YouTube Videos Logo
Posted on Aug 31, 2010
I can get sounds,music and so on,on my computer for some reason I cannot get sound on You Tube video's,can you help?
Anonymous
Level 1:
New Friend:
  • Contributor 44 Answers
  • Posted on Sep 02, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
44
Questions
0
Helped
6015
Points
82
May be ur system volume is muted... or if other music sounds of ur pc are playing... den when u play a video in youtube go to right hand corner of the video where u get the volume control of the video. unmute that... or increase its volume...
Popping sounds only during video/ you tube on tv from my computer.
Because of the amount of voltage required to run the older-style "tube" televisions, many problems, sounds and noises occur in tube televisions than in the newer, flat-panel televisions. Sounds occur for multiple reasons, with some being just part of the normal process these televisions run through in order to operate. On the other hand, some of these noises may indicate a problem with the television that could warrant repair.
Worn Insulation
Voltage against metal. Inside your television's tube, there are many wire parts that electricity runs through in order to make the television run. Usually, these parts are insulated with a rubber or foam casing that prevent the sound of the electricity. If the insulation surrounding these components is thin, weak, worn or absent, you are bound to hear buzzing, popping and cracking sounds coming from your television. While this may not mean you have to run out tomorrow and get a new one, the chances are that your TV's tube is working extra hard to make it all happen for you, and you may want to start pricing new sets for the near future. b> Static During Warm-Up b> Just like rubbing your feet on a thinly-carpeted floor can cause static electricity, the same can also build up inside your television. If the noise is relatively subtle, only occurring when you first turn it on, and not overly-disturbing, the chances are that the cracking and popping sounds you are hearing are just the television's way of warming up and getting rid of the unnecessary electricity. Bad Lamp b> Deep inside the heart of your tube television, there is a light-bulb fixture that makes the entire unit light up so that you can see a picture. If the cracking and popping sounds you are hearing tend to go along with the picture on the TV becoming unclear, it could be that the picture tube is failing. It is very difficult and costly to replace the picture tube on a tube TV, so this is an instance where you may benefit more from buying a new television than taking the old one in for repair. Hope this helps.
I can't get the volume on my computer and it has speakers
Hi If you have sound other than in videos that you are streaming from the net ( you tube) it maybe a problem with your flash player software it may need to be updated. google Adobe Flash player.
2helpful
2answers
To day i tried to get more bass on my laptop and i dont know what happed but when i try to use you tube and other music websites it does not wor
Hello
How does the bass respond when you listen to a audio cd? You tube is hit or miss with good sound.Most videos on you tube have crappy sound.Since alot of them are not mixed and have been downloaded and uploaded from someones vid cam or cell phone.
Try downloading and installing adobe flash player,the latest version.It may help
Lost gain on a jackson 50 tube amp. Only slight sound comes out?
Could be any number of reasons. Most likely is a blown speaker. Next likely is a blown tube. Check these first.
If it's still not working, find a qualified amplifier technician.
Hope that helps!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/cameron_463100ffd54b591d
Feb 09, 2011 • Music
3helpful
FREQUENT START AND STOP DURING THE PLAY OF VIDEO
usually this happen when you have slow broadband connection and video is need more speed then your broadband connection speed if you have 512kbps internet speed you do not have to wait this long to watch video on you tube. check your internet connection speed for you tube video.
This will help. Thanks please keep updated. please do rate the solution positively .Thank you for using Fixya
Regards
manish
Hello, I have the MIDI kit and it is pluged in, how do I get the music to the keyboard or keyboard music to the computer? I want to recoard some music for singing, please help. Thank you, Princess
In Device Manager (I am assuming you are using Windows XP) you will find your MIDI devices under Sound, Video and Game controllers. It is possible that the MIDI port has not been enabled in BIOS, I have had some PCs where this had to be done first. If Fruity Loops doesn't give you any available MIDI port to use it does not sound as though the PC knows it's there or has installed the driver properly. Start in Device Manager - if there's no MIDI port there or it's not working for some reason you'll have to fix that first.
1helpful
No sound when playing video
hi bearly,
this may be due to codec issues, there are special video and audio codecs needed to give sound to webbased films and videos.
try downloding k-lite codec pack or xp-codec install, reboot and try to access youtube again!
good luck
The sound on my gateway skips...lllamp...viddddeo...yestttttday. help!
is the video loaded completely? do you have a slow internet connection?
the pause/skip is because the playback program doesn't have data to play. Does your pc have enough RAM? are you on cable internet?
No sound
Just reinstall ur sound drivers again ... it will reset it to default!!!
Lost sound please help
remove / uninstall the drivers from the control panel (device manager) reboot and let the computer reinstall the correct drivers.
Top YouTube Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Andrew Chrostek
Andrew Chrostek
Level 1 Expert
 Grubhead
Grubhead
Are you a YouTube Computer and Internet Expert? Answer questions, earn points and help others
