Question about Microwave Ovens
Instruction manual for pyrex - vitri micro-dur
Can I freeze a cooked apple pie in a Pyrex dish
Yes Pyrex should be tempered so, it will not hurt pan
Sep 06, 2017 | In Microwave Ovens
Can visionware go in oven
The short answer is YES!
In the 1990's Corning produced a series of Visions cookware, brown amber and cranberry colored glass-ceramic dishes and casseroles, that had the same basic properties of its white Pyroceram cookware. Visions cookware could go directly from freezer to hot oven to stove-top to the microwave oven to table to fridge to the broiler to the dishwasher, etc. Extreme temperature changes did not affect the very durable cookware, While many folks mistake Visions cookware for Pyrex bake-ware, they are not the same. Visions cookware was never issued in the forms (square pans, rectangle baking pans, loaf pans, pie pans, etc that clear glass Pyrex baking pans had been produced in for decades. In any case, Visions glass-ceramic cookware could go direct from the freezer to the hot oven - there would be NO DAMAGE to the cookware in such a practice. Visions glass-ceramic cookware also has markings to indicate usage. The majority of Visions cookware were of the "stove pot" design - stove top was intended from the start. However it is practical to let the food defrost first, or adjust the cooking time in order to create a better thoroughly cooked dish.
Yes, Visions cookware can be used in the oven! One caveat is that the pot lids are Pyrex which means that the pot lids can not be placed under the broiler (who does that anyway?), or under direct heat, or while hot on wet surfaces. The pot lids were meant to be pot lids - just like other Pyrex glass pot lids on most cookware.
Apr 17, 2014 | CorningWare Microwave Ovens
Need instructions on cooking times for steaming veg
On a 1000 watt oven, I find 7min about right for most vegetables. Those which need more cooking may require 10min or more.
Apr 14, 2013 | Pyrex Pyroflam Steamer Set, 2L
I want to bake a salmon loaf in a glass loaf pan in my Jen Air mincrowave/convection oven. The 4 pg. instruction manual does not give me sufficient info. In fact, there's onloy a half page relating...
I have a Panasonic Convection Micro. Yes, If you are using convection you can use metal pans. Microwave energy cannot pass through metal pans so that is why it is not good to cook in them. It could also cause arcing or reflect the microwave energy bak to the mag and over heat it. So, when possible use corning ware or Pyrex when using the microwave
Aug 17, 2017 | Jenn-Air JMV8166B 950 Watts Convection /...
Instructions for panasonic micro oven browner nn 605
Most major manufacturers supply manuals online so if you were to log on to the manufacturer's web site, you may be pleasantly surprised as usually, if available, one is able to download, by model number, Customer Instruction Manuals, Dealer Network for spare part supplies as required.
The information is normally free of charge.
I hope this helps.
Mar 14, 2011 | Panasonic Microwave Ovens
Light inside micro- went out
You can download GE owner's manuals and installation instructions here.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
May 31, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Instruction Manual Needed
The only ref online is http://www.espares.co.uk/parts/microwaves/proline/micro-chef-st22/p/1095/1169/0/542092
Any microwave cooking guide should walk you thru the steps
Jul 28, 2009 | Microwave Ovens
Can't remove the vent grill
Two problems found. The electrician that installed the micro. installed it incorrectly. The fan was supposed to be turned so that the exhaust would go through the pre-installed duct in the wall. To remove the grill, there is two screws on top of the micro. which have to be removed. The builder put in a deeper cabinet that covers the screws because it looks better. To fix it I have to drop the micro, take off the grill, clean it and all the grease off the micro., replace the charcoal filter, turn the fan so it will exhaust through the duct and reinstall the micro.
May 27, 2009 | Kenmore 80412 Microwave Oven
I need mounting instructions for frigidaire model plmvz169gcb
You can download Frigidaire owner's manuals and installation instructions here.
Jan 02, 2009 | Frigidaire PLMV169DC Microwave Oven
Microwave Ovens Logo
196 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
