Question about Ryobi Backpack Blower 25.4cc
Where can I get the special tool to adjust the jets on the carb.
  • 3,740 Answers
The special toll your looking for is a thin bladed screwdriver. Some carbs have and idle and a "H" (high) adjustment only Others have third setting for "L" (low). The adjustment for idle (top of carb) is a personal judgment call but it should remain running at a low RPM. The adjustment for "H" Is done with full throttle and to the pint that it just does run at full speed without missing. DO NOT set it too lean (clock wise) or you will end up with a short lived blower. As far as setting the "L" speed (on models so equipped) you dial that one in by allowing the unit to idle then rapidly accelerate the engine to full speed. If it hesitates you turn it no more than 1/8 th turn each time and keep repeating the accelerate to full throttle rapidly routine until the hesitation stops. A few of these models have a plastic cover over the "H" adjustment screw. On some of them you can do about 1/4 turn with the cover installed but have to pry it off the jet screw head if further adjustment if required.
Thanks for choosing FixYa.
Kelly
Posted on Aug 31, 2010
Engine runs on choke but dies without?Special tool to adjust hi /lo carb settings?
Your main jet in carburetor is fouled and needs to be cleaned out. The choke circuit bypasses it but when you remove the choke the gas is supposed to go into engine via the main. If clogged, the engine will quit for lack of fuel.
Either clean the carb and jet or replace carb. And yes, newer carbs have basically non a adjustable jets which is ridiculous since each engine is unique and has to be properly matched to new carb. Way around this is by either buying the special tool (he-- with them) or using a dremel tool to cut into head of adjuster a slot so that you can use a regular flat blade screw driver to adjust.
Oct 27, 2015 | Ryobi Garden
Where do i find idel jets in carb on a poulan2150 2.1C.I chainsaw
The jets will be under alluminium core plugs, special tools are required to remove them, this should be left to a chainsaw shop as with the wrong tools the carb body can easily be damaged.
Jul 21, 2013 | Garden
How do I adjust the pilot jet screws on a yamaha xv920 model 1982? How many turns should I turn open the pilot jet adjustment screw?
Carb work is for the pros. This may or may not be your trouble. Before you damage your very expensive carbs, take your bike to the pros. They have the special tools and expertise to set your carbs for maximum efficiency, safety and performance.
Nov 29, 2012 | Motorcycles
When cutting and after letting off throttle saw runs for maybe 10 seconds and then stalls. Have to constantly restart because will not continue to idle. Runs fine at full power just will not idle for any...
The carb may well have anti tamper sleeves on the jet screws, or will need a special splined tool to adjust them, the tool is part no. 530035560, if there are caps you will have to gently screw a self tapping screw into the end, when it hits the head of the screw behind it will draw off, you only need to adjust the L screw, i would suggest turning out 1/8 of a turn to richen it up a little.
Jun 26, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Husky 125B blower, new right out of the box. starts, runs about 30 sec, bogs and quits. I'm guessing likely needs carb adjustment, but set screws are not regular slotted screws. Looks like it requires a...
My name is Dane and I am going to assist you in solving your problem.
You will need to adjust the high speed setting on your Carburetor jet. Turning the screw out just 1/2 turn or so should do the trick. It is not so hard to adjust the Carburetor, however, yes you do need a special tool that is very hard to get your hands on, in order to adjust the jet screws. They don't make many engines with plain screw heads anymore. The newer Carburetors are factory set lean so they can pass emission standards. Since you just bought yours, a local husky dealer should adjust the mixture for free. I hope I've helped. If you found this reply useful, please leave me some THUMBS UP, if you feel I
Dec 09, 2010 | Husqvarna 28cc Hand Held Blower HVH 125B
Flymo Turbo Compact 350 - no power when safety button and lever pressed
You will need to adjust the high speed setting on your Carb jet. Turning the screw out just 1/2 turn or so should do the trick. It is not so hard to adjust the carb, however you do need a special tool that is very hard to get your hands on, in order to adjust the jet screws. They don't make many engines with plain screw heads anymore. The newer Carbs are factory set lean so they can pass emission standards. If you have a local dealer they should adjust the mixture for a couple of bucks.
Before you take it in though, make sure you haven't left old fuel in it for a long period of time and gummed those jets up. Sometimes they just need to run in order to clean the jets out. If this is the case, just replace the fuel and get it running and work it normal for a tank of fuel if you can.
I hope I've helped. If you found this reply useful, please leave me some THUMBS UP, if you feel I've deserved them. Thank you! Dane
Dec 06, 2010 | Husqvarna Garden
How do adjust the carburator? trimmer bogs doen at high speed.
My name is Dane and I am going to try to help you solve your problem.
Well, it is not so hard to adjust the carb, however you do need a special tool for the carb jet screws, that is very hard to find. They don't make many Carbs with plain screw heads anymore.
The equipment anymore is factory set lean so it can pass emission standards. If you have a local dealer they should adjust that out for you for a couple of bucks.
I hope I've helped. If you found this information useful, please leave me some THUMBS UP as deserved. Thank you! Dane
Dec 05, 2010 | Garden
24cc craftsman 2 stoke trimmer. took apart everything and cleaned. new fuel lines. cleaned air filter. ran fine saturday. now sunday bogs out while trying to throttle up or just stalls.
Low side adjustment on the carb needs to be opened up or the carb needs to be overhauled. To open up the low sie, find the carb jet adjustment screws. The screw closest to the cylinder is the low side. Turn the screw counter-clockwise 1/2 turn. You may need to romove tho plastic locks from the adjustment screws, or if it is fairly new, you may need to buy a special tool to use on these screws. The tool is available anywhere that sells Poulan parts. If adjusting the screws doesm't fix it, the carb will need to be overhauled or replaced. Check with www.searspartsdirect.com . Replacement carbs are sometimes cheaper than an overhaul.
Aug 30, 2010 | Craftsman 25cc Gas Line Trimmer
My 32cc starts right up but as soon as i give it gas it stops...help
The low side carburetor adjustment screw needs to be turned counter-clockwise. Start by turning it 1/4 turn then test run. If your carb has plastic locks on the screws, they will have to be removed first. Most modern carbs require a special tool to adjust the jets. The tool can usually be purchased from your local repair shop.
Aug 23, 2010 | Craftsman 25cc Gas Line Trimmer
My trimmer runs on chock give it gas and it dies will not rev up is there a special tool to set the carb ?
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
There is no special tool to use on the carb, just a screwdriver to adjust the jets back to normal position.
Please rate me, Thanks
Good Luck, I hope this helped
May 13, 2010 | Craftsman 25cc Gas Line Trimmer
Ryobi Backpack Blower 25.4cc Logo
322 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
