Question about SAMTRON 55V 15" CRT Monitor
Monitor SEttings What are the best settings for a 20.1 LCM - 20V5 Westinghouse monitor.
I cannot get 32bit color or what i can do for get 32bit color
Posted on Jul 20, 2008
    Guru:
  • 859 Answers
Probably 1280 x 1024 at 32bit color depth assuming those are the settings you are asking about. If not, please be more specific with a follow up post.
Posted on May 10, 2008
My Westinghouse LCM 19v5 will not powerup
Look for bad caps with bulging tops, similar to the 19" version as shown here:
http://s807.photobucket.com/albums/yy352/budm/WESTINGHOUSE/Westinghouse%20LCM-20V5/
Make sure to use correct type caps for switching power supply.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Oct 21, 2011 | Westinghouse LCM-19v5 Monitor
The screen goes on for a second and then turns off. If I then turn the power on and off numerous times it eventually stays on. I put the screen off to 60 minutes. Every time the screen is allowed to turn...
Hello Geoff,
The problem you are having is caused by a power supply board that is failing. Your monitor uses the Delta DAC-12M033 power supply board. We have a repair guide for the Westinghouse LCM-20V5 monitor that uses the same power supply board posted o our web site at: http://www.ccl-la.com/blog/index.php/repairing-the-westinghouse-lcm-20v5/ Check out the web article, it should get you back going again. If you don't want to do the repair yourself we do offer a repair service. We can get deatils on this service here: http://www.ccl-la.com/blog/index.php/service-request-form/
I hope this helps, if so please rate our solution.
CCL Tech
Corporate Computer
www.ccl-la.com
Oct 26, 2010 | ViewSonic VG2021m LCD Monitor
My Viewsonic VG2021m Monitor recently cut out every 5 or so seconds (the display came up and then went off) again and again and now it seems as though i cant turn it on at all even though the blue on light...
The intermittent image, dark picture or no power are all indications of a failing power supply. If you can solder you should be able to repair your monitor. We have an article posted on our web site at: http://www.ccl-la.com/blog/index.php/repairing-the-westinghouse-lcm-20v5/ The post is about repairing the Westinghouse LCM-20V5 but they both use the same power supply board, the Delta DAC-12M033 so the information is the same. If you don't want to do the repair yourself we do offer a repair service for this model for $32 plus return shipping. More information on this service can be found here. http://www.ccl-la.com/blog/index.php/service-request-form/
I hope this information helps, if so please rate our solution.
CCL Tech
Corporate Computer
www.ccl-la.com
Sep 19, 2010 | ViewSonic VG2021m LCD Monitor
After pressing the power on button it starts to turn on but then makes a hissing sound and goes into standby mode. It takes several attempts before the screen wont make the hissing sound and finally stays...
You have a monitor with a failing power supply. The Viewsonic VG2021M monitor uses the DAC-12M033 power supply board. After several years of use the capacitors in the power supply start failing and not keeping a charge. The capacitors are on the output side of the power supply and help filter and stabilize the voltages. When they fail the power does not settle when you turn it on so you have to do the on/off/on/off to get it to start. If you can solder then you should be able to repair your monitor. Check out the article on our site at: http://www.ccl-la.com/blog/index.php/repairing-the-westinghouse-lcm-20v5/ it is for the Westinghouse LCM-20V5 but they both use the same board so the repair information is the same. If you don't want to do the repair yourself we do offer a repair service for this unit, it runs $32 plus shipping. You can get more information on this service here:
CCL Tech
Corporate Computer
www.ccl-la.com
Jul 01, 2010 | ViewSonic VG2021m LCD Monitor
Does not power up freind thinks it's a blown capacitor
Yes, it can be that and other components.
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed WESTINGHOUSE (LCM-20V5 may be thesame chssis as yours) and monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Mar 31, 2010 | Westinghouse LCM-19v5 Monitor
Screen goes black after fraction of a second
More likely to be bad capacitors in the power supply, see LCM-20V5 (almost the same chassis as used in LCM-19V5) example: http://s807.photobucket.com/home/budm/allalbums
Post back what you see insdie so we can guide you further.
Mar 15, 2010 | Westinghouse LCM-19v5 Monitor
Westinghouse Monitor Repair
you can look for other caps that are bad on the board that may have failed later.
hear is a list of replacements for all the caps on the 20v5 i have
http://www.fixya.com/support/t2576306-two_westinghouse_20v5_monitors_also_just
Apr 01, 2009 | Westinghouse LCM-19v5 Monitor
Blue Screen
chak the signal cable of u r monitor
Nov 30, 2008 | Westinghouse Computers & Internet
SAMTRON 55V 15" CRT Monitor Logo
69 people viewed this question
Top Samtron Computers & Internet Experts
Daniel Sweetlin
Daniel Sweetlin
Level 1 Expert
Richard Lilja
Richard Lilja
William Miller
William Miller
Are you a Samtron Computer and Internet Expert? Answer questions, earn points and help others
