Question about Pride Mobility Products Go-Go Elite Traveller 17AH Battery Pack
My Pride GO GO elite has started making a loud clicking noise in the right rear area when going down hill or on flat areas. If going up hill it stops. Its abott 3 years old.
4 Suggested Answers
  • 118 Answers
SOURCE: Pride Legend surges at any speed & makes a clicking noise
This sounds like a bad throttle pot. You need to have it replaced.
Posted on Nov 27, 2008
petraman7
  • 1175 Answers
SOURCE: Loud Clicking Noise in the back when I drive it.
Hi...
First off..Check the wheels to make sure nothing is jammed between them and the body.
I had one like that where a hat was stuck in the wheel well
Also , make sure the drive lever is all the way in
Pride service is 1-800-800-8586
Posted on Apr 23, 2010
  • 692 Answers
SOURCE: I need immediate help with
Check the area at the rear of the motor where the brake is attached after operating for a while if you can feel heat or hot at the brake motor area then the brake is sticking causing excess drag this in turn drains the batteries quicker and can be the cause of the clicking sound you hear. If the battery is not getting hot or the motor then the problem could be in the transaxle. Block the rear wheels off the ground and have the wife engage the throttle if you still hear the clicking noise place your hand on the gearbox /transaxle to see if you can feel a vibration in time with the clicking If you feel a vibration then the transaxle/gearbox will need to be changed If you see that the brake is dragging then the brake will have to be replaced If Medicare paid for the wife's scooter then they will pay for 80% of the repair. You can contact the provider that sold your wife the scooter to see if they do repairs or you can contact Repair xpress @1-877-581-3733 to see if they have a tech in your area Hope this helps you
Posted on Apr 21, 2011
Rear clicking noise
theres a stall in parkhead indoor market in Glasgow which is open Thursday to sunday.you have a slip brake.it is cheap to fix
Jul 01, 2014 | Pride Mobility Products Go-Go Elite...
Whining or hissing noise from rear area of 1998 chevrolet corvette
If the alternator has a bad bearing or bearings it would likely make a noise.
Oct 18, 2017 | 1998 Chevrolet Corvette
Battery loses charge when going up hill. Also hear clicking noise, but don't see anthing hitting the wheels. Is there a local authorized repair dealer near Williamsburg, VA, that could do a...
Hi, Something maybe touching the battery terminal and arcing is occuring. Check terminals again.
You may have to strap down the battery better. Good luck
Aug 12, 2011 | Pride Go-Go Elite Traveller Plus HD...
I need immediate help with a problem with my wife's GO GO Elite Traveller 3-wheel scooter. With a fully charged battery, in about 10 to 20 minutes of operating, there is a clicking noise in the area of...
Apr 21, 2011 | Pride Mobility Products GoGo Ultra X...
My scooter is making loud clicking sounds as though something has come loose & hitting something in the rear wheels as it goes around. The repair tech rotated the rear tires last week & this helped...
Its quite common for Pride scooters to be assembled using little or no grease on the rear axle. If the noise is like a stone stuck in the tyre, its probably a 'Dry Axle' as mentioned above. Try just removing the rear wheel(s) and greasing the axle. This normally cures the problem. When removing the wheel, be careful not to lose the hub key which slots into the axle and wheel to stop the wheel spinning freely on the axle. Hope this helps.
Jun 29, 2010 | Pride Go Go Elite Traveller Plus HD 4...
Back wheels make a loud clicking noise
Hi. Loud clicking noises from the rear wheels are usually caused by movement of the square steel key that fits into a groove on the axle inside the wheel hub. This is what drives the wheels.
You will probably get a click for each revolution of the wheels.
To fix it, remove the rear wheels and wipe a thin smear of grease on the key and axle, then replace the wheels.
The grease will allow the key to move slightly without making a noise, and help stop it from wearing.
It sometimes helps to also remove the front wheels, and wipe a thin smear of grease onto the front stub axles. There is no key in the front hubs, but the grease helps to prevent the bearings siezing on to the axles.
Good luck. Neil.
Jun 24, 2010 | Pride New Mobility Legend 4 Wheel Scooter
Loud clicking noise coming from rear wheel drive section
Hi. Does it make a click about every revolution of the rear wheels? If so it is probably the square key in the axle that drives the wheels. Raise the rear of the machine on blocks, and remove the rear wheels. Wipe a thin smear of grease on the axle and key. then reassemble and test.
I have done this on many machines because of the noise. Just about all brands have this problem.
Good luck. Neil.
May 31, 2010 | Pride Mobility Products Go-Go Elite...
Hi...
Apr 16, 2010 | Pride Mobility Products Celebrity X...
Click and clunk when moving from right rear wheel Pride Elite +
This can be caused by two things usually. One cause is the bolt holding wheel to the axle is a little loose so check to make sure it is very tight on the axle. The second click comes from flat-free tires. The tires have an adhesive applied at the factory and if you hit a bump, or if there's not enough to hold the tire tight to the rim, the tire will make a grinding click noise when it rolls and passes over this area. Pneumatic tires properly inflated don't make this noise since the air pressure keeps the tire fixed to the rim at the bead; flat free tires lack this pressure. Simply lubricate the area around the tire where it meets the rim on inside and outside, and drive it...noise should dissipate.
Aug 28, 2009 | Pride Go-Go Ultra X 3-Wheel Travel Scooter
Pride Mobility Products Go-Go Elite Traveller 17AH Battery Pack Logo
162 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
Robin Hill
Robin Hill
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
