Question about Microsoft Xbox 360 Console
How do you fix your xbox when it say's it had a problem with sining in
  • 4,102 Answers
Hi loads of people are having the same problem, xbox live must behaving some downtime or server issues if you was the only one then itcould be your end but in the last hour their have been loads of postsregarding this problem and all users are getting the same message.<br><br>try switching you xbox off and back on and if it still dont connectthen your going to have to wait i would try again in an hour or two,usually down time for the servers is a couple of hours while xboxinstall updates to xbox live, its not a problem your end so dont getchanging any settings, the problem is with xbox live so just bare withthem and it will sort itself out.<br><br>the last time this happened was about 6months ago and the downtime wasjust over 4 hours, so bare with them for a bit and it will be sorted.<br><br>you could try logging into the xbox site on the net and not throughyour xbox and check the xbox chat rooms and you will be able to findout more their.<br><br>let me know if you need further assistance ok<br><br>plz rate this solution as i have a whole page on unrated posts, thanks<br><br>goto www.xbox.com/support and it should tell you whats happening andabout any downtime they are having, you need to go to this site fromyour pc, have a look in the chat rooms this problem is with all xboxesso dont change any settings the problem is their end<br><br>plz rate this solution
Posted on Aug 31, 2010
Generator burning my electronics up
take you generator in and have the output tested for correct voltage and sine wave configuration
electronics rely on a perfect sine wave ac current as a manufactured sine wave affects electronic components such as capacitors, transistors and diodes
generator sets that run an alternator ( not an inverter ) have a pure sine wave and have less affect on electronics.
go google and type in search headings like ---sine wave, inverter sine wave, sine wave affects on electronics, alternator operation and inverter operations and then you may get a pointer as to why your inverter gen set is affecting your electronics
Jul 23, 2016 | Honda EU3000iS Inverter Generator
When ever i press sin^-1, and type in a number, the answer is always "domain error" on my ti 30x iis, how can I fix this problem?
Not quite true. (Explanation at the end)
The sine and cosine of an angle have values in the closed interval [-1,1]. That means whatever the value of the angle, its sine or its cosine cannot be less than -1 or greater than 1.
When you consider the inverse problem where you want to find the angle whose sine or cosine is known, you must take the values of the sine or cosine in the interval [-1,1]. That is the domain of the functions arc sine and arc cosine. So if you take a value outside the domain [-1,1], and want to calculate the angle to which it belongs, the calculator signals that there a domain error, because there is no angle that answers the question. Limit the arguments of the sin^-1 and cos^-1 to values in [-1,1]
For the inverses of arc tangent and arc cotangent functions there is no domain limitation because the range of tangent and cotangent is the whole real line ]-infinity, +infinity[.
Mar 30, 2014 | Office Equipment & Supplies
How do I fix the sin on my calculator?
It depends on the unit of measurement. The sine of one radian is about 0.84. The sine of one degree is about 0.017. The sine of one grad is about 0.015. From your numbers it looks like your calculator is set to grads when you want it to be in radians (and are you sure you want a negative number for the sine of one?).
Press the DRG key to cycle through the angular modes. One of the annunciators at the top of the display will light to indicate the current mode.
Jan 31, 2014 | Sharp el-531x scientific calculator
I'm trying to do inverse sine and cosine equations but I'm receiving a message that there is a domain error. Is there anything I can do or press like a reset button?
The inverse sine and cosine equations mean "angle who's sine/cosine is:" The bounds of the arguments for these functions must be between 1 and -1, the maximum and minimum values of the sine and cosine functions, because no angle can have a sine or cosine that is greater than 1 or smaller than -1. Also it should be noted that the inverse sine/cosine function is not the same as 1/sine or 1/cosine, although the symbol makes it look like that.
Mar 08, 2011 | Texas Instruments TI-84 Plus Calculator
When I type sin(6pi) in my calculator I get: 2x10^ -13 But sin(6pi) is normally 0. The calculator gives the right answer when in degrees: sin(3x360) = 0 How to fix this ?
The sine of 6pi is indeed zero. The calculator works with twelve decimal digits while pi is an irrational number with an infinite number of decimal digits. Thus the calculator cannot actually calculate the sine of 6pi, instead it calculates the sine of 18.8495559215. The sine of that number is close to zero but not quite, about 0.000000000002 which is what the calculator shows. This is a natural consequence of using finite machines to deal with infinite numbers.
In degrees, 3*360 is 1080 exactly and thus the calculator can produce an answer of exactly zero.
You'll notice that the calculator also gives a nonzero result for the sine of 4pi.
The "proper" fix for this is something called "argument reduction." If the argument lies outside the range of 0 to 2pi (or alternatively, the range -pi to pi), add or subtract multiples of 2pi until the argument is inside the range. So in this case, subtract 6pi from 6pi to get zero, then take the sine of that.
Bear in mind that argument reduction won't always work, since it too is limited to twelve-digit arithmetic.
Dec 12, 2010 | Texas Instruments TI-84 Plus Calculator
Hello is this ups a sine wave output or modified sine wave output. Thanks
The manual states when running on AC, it is the same sine wave ouptput that comes in. When running on DC, it is a modified sine wave.
Nov 30, 2010 | Opti -UPS BackUp-Time 525BT (UPS-525BT)...
I bought a new Black and Decker 200 watt power invertor to plug into our car cigarette lighter to power a laptop. We did this and our car blew a fuse. We went to Saturn to fix it and they could not...
Most power inverters supply a modified sine wave output. This is different from the true sine wave you get at home. It's close enough for many applications, but not close enough for many transformers, which is what your laptop power supply is. So the problem is that your laptop's power supply does not work with a modified sine wave input. Some will, some won't. Very common problem.
Aug 23, 2010 | Black & Decker Electronics - Others
Is true sine wave better than modified sine wave.
I'm not sure what the application is but I will offer the following. As a retired electronics engineer i can say for sure that a true sine wave does not have any harmonics in it. A modified sine wave will have some harmonics and other what I would call " trash content" depending on how it is modified.
Loringh
Nov 16, 2008 | Xantrex Technology RS400 Sine Wave...
How do I get my profile to sign in automatically when I turn my 360 on?
sign in then go to your profill by pushing the big X butin in the mitl of the controler it shud hav a gamerpik on the top clik on it go to the botum it will say sine in clik
Aug 12, 2008 | Microsoft Xbox 360 Console
Downloding from xbox live
yes now xbox live as a suffer my self with my xbox360 xbox live is broken right now some features have been screwed i rung them and they said it will be up and running properley in a week sorry but its out of all our hands if you need to contact me my email is mid.nightclub@hotmail.com
Jan 01, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
29 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
