SOURCE: Program bell expressvu remote for new tv
The easiest way is to do device code scan. Since you want to program the TV, hold the TV button on your bell expressvu remote. When all the top buttons light up, press the power button, the TV button light should remain lit. Keep pressing up/down until your TV turns off. When your TV turns off, press the # button. Thats all. Your done.
If you want to set up the AUX button, hold the AUX button until all the buttons light up. Then press * and either
0 - second TV
1 - second VCR/DVD player
2 - audio amplifier or cable box
Then press the power button and press up/down until the device turns off. The last step is to press # and your done.
SOURCE: bell express vu remote codes for soyo tv
1 - Hold the clear tv buttom until all 4 light flash red
2- Press the red tv buttom
3- Press the amount of time needed on the up cursor ( around select buttom) until your tv shut down
4-When the tv goes off press the search buttom ( at the end on the right side )
5-Press record
Then u can use the red tv buttom to control ur tv and u can control the volume on satelitte mode without going back to tv mode , if u press too much time while searching the code and the tv wont light back , do the same thing but instead pressing the up cursor press the down one to go back on the code it will be faster .
SOURCE: I need an service manual for ACER LCD TV, Model
Hi, the truth is thi, the service manual for your TV is available, but it's available for free.
You will need to purchase it..
Use the link below to download...To be ableto download, you mightneed to register pay a small amount for the service manual..Hope you like that
http://www.nodevice.com/manual/newmans/acer/SG_AT3205_2605_ALLzip/get48182.html
And hope it helped..
