Question about Philips Magnavox 27MS343S 27" TV
32mf23id philips I have a problem when I turn on the tv after a while I lose signal and then a few seconds late the tv shut off
Sounds like the internal power supply is going bad. Loses power to the tuner first then the whole tv.
Posted on May 09, 2008
PHILIPS 40PFL7705DV/F7 keeps shutting off
If it is a new TV and under warranty, return it. There is an internal fault and it needs to be serviced.
Oct 25, 2012 | Philips 40pfl7705dv/f7 40 Hz 120 Led Tv -...
TV keeps shutting off
Its the power pack located inside the TV, it needs replaced. contact manufacturer for parts or service.
http://www.support.philips.com/support/html/index_global.html
Nov 14, 2007 | Philips 50PF9431D Television
REPLACED POWER BOARD TV TURNS ON DISPLAYS PHILIPS AND SHUTS OFF ,BUT LIGHT BLUE INDICATOR LIGHT STAYS ON
If no signal (whatever the reason) most sets with a solid blue screen will shortly shut off.
A few things to try first:
Unplug set, a box if used, a receiver if you have it in line---wait a while and plug each back and wait to see if they reboot and restore signal.
Also look to see if you can get the set to a video input before it shuts off---A DVD etc should be connected and on when you try that.
May 26, 2012 | Philips 40PFL3705D 40 in LCD TV
I have a phillips 42fd9954 17s. when i turn it on the green light tuns on for like 6 seconds then fades . then nothing. no sound no picture. any idea. i am using a comp cord. had no cord when i got it
if you use vga input and there is no signal the tv shuts down in few second. It will wake up again if you provide vga signal or cycle it on off again. Change input to component or s-video and tv should stay on. On the other hand, this model has known problem with bad power supply unit but usually red light flashing when tv shuts down in that case.
Oct 16, 2011 | Philips 42FD9954 42 in. Plasma HDTV
I have 20MC4306. Recently when you turn it off it turns itself back on. Also when you turn it on shuts off after 2 seconds. Tried putting in a video vhs then press play and wait few seconds and hit...
Sometimes when the TV recives a brodcast signal for a new update to the mainframes firmware, it will have to turn itself on to install/recive the update and aslong as it is connected to a power source it can do this. hope this helped answer your question. Have a good day :)
Jan 03, 2011 | Philips Magnavox 20MC4306 20" TV/VCR/DVD
The screen won't turn on. But, whenever you press the on button it turns red like it is turned on. What's wrong? And how can I fix this?
A very common problem with this TV model. You have a bad signal module or a bad small signal board. Leave your TV unplugged for a few days or a week. Then plug this TV and power on. If the TV comes on and plays well for a few seconds and goes out, the SSB needs replaced. The second thing would be to pull the back cover off. If TV is already on,you can see the rear filaments on the TV tubes lit. Still no picture..then your the signal module is bad and the Convergence ICs and resistors will need replaced. This is a good starting point. Definitely one of these two problems.
Nov 21, 2010 | Philips 50P8341 50" Rear Projection...
Magnavox HDTV very dim
hi i have a philips 42 pfl5522d and need a new screen can you get me one..
Mar 16, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
DVD playback color
When passing the video signal thru a VCR on the way to the TV, you are activating the DVD's "Macrovision" copy protection.  You need to hook it directly to the TV.
Jan 27, 2008 | Philips DVP642 DVD Player
Tv turns off
is the timer set. or does it have an automatic shut off. I would check your settings.
Oct 23, 2007 | Televison & Video
Philips 55PW9363
Hi! ronogre,
This set has a defective SMALL SIGNAL BOARD.
Toprol
Jul 31, 2007 | Philips 55PW9363 55" Rear Projection...
Philips Magnavox 27MS343S 27" TV Logo
157 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
