Question about Starrett T216XRL-1 - MICROMETER, DIGITAL
I replaced the battery on a 786 starrett blade mic and now the display works fine, but as I move the mic the display stays on 0.000, I was wondering if there is a reset or something that I do not know about?
Changing the location of the decimal point on digital Starrett Internal Mic's
im not too sure what your asking, all imperial starrett id mics read 3 place decimal you will have the inch number that is set by you for the job and then the mic gives you the next 3 numbers IE 4.250
Jun 06, 2014 | Starrett Measuring Tools & Sensors
Starrett no 731
Are you certain the battery is installed correctly? Many electronics won't work if the battery is installed backward/upside down. Do not ask how I know this....[-:
Jan 15, 2014 | Cars & Trucks
Shut down starrett 733
On some Starrett calipers, there is no way of turnig them off, which means about once a year you have to replace the battery. sorry
Jan 22, 2013 | Starrett Electronic Caliper
I have a Starrett 749 micrometer that will not power up I replaced the battery but still nothing
I have a Sterrett 733XFL-1 (O-1" Digital Mic). It turns out that these will only use the Renata Batteries. (Radio Shack Batteries are Renata and some Battery Stores Carry Them). The Renata CR2450 has a smaller diameter negative terminal (smaller diamter back half of battery). If you use an engergizer or other, the battery cover will short against the positive battery terminal and the tool will not work (and the battery will quickly drain being shorted to case)
Dec 16, 2009 | Starrett Measuring Tools & Sensors
I just aquired a Starrett 721 digital caliper that wouldn't turn on. Took cover off and batteries were in reversed polarity. New batteries didn't help. Is the display fried?
More than likely. But to make sure: check that new battery is good (voltmeter). Check with ohmmeter across the battery contacts - should read few hundred ohms to few kiloohms. If OK, reinseret battery. Push ON button. Push reset button. If go, congrats. If not, get another caliper.
Dec 07, 2009 | Starrett Electronic Caliper
Starret 734 Caliper will not power up
OK, I fixed it! After hearing back from Starrett, it seems that a RENATA battery is the only one that fits right. I went out to Radio Shack and checked their stock, which turns out to be manufactured by RENATA. The new battey works fine... It did take a try or two to get the display cleared, then Error04, now it's working again.
--David--
Mar 25, 2009 | Starrett T216XRL-1 - MICROMETER, DIGITAL
Micrometers out of calibration
Micrometers must be calibrated at 4 spots around the barrel and at zero and full scale to be truly accurate. You will have to send it to a calibration lab or back to Starrett for a full calibration because they will check it with gauge blocks of known length and verify the spindle and anvil surface flatness.
If you are only concerned with the zero and not as much about the full accuracy of the tool, then you can reset the zero yourself. With the mic fully closed (spindle and anvil touching), turn the barrel with the funky, half circle shaped wrench that came with the mic in the box. There is a little hole in the barrel where the nub on the wrench will fit then you just turn it until it reads zero. Good luck.
Mar 07, 2009 | Starrett T216XRL-1 - MICROMETER, DIGITAL
Starrett T216XRL-1 - MICROMETER, DIGITAL Logo
55 people viewed this question
Top Starrett Measuring Tools & Sensors Experts
ray gallant
Mark Schmit
Mark Schmit
Are you a Starrett Measuring Tool and Sensor Expert? Answer questions, earn points and help others
