Question about Linksys BEFSR41 Cable/DSL Router W/4 Port Switch, Retail Box (DSLSBEFSR41)
IP ADDRESS how can i get ip address from my router that i don't know be for? or how i can setting router to become default ip address?
  • serra baby
    serra baby May 11, 2010
    hello!
    if you want your router to go back to its default settings, try to reset the router. Try these steps on how to reset the router properly
    -- while the router is powered on, push the reset for 10sec
    -- still holding the reset button, unplug the power cable
    -- after 5sec plug the power cable back in then release the reset
    this should reset the router settings back to default.
    Your router is a dhcp server so if you connect a computer directly to the router, it will provide an ip address to your computer
    Novelist:
  • 144 Answers
Hello!
Checking the IP address of the computer allows you to verify if the computer is getting a valid IP address from the router. You have to check the TCP/IP properties of the Ethernet Adapter installed on the computer.
Finding the local IP address of a Linksys router is useful when accessing the router’s web-based setup page. This will identify what IP address to type in the Address bar, in case you forgot your router’s IP address. For instructions, please follow the steps below.
NOTE: Linksys default IP address is 192.168.1.1. The default Gateway IP Address of your computer is the routers ip address
Windows 2000/XP
Step 1: Click Start, then Run.
Step 2: When the Run window opens, type “cmd” in the Open field, then click OK.
Step 3: When the MS DOS Prompt appears, type “ipconfig/all” then press [Enter].
Step 4: Check your computer’s IP Address, Default Gateway and DNS. They should have the same first three numbers. It can be any number other than 169.254.x.x. The default IP Address is 192.168.16.x where x is any number from 100-149 and Default Gateway is 192.168.16.1. In this example, we used Local Area Connection.
Windows 98/ME
Step 1: Click Start, then Run. A window similar to Step 2 will appear.
Step 2: When the Run window appears, type “winipcfg” in the Open field, then click OK.
Step 3: When the IP Configuration window appears, select the Network Adapter or the Wireless Adapter that the PC is using from the drop-down menu.
Step 4: Check your computer’s IP Address and Default Gateway. They should have the same first three numbers. It can be any number other than 169.254.x.x. The default IP Address is 192.168.16.x where x is any number from 100-149 and the default Gateway is 192.168.16.1.
NOTE: If your computer is getting 0.0.0.0 or 169.254.xxx.xxx IP address you need to release and renew your IP address.
Posted on May 12, 2008
  • 39 Answers
I need to know a little bit of information. Could you please go to start>run>cmd. In the command prompt type "ipconfig /all" without the quotation marks. Please let me know the information displayed.
Posted on May 11, 2008
Need to turn on wifi for belkin router for desk top
Plug an ethernet cable from the router into the ethernetport of a computer and type in the router's ip address in the browser. For example the ip address will be something like 192.168.1.1
Once you have the correct ip address ( you can google your router'smanufacturer for the ip address if you don't know it), then the routers guiinterface will open up for you to configure the router. It will ask forthe user id and password. Most times this is the default password set bythe manufacturer unless whoever installed your router changed it. You canalso google your router's manufacturer for the default user id andpassword. In fact you could go to the router's manufacturer's website andlook at the manual for your router which will have the ip address, userid andpassword.
Once you are in the router you can go to the Wireless Settings and turn on the wireless and set a password for it.
Apr 20, 2012 | HP Compaq Presario SR5030NX (RX896AA) PC...
Hmm
Reset your router back to it's factory settings by holding the reset button for about 5 seconds. I have provided a list of the most popular router brands. If it does not work you may need to google what your specific model's default IP address/default username/default passwords are, for example search for "Encore ENHWI-2AN3 default IP address" The default login info can change, it can depend on where you obtained your router. If you purchased it yourself from a store then the standard defaults should work. If you obtained your router from your Internet Provider you may need to contact your service provider. It also may depend whether it's an old or new model router as well. And you may need to press and hold the reset button on your router several times before it actually clears. Make sure you have a wired connection then once you have accessed your router simply run the Setup Wizard. Set your SSID as something you'll remember like "Mavericks Network" and your Password can be something like your phone number for example 3109876543
Belkin - Username: Leave the field blank Password: Leave the field blank Default IP address is: 192.168.2.1
Buffalo - Username: root Password: Leave the field blank Default IP address is: 192.168.11.1
D-Link - Username: admin Password: Leave the field blank Default IP address is: 192.168.0.1
Encore - Username: admin Password: admin Default IP address 192.168.1.1
Linksys - Username: admin Password: admin Default IP address 192.168.1.1
NetGear - Username: admin Password: password Default IP address will be: 192.168.0.1 or 192.168.1.1
TP-Link - Username: admin Password: admin Default IP address 192.168.1.1
TrendNet - Username: admin Password: admin Default IP address 192.168.10.1
Zhone - Username: admin Password: admin Default IP address 192.168.1.1
Zyxel - Username: admin Password: 1234 Default IP address 192.168.10.1
Sep 08, 2011 | Belkin (F5D8231-4) Wireless Router...
