Question about IBM Wheelwriter 30 Typewriter
I have a wheelwriter 3 #674X. The print skipped somewhat and now is not printing at all-put in new ribbon and it seems the letters are not hitting the ribbon at all. What can I do to fix?
  • IBM Master
  • 3,594 Answers
You probably have a broken print solenoid pad. We sell them for 20.00 includes shipping and handeling and instructions.
DickyO
Cleveland Business Machines
216-241-0027
Posted on Aug 31, 2010
Ribbon will work in one Wheelwriter 6, no print output in another one
Your print solenoid probably has a broken cap. There are some companies that sell the "kit" with instructions on how to replace the cap.
Jan 16, 2014 | IBM Wheelwriter 6 Typewriter
IBM Wheelwriter 3 won't type
Print hammer selenoid cap is broken, or print hammer selenoid is gummed up.
Jan 03, 2014 | Lexmark Wheelwriter 3 Typewriter
I changed the ribbon on my IBM Wheelwrite 3 that was printing perfectly only to find that with new ribbons, the letters half-print. The print quality is poor. What could have happened? I have a brand...
Most likely the print solenoid cap is cracked. We sellthem for 20.00 includes shipping and instructionks. If only the top of the letters are printing to be sure the platen id filly seated in the side frames.
DickyO
Jan 16, 2011 | Office Equipment & Supplies
IBM Wheelwriter 6-Letters striking paper above
Put in a multi part form and type if the carbons come out OK the the ribbon isn't lifting, Wiggle the big black gear on the R. side of the carrier back and forth. They do get tooth for tooth when they get old. If the print on the copies id bad or not there you need a print solenoid cap. We sell them for 20,00 including instructiond and shipping.
DickyO
216-241-0027
Feb 18, 2010 | IBM Office Equipment & Supplies
My Wheelwriter 5 types faded and incomplete letters. We changed to a new ribbon, but problem is still there. Seems the pressure is not hard enough.
The solenoid for the hammer is probably sticky or the pad is worn.
This requires disassembly for cleaning, lube or replacing the pad.
Jan 25, 2010 | IBM Wheelwriter 30 Typewriter
Wheelwriter 3 Selector Assembly
The selection motor bearings just right of the print solenoid get dry a little WD40 on the front and rear bearings usually takes care or this.
DickyO
Dec 14, 2009 | Lexmark Wheelwriter 3 Typewriter
My ibm wheelwriter 5 does not print
Is the ribbon moving? Possible ribbon feed motor bad.Can you hear the printwheel letters hitting the paper? If not, then the solenoid pad is broken. Easy repair for a tech. A 7 to 15 dollar part depending on where you buy it. You can see it down on the left side of printwheel in front. A little round white or opaque pad. I have used a pair of tweezers and small bladed screwdriver and slipped a new in. Takes practice. Otherwise, you have to remove the carriage and take the solenoid out.
Jun 10, 2009 | Lexmark Wheelwriter 3000 Typewriter
Typewriter is working fine but won't type anything on the paper - new ribbon / new printwheel - no impression. Appears to be stuck on a "stencil" setting.
Put in a mulit part form, if it prints on the copies the ribbon isn't lifting, if it dosen't the plastic cap on the print solenoid needs replaced.
DickyO
Apr 23, 2009 | IBM Wheelwriter 30 Typewriter
IBM Wheelwriter 3 will not type
Probably the plastic cap on the print soleniod is broken. They are available from us for 15.00 but a little tricky to install.
DickyO
Jun 20, 2008 | IBM Wheelwriter 30 Typewriter
Ibm wheelwriter 5
Most likely the plastic cap on the print solenoid is broken they are available but are a bit tricky to install.
DickyO
Mar 27, 2008 | IBM Wheelwriter 30 Typewriter
IBM Wheelwriter 30 Typewriter Logo
59 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
