key.
  • You can Bios screen, leave it for half an hour.
  • if you have same problem in the bios screen, its problem with the monitor.
  • if not problem with your operation system.
Thanks, SF
Jan 28, 2010 | Hansol H550 15" LCD Monitor
Monitor is blank and the power light keeps flashing green.
When you switch on both Poota and Monitor, is there visual startup flashes or startup information showing on screen.
Make sure the monitor connect to rear of poota is located and firmly in place and properly screwed in?
Nov 12, 2009 | Dell E196FP 19" LCD Monitor
Flashing on and off
Is the monitor a LCD monitor and does it uses a power adapter?
If this is the case then it could be the power adapter that is faulty or if it is underpowered and the thermal overload cuts in then it switches off and when it cools it switches back on again.
Check the monitors power specs and the adapter should match the power requirements of the monitor or greater (ie. the voltage should be the same but the current rating should be the same or greater).
Feb 10, 2009 | Dell Inspiron E1505 Notebook
Hansol H550 15" LCD Monitor Logo
56 people viewed this question
Top Hansol Computers & Internet Experts
k24674
Andre van Wyk
Andre van Wyk
Level 1 Expert
ray gallant
Are you a Hansol Computer and Internet Expert? Answer questions, earn points and help others
