Question about Dell 922 All-In-One InkJet Printer
I have put in a new printer cartridge but sometimes the page has places that don't print clearly or they are too light - one page may print fine and the next will have a few words that aren't readable. thank you!
    President:
  • 2,571 Answers
You need to use the built in printer tools, use the head clean function, and also align cartridge
Posted on Aug 31, 2010
My Brother HL2140 printer was running fine and all of a sudden the toner light is on and it stopped printing. Just yesterday when i printed out the status for the drum and toner it showed more than 80 %...
636 is a lot of pages and depends on the toner coverage you may need to replace the toner.. 80 - 75% (is that used is remaining ??) any way check your waste toner basket first (see you manual for instructions) chances are its filled and needs cleaning or replacing (see your manual for instructions) If its fine then change your toner .. If you have the demo toner (toner shipped with machine) these contain less toner than a new cartridge and will finish faster ...
Jul 26, 2010 | Brother HL 2140 Laser Printer
Problem with printing in black writing not clear and very faded.
It sounds like you need to run a printhead cleaning. The print head is what you put the ink cartridges into, it's responsible for placing ink directly to the page. If the some of the nozzles are clogged up, it can give you bad print quality. Without knowing the exact model of your printer, I can't tell you exactly where to find the menus needed to run the cleaning. Sometimes you can do this via the "maintenance" tab in the printers properties. If you need any further assistance, feel free to let me know.
Jul 30, 2009 | Brother Office Equipment & Supplies
DELL PRINTER A920 PRINTING IS BLOGGIE
Hi! Your problem is your printers INK CARTRIDGE alignment, make sure that your printer ink cartridge is properly aligned. Or try to clean your ink catridge. GOOD LUCK. THANKS
May 06, 2009 | Dell Inspiron 1000 Notebook
Alignment of cartridges
To align the cartridge from the control panel:
Please follow the steps given below:
1. Please Load a plain paper.
2. Press and hold the "Scan" button for three seconds.
3. An alignment page prints.
4. Place the alignment page onto the scanner glass.
5. Press the "Scan" button.
6. Once scanning is complete, the cartridge has been aligned for optimal print quality. Alignment must be complete before continuing with any print jobs.
Apr 17, 2009 | Lexmark All-in-One Printer with PictBridge
Brother HL2070N printed 1 page fine,then nothing but light streak
turn off printer, remove cartridge and drum and clean internally.
reinstall drum and cartridge and do a test print, hopefully all will be better.
Jan 18, 2009 | Brother HL-2070N Laser Printer
Canon pixma mp780 printing problem
If deep cleansing via software doesn't work then you've got to manually clean your print head unit. Sometimes you'll have to bite the bullet and get a replacement print-head unit ($$). If you're at the stage that you're considering replacement, then you've got nothing to lose by cleaning the print-head unit yourself. It's simple. Remove all ink cartridges first then remove the print head itself. Place the print head unit in a saucepan of warm (NOT boiling hot) water and leave to soak for an hour. (Protect your clothes - it gets messy) After an hour, flush the printhead unit under a running tap. Don't run the water too fast or you may damage the unit) You should flush until the water runs clear. Do not attempt to clear the nozzles with anything other than water - they are very fine needle jets and you will damage them!! If needs be, return to saucepan and leave to soak in warm water again and repeat process. When you are satisfied that the printhead is clean, you need to dry the unit thoroughly. Shake as much water from it as you can then pat it gently dry. Next place it on some absorbant kitchen paper and put the unit in a warm place to thoroughly dry (Overnight in a warm airing cupboard would be good). Once dry, refit the unit put in (Preferably new - but I've used existing one's without problem) cartridges and run a cleaning cycle. Your printer should now work as if new!!! - In Most cases!! - sometimes though, you'll either have to replace the print head unit - which sometimes can be more expensive that simply replacing the printer. What have you got to lose though eh? CLIVUSS
Mar 26, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Just started printing blank pages
you may need to prime the new cartridge by "charging it" if you go to printers/faxes menu then select "printing preferences" and clcik on the maintenance tab you should have the option to do this also to reset to default settings.
Jan 08, 2008 | Canon imageCLASS MF6550 All-In-One Laser...
Faded print on one side of page
I have a SCX-4100 Samsung, replaced the tonger cartridge, it was working fine for a few hundred sheets of printing, but after that, the left side of the page was printed very light, faded.
If I run the "Clean Drum", it will print a litter better, but still faded.
What can I do to correct this problem?
Thank you
TT
Nov 24, 2007 | Samsung ML 1710 Laser Printer
Dell 922 All-In-One InkJet Printer Logo
27 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
