Question about Vacuums
Model # zw5000y8 The air conditioner is less than 2 years old, and has leaking water from the from of the air conditioner. I contacted Home Depot where I purchased the item and the only advice they could offer was that there was something wrong. I purchased two of the same air conditioner and I havent had any issues with the other. Can someone please offer any advice on the reason that the air conditioner is leaking from the front and filling up with water, not the normal condensation, but filled.
SOURCE: leaking
what goes in the hole on the bottom of the clean water tank? I bought this on a yard sale and there is an open hole in the bottom of the water tank...if I only add about a pint of water and keep it tipped and get it onto the bottom tank really fast it works fine but I'd like to have what ever originally held the water in the tank
Posted on Jul 20, 2008
  • 190 Answers
SOURCE: water tank leaks
If the tank is leaking, when removed from the cleaner, it is not user serviceable.
Posted on Oct 03, 2009
SOURCE: i fill the hot water tank and it and it pours out
The tank is cracked under the plastic cover. I am on my second machine. The first one was cracked when I brought it home. I have maybe used the second one 20 timed and now it is leaking all over the floor. If you turn the tank over and look at where the pastic cover snaps on to the tank you will see some indentations to lock the cover in place. Both of mine machines tanks cracked there. It is kind of a poor design. It is a week spot in the tank. Hope this help.
Posted on Nov 24, 2009
SOURCE: Need Charger for Shark: Charger # KA12D090015023U
I've got one you can have. I just tossed my machine out today.
Posted on Feb 21, 2010
heatman101
  • 43501 Answers
SOURCE: my shark steam pocket mop
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
zx
Posted on Sep 24, 2010
Air conditioner sharp model af s125 fx a runs fine on all speeds but only blowa warm air same as what the room temp is any ideas, it is about 7 or 8 years old.
This kind of symptoms is caused by the following.
1. Faulty thermostat
2. Faulty compressor's OLP (overload protector)
3. Faulty compressor's starting capacitor.
4. Faulty compressor
This is not DIY, I would advice you to ask for an assistance of a technician to isolate the problem.
Have a nice day!
Thanks for using Fixya.
Jdvillanueva
Aug 22, 2011 | Vacuums
Nutone central vac shuts down after a few minutes of use
this is a very common problem.
If the unit is less than 5 years old and you have your bill of sale it will be covered by warranty. Although one of my customers said that there is a recall on the motor in this unit. That is totally unverified. However, if it is still under warranty, contacting broan/nutone will give you the closest warranty depot, or they may just deal with you directly.
I do recommend that both the motor and the PC board inside be changed.
Good luck,
Mark
Nov 07, 2010 | Broan-NuTone VX475 Bagged Central System...
I have a 11 yr old Hampton Bay ceiling fan with light kit. The pull chain to operate the fan broke (evidently inside of the fan) and I cannot figure out how to fix it. Do I have to take off the light...
I'm unfamiliar with your exact model but your description makes it very similar to the "King of Fans" branded models I fitted in my house twenty years ago and have fixed a few times. It might even be that yours are made by the same company as Home Depot source their Hampton Bay range from a variety of manufacturers including KoF.
You are entirely correct that you can access the pull chain once you have removed the lamp assembly. If it's just the chain which has snapped then it's normally straightforward to remove the short piece from the switch and install what's left onto the switch, but if your chain is the typical ball and link type and is more than a few years old then replace it with a new one if you can obtain the right size easily. They're not expensive, and the old one will have wear and tear making another failure highly likely. If either of the switches has failed (the pull switch or the fan direction switch) then they're also usually easy to obtain from any electronics store at low cost or you can contact Home Depot regarding spares, also check here and here. Your total repair cost should therefore be no more than a few £'s, $'s or whatever else you use locally: far cheaper and quicker than fitting a new fan.
I hope that my reply has been of use to you and saves you a lot of time and money. Please take a brief moment to rate my answer.
Oct 07, 2010 | Vacuums
I have a bissel 2x pro heat carpet scrubber it is not that old. It was working good now it won't **** up the water. What can I do to fix it?
Check the hose in the bottom. They get brittle and crack or get crimped it can be replaced easily with a piece of hose from home depot or lowes
Apr 02, 2010 | Hoover Floormate H3000 Upright Wet/Dry...
Steam leaking from water reservoir cap
Replace the O ring. Cut the clear one out with a razor blade and buy a standard black 3/4" O ring from Lowes or Home Depot.
Mar 26, 2010 | Tristar SB Steam Buggy Vacuum
I fill the hot water tank and it and it pours out of the tank onto the floor less than a year old used to work fine
don-I too have the same issue. I tore mine apart today and still don't know what the issue is...I have a Hoover Dual V...I'll let you know once I find the solution. Like you, mine machine is just at a year old.
Nov 15, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
Can not get the housing off
Remove the 4 screws on the bottom of the canister, and also carefully remove the water basin gasket. You will reattach the gasket with rubber contact cement when you're finished with your repair/cleaning.
May 05, 2009 | Rainbow Technologies D4 Bagless Vacuum
Oreck XL2 Ultra
I have the same problem and mine is less then a year old.
Aug 21, 2008 | Oreck XL Ultra Bagged Upright Vacuum
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