Help me with my wep key please
Sep 07, 2011 | Belkin F5D8236-4 Router
Netgear router try to connect but saying validating identity wat can i do
Sep 07, 2011 | NetGear RangeMax WPN824 Router
Wanted to set password om my linksys
192.168.2.1
192.168.1.1
Sep 07, 2011 | Computers & Internet
How 2 put the password?
Sep 07, 2011 | SMC Barricade N Wireless Broadband Router...
When i try to install my Linksys wireless G, it ask for a password. I don't know it and it won't let me proceed!
Step 1:
Open a web browser such as Internet Explorer.
Step 2:
Go to the Address bar and enter your router's IP address ("192.168.1.1" is the default IP of most Linksys routers) then press [Enter].
NOTE : For WRP400, the default IP address would be "192.168.15.1" and if you place the router behind a primary router with the IP address of "192.168.15.1", then the router will automatically assume a new default IP address, "192.168.16.1".
NOTE: If the IP address of the router has been changed, type the router's IP address in the Address bar instead.
The router's IP address can be changed by:
1. Running the router's setup CD.
2. Changing it on the router's web-based setup page.
1. Check the router's IP address. For instructions, click here.
2. Press the Reset button at the back of the router for 30 seconds.
NOTE
: This procedure will reset your router to factory defaults. Any settings on the router will be erased. The router's IP address will be "192.168.1.1" and the password will be "admin".
Step 3:
A new window will prompt for a User name and Password. Leave the User name field blank then enter your router's password ("admin" is the default password), then click OK.
If you forgot the router's password you need to reset the router. For instructions, click here.
Nov 04, 2010 | Linksys Wireless-G Broadband Router
I am trying to set up a new printer to a Linksys router model no WRT300 Ver 2.0. I have lost my IP no and also my Network Security Key, Is there any way to retreive these nos Gordon Stephens
The router can be set to factory default by performing either of these two steps:
Resetting the Router Using the Reset Button
Resetting the Router Using the Web-Based Setup Page
NOTE: Pressing the Reset button on the back of the router for 30 seconds will reset your router to its factory default settings. All of the settings of the router will then be erased and the router's IP address will become 192.168.1.1.
Accessing the Router's Web-Based Setup Page
NOTE:To access the router's web-based setup page using Mac, click here.
Step 1:
Step 2:
If you forgot the router's IP address you can:
NOTE
Step 3:
Aug 21, 2010 | Linksys Wireless-G WRT54G Router
Wireless router won't connect to my laptop
1. check your network adapter TCP/IP settings if its set into "Obtain as IP address Automatically".
2. if the settings is set as Automatic and your not getting IP address then select "Use the following IP Address"
3. use IP address followed to your router address like if192.168.0.1 in router type 192.168.0.2 or192.168.0.3 just check the next address IP in your network.
4. after typing subnet IP will automatically set
5. type the router IP address as your default gateway
6. click OK to save your new settings
Hope this will help
Nov 24, 2008 | Arris WR850G Router (DHWR850G)
How do I use the Remote Management feature on my router?
Remote Management allows the device to be configured through the WAN (Wide Area Network) port from the Internet using a web browser. Step 1 Log into the web based configuration of the router by typing in the IP address of the router (default:192.168.0.1) in your web browser. The username is admin (all lowercase) and the password is blank (nothing). Step 2 Click the Tools tab and click the Admin button. Step 3 Select the Enabled button to enable Remote Management. In the IP Address field type in the public IP address you wish to manage the router. Note: If you don´t know the IP address or wish to allow more than one IP address to manage the router then put an asterisk (*) in the IP Address field. You cannot enter an IP range. Step 4 By default the port used to Remote Manage the router is set to 8080. Change the port number by selecting the down arrow next to the Port Number drop down menu. Step 5 Click on Apply and then click Continue to save the changes. To Remote Manage the router you will need to type in the Public IP Address of the router in your web browser along with the Port Number (separated by a colon) you selected in Step 4.
Feb 16, 2006 | D-Link Express EtherNetwork DI-604 Router
Linksys BEFSR41 Cable/DSL Router W/4 Port Switch, Retail Box (DSLSBEFSR41) Logo
614 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
