Question about Tappan 18 in. MDR251RE Built-in Dishwasher
Not cleaning dishes on top rack proline make wat could be wrong
  • Tappan Master
  • 43,501 Answers
When my wife started complaining about her dishwasher not getting the top rack clean this is what I found and I wrote a tip about it...
Dishwasher Spray Arms not Spinning
heatman101
Posted on Aug 31, 2010
Top dish rack dishes don't get clean model 8575637
Most dishwashers have a rotating spray bar underneath the upper rack. Over time bits of food can clog up the holes and then dishes won't get clean in the upper rack. Check to make sure all the holes in the spray bar are clear and that it is rotating freely.
Mar 22, 2017 | Dishwashers
Why doesn't the top rack of my dishwasher clean dishes?
the water tube may be clogged at the sprayer on the top of the basin. probably have to disassemble and clean
I’m happy to assist further over the phone at https://www.6ya.com/expert/howard_977676954994c5b2
Apr 14, 2016 | GE Dishwashers
The top rack is not cleaning. The dishes on the bottom rack come out clean but the ones on the top rack don't look like they have even seen water?
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it
Oct 19, 2010 | KitchenAid 24 in. KUDS02SRSS Stainless...
My whisper quiet dishwasher is not cleaning the top rack dishes
I'm having the same problem. Did some testing and found that the sprayer on the top rack is not even moving and hence not getting any water. Not sure what to do.
Sep 07, 2009 | KitchenAid 24 in. KUDP02CR Built-in...
Our GE Potscrubber 640 isn't cleaning the top rack items. They are neither cleaned nor rinsed. Does it have something to do with the "Rinse Dispenser" knob on the door? It's always been fully screwed in.
likely not .....the problem may be how you stack the dishes ....try doing a load with nothing on the bottom rack ....if the top rack items come clean then you may be stoping the water from reaching the top rack with the dishes on the bottom rack ....it's important to keep the center of the bottom rack free this is where the water comes from (on most models). to clean your upper rack .....have a close look at the inside of the machine to try and figure out where the water comes from ...it helps a lot to understand this ....good luck
Jul 25, 2009 | Dishwashers
My dishwasher is not washing dishes on the top rack...
HI,
The top rack is not cleaning because of low water pressure from the wash motor to the upper spray arm.
Assuming the top spray arms are clear of debris, remove the lower spray arm to access the wash motor. Remove the 4 torx screws and the filter (accumulator assembly). Remove the torx screw and the inlet protector that covers the chopper assembly. Make sure the chopper is not broken (broken chopper will fill with debris and block water flow). While holding the chopper blade, reach inside the "D" shaped opening on top of the motor and spin the wheel/motor by hand in each direction to make sure either the chopper gear or the motor gear that drives the chopper is not broken. Replace the chopper if necessary . If the motor gear is broken, replace the sump and motor assembly . Remove any debris from the sump area in the process.
You don't have to shut the power off to the dishwasher because the door will be open, but if you feel more comfortable, do so.
thanks,
Mar 18, 2009 | Frigidaire 24 in. FDB1050RE Built-in...
Top dishes not getting clean
OPEN THE DISH WASHER AND PULL OUT THE TOP RACK AND SPAY IT OUT WITH AN OUT SIDE WATER HOSE BECASE IT GET CLOG SOME TIME
May 05, 2008 | Kelvinator MDB121RF Dishwasher
Dishwashers Logo
193 people viewed this question
Top Tappan Dishwashers Experts
Ronald Rissel
Melissa Martin
Melissa Martin
Trevor Turner
Are you a Tappan Dishwasher Expert? Answer questions, earn points and help others
