Question about HP Compaq Motherboard
Hp Laptop as u switch it on 10 sec later you get one long bleep and two short bleep that's it the fan still works the lights across the top of key board a lite but screen stays black and that's it nothing more
  • 916 Answers
SOURCE: Screen goes black after windows XP logo, then no response.
I would suggest checking your hard drive to see whether or not it has a bad sector on it.
Posted on Dec 20, 2008
SOURCE: one long beep, two shorter beeps - HP laptop will not start up
Hi...
I had the same problem...
The solution is only temporary and you will have to reapply it after around 5 to 6 boots cuz it'll just happen again (the beep syndrome).
Just heat up the laptop by turning it on and covering its air vents with your hands.
Then after you hear the beeps turn it off.
Turn the laptop on again and immediately turn it over upside down with the lid closed ofcoarse (simply put it on its back).Hopefully you wont hear the beeps and when you open up the laptop lcd...voila display.
Posted on Apr 13, 2009
  • 5 Answers
SOURCE: I have a HP pavilion Entertainment laptop and
the problem is with the screen HP has used the cheapest lid swithes available in the market therefore it is offering a two yr extended warranty to all its customers. try HP website or call hp helpline.
Posted on Aug 07, 2009
bhagyavichar
  • 414 Answers
SOURCE: laptop turns on but screen stays black
probably itz either minor case of software corruption/improper ground/cpu fan..
or major case of faulty or defective main board/ram/addon/daughter cards..
..plz do check the following as in order:..
the Hardware part:..
1)a) in power-on mode, open/unplug the data/vga cable of the monitor from cabinet..see if raster or 'osd' is appearing on the monitor screen..if so monitor is ok..else replace the monitor and see..[not applicable in case of laptop]..
b) in case of laptop try to get output from external display unit/monitor using vga port..if there's proper display in there..the problem is probably with either the 'lcd' or 'ccfl' or 'inverter circuit'..
2) if u hv a graphics card, replace with a standby or onboard and see..[not applicable in case of laptop]..
3) unplug mains supply..pick open/remove the cmos battery..check (above +3v)..resit..
4) see if the ram(s) is loose/faulty..open clean/remove carbon & or oxide formed on the teeth with an eraser n resit it..or replace with a standby n see..
5) a) see if ur hdd is noisy or emitting any 'ticking' noise (like 'tuk tuk' or 'kirr kirr')..
b) or if the system is not supporting either the newly installed device or itz software/driver /firmware
if so, u need either a fresh os installation or ur hdd is likely to b replaced..
6) remove/clean dust neatly..dust is non-uniform in nature n may cause jam/short circuitry/excess resistance n many more..resulting an increase in heat..
7) open the CPU Heat-Sink with fan out of the socket..put some "Heat Sink Compound" (available in local electronics chip level spare market)between the cpu/processor and the CPU Heat Sink *** fan..resit/fit it tightly in position..
8) on main/mother board..see with a debug card for mb error..may b short..look for defective capacitors(espabove1000mfd)/mosfets..go through the mb's south bridge n the circuit lie around atx connector..the crystal clock generator (if cpu isn't heating up)..
9) [in case of desktop] the smps itself may b defective/faulty..check the outputs of smps viz. 0v (black~ground); +12v(yellow); +5v (red, green~ps-on, violet~pg& grey~sb); -12v (blue);-5v(white); +3.3v(orange)..the 'oscillator and error amplifier ic',or pwm switching regulator circuit..look for defective protector-transformer/resistance (esp 4.7k)/mosfet..
check the battery n adapter [main power], in case of laptops..
for any further assistance u may plz leave comment and or testimonials at any point of time, so that i/we can help or u think it to b helpful..
if u r not a professional, always better to seek advise from ur system admin/vendor....
Posted on Nov 23, 2009
  • 120 Answers
SOURCE: black screen on booting my Compaq 610 notebook
If it seems like you're accessing the hard drive (drive light comes on, flickers intermittently, then goes off, it's a good chance your screen is bad.
First thing to do is plug in an external monitor and start up the laptop. If it comes up with windows, you know it's the screen.
To find out if it's the backlight, or the lcd, toggle the monitor function and shine a flashlight on a slight angle to the screen. If you can faintly see what was displayed on the external monitor, then the backlight inverter is probably bad.
If the external monitor didn't come up, you're probably looking at a motherboard.
The good thing is that all of those are covered for one year under Compaq's warranty, on a new machine.
If you are able to use the external monitor, back up your data, because HP/Compaq usually reformat the harddrive. Additionally, if you've added memory, pull the cards. They want it sent back the way it came from the factory.
Posted on Jan 09, 2010
Laptop automatically turns itself off
could be over heating,can you hear the fan running?
if not the way I clean my laptops is get the hover and put it at the side were the fan is and try and clean out the fan that way.
are you still getting any lights on your laptop?
if it only runs for a short time then switches off then I would chech the fan.is it bleeping when you turn it on?,if so check your ram.
check hdd.
Oct 29, 2016 | Computers & Internet
Remove c-24 errorminolta di450/500
Sir/Mam,
C0F24 Code is the code for the sensor that monitors the drum. I would remove the drum cartridge two black screws pull out the drum assy. Remove the drum be careful do not nick or harm the drum the sensor is located on the left side of the to the rear of the of the drum looks like to little eye of a bug. Dust with a brush NO VACUUM static could destroy it. Re-install drum and re-install cartridge. When the last time a PM was done Developer replaced and Drum replaced?
Dec 14, 2014 | Minolta Office Equipment & Supplies
At switchon the mother board bleeps continously for about 10 secs takes a break 5 secs then goes bleep again for another 10 secs and repeats the cycle reapetedly until switch off. All drives have been...
It is a very real possibility as there are no beeps when it is removed, but that does not mean it is faulty, you could be getting POST beeps suggesting there is a fault with the mainboard, have it checked out with a local & reliable engineer who may be able to solve your problem.
Keith.
Aug 06, 2017 | Intel Server Board SE7501CW2 Motherboard
My ps3 will not turn on... when I start up by pushing the power button I can hear the fan turning on, it boots on, and then turns off a few seconds later. any advise would be greatly appreciated.
hello, try resetting it, turn on the ps2 press and hold the standby on the front of the ps3 you will hear 1 bleep then 2 short bleeps after the short bleeps release the button it should reset
regards
shaun
Nov 21, 2010 | Sony Playstation 3 (PS3) Console
When i press power, lights and fans come on for 2 seconds, shut sompletely off, then about 10 seconds later, they do the same thing, over and over again, but the computer will not turn on/boot
take out the battery and the mains, hold the on button for 30 sec's, plug the mains back in while holding the on button and it shud *** on... put battery back in when fully loaded up....
Happened to a friends hp laptop and i found this simple fix, should work...
Gerard
Jul 29, 2009 | HP Pavilion DV6700T Notebook
F&P Smartdrive 058 filling in short bursts then stopping.
I had the same problem today. shephonos 18 had the correct diagnosis. Out of balance micro switch seized. Situated under the main circuit board. Cherry electric Corp 0.1amp 125 volt sptd type switch. jaycar has them for under $4.
I un-seized it with some electrical cleaning spray, fixed itshort term, no worries.
Thanks Stephanos 18.
May 04, 2009 | Fisher and Paykel Fisher & Paykel Washer
Hello! I have an Hp laptop touch screen Tx1016AU, earlier my wifi would not be detected and later in next 3 months my laptop wont start When I switch on the power switch it blink for 1 sec and then goes...
this is called the black screen of *****
but you failed to say if BIOS is dead. too.
is it? BIOS even runs with the HDD removed, and MUST.
be nicer to say in detail only what happens with power button pushed, battery out.
it can do many things right and wrong,
only one word here matters (pair) GOES OFF.
that is a bad power pack.
why not replace that first,. and for sure if you can not reach and hold BIOS screens.
old notebook with Vista 32 I bet. is it?
as old as 2008 made, and supported.
the line power pack, get a new one. 19vdc is HP normal power.
packs go bad, its common,
and is like $15 fix. unlike fixing the dead PC, in a shop for $300
or more.
why delay for such low, cash? ?>?????
  1. bad power pack
  2. CPU overheating in 1sec, and auto shuts off.
  3. mobo regulators bad. or shorts on there bus lines.
  4. others, many.
your symtoms are POWER FAILURE
a pc that does not turn on is that.
but can be more complex it is after all a computer.
every way possible is here, and more. lots more.
your PC has flash codes, the keyboard LED flash. a code
if yes, they MATTER FIRST.
http://pcdied.com/black-screen.html
Jun 11, 2017 | HP 12 x 10/100Base-TX - 2 x Expansion Slot...
Scooter motor does not operate
are you sure its in gear. I had the same problem and I pushed the nob on top of the motor towards the front of the machine and it worked!!!
Apr 03, 2009 | Health & Beauty
Switch laptop on , bleeps twich and then does nothing
Two beeps - problem with RAM.
Try to reseat it or replace.
Mar 26, 2009 | HP Compaq nx6110 Notebook
HP Compaq Motherboard Logo
18 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
