Question about Whirlpool 24" White BuiltIn Dishwasher Dishwasher
Burns out thermal link what causes it - Whirlpool 24" White BuiltIn Dishwasher Dishwasher
  • Whirlpool Master
  • 3,740 Answers
Hi I am Kelly. What you should do is first turn off input power and perform resistance readings.
1. Unhook one wire of the heating element and read each of the element end terminals ONLY to the chassis and the outside cover of the heating element.(not to each other) If the element has failed internally they are notorious for tripping circuit breakers or burning out thermal links. Make sure to reconnect the heating element terminal if it reads correctly.
2. Make sure the circuit breaker is OFF and then test each of the input power terminals to the pump / motor case. Only the ground should read to the pump motor case. If either of the other 2 leads read to the motor case then most likely water has leaked into the motor and caused a short.
These are the 2 most common dishwasher shorts. There is always a possibility of a chaffed or broken wire somewhere but it is not nearly as common as the first 2 above.
Thanks for choosing FixYa.
Kelly
Posted on Aug 31, 2010
How to replace dv7 1130us cpu
When replacing a CPU. Make sure the new CPU is compatible with the device you are trying to upgrade. You are going to enter into the BIOS. Download this PDF manual to be aware on how to get into these settings. http://h10032.www1.hp.com/ctg/Manual/c02642701.pdf
The physical part with replacing the CPU hardware. CAUTION!! DO NOT FORGET TO HAVE THERMAL COMPOUND BEFORE PLACING THE HEAT SINK ON THE CPU. IF YOU DO NOT APPLY THERMAL COMPOUND, THE CPU WILL OVER HEAT AND MAY CAUSE YOUR UPGRADED CPU TO BURN OUT.
LINK TO LEARN HOW TO APPLY THERMAL COMPOUND;
http://www.computerhope.com/jargon/t/thercomp.htm
Good Luck.
Sep 11, 2016 | HP Pavilion dv7-1130us laptop
Replaced thermal fuse after self clean burned it out, now upper oven works fine but lower oven won't bake or broiler
Hello;
My name is Peter. I am a retired field service appliance technician.
The High Temperature limit switch is the week link in the system. This component will fail first causing the thermal fuse to fail. You need to replace both components.
Also check your temperature operating switch. You should get a reading of '0' Ohms if it is good.
Still having problems? Remove the oven thermocouple and test it. You should get a reading between 1000 to 1100 Ohms if it is good.
May 04, 2015 | Ovens
Dryer spns but there is no heat
probally the heeting element
Mar 10, 2015 | Samsung Dryers
What causes a thermal fuse to burn out on a samsung front load dryer
Lint exit tubing may be clogged. Need to clean periodically.
Jan 12, 2014 | Samsung DV218AEW Electric Dryer
No heat in dryer
Check your exhaust leading from your dryer because kinks and lint blockage are the leading cause for exhaust high temperature thermal fuse to burn out causing it to run with no heat. The thermal fuse for a front loading 110.88752791 is part number=> 3399849 Thermal Fuse
You may view the location number 15 HERE. The location 5 in that photo is the=> 3398128 Cycling Thermostat
How to check these parts can be found on the same above pages, If rhe model I listed is not your model let me know and I will send you links to other models with the same model number as 110.88752791, Thank You Sea Breeze
279843 Heating Element Assembly
Nov 07, 2012 | Dryers
Whirlpool dryer bad heating element AGAIN
Hi Warren Fink
Try this solution to your problem
A vent clogged with lint can cause the dryer to overheat.
Right after replacing a dryer element, always run the dryer on air fluff/no heat, and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
Please take time to rate me
Bud
Oct 18, 2012 | Whirlpool Dryers
If the thermostat is sticking could it cause my thermal cut off to keep going bad
That could be the case also if you aren't getting the proper flow out of the dryer because of lint build up could also cause the problem. The thermal cut off switch is activated when the temprature at the coils reach a certain heat limit then the switch burns out.
Hope this helped
Dave
Feb 24, 2010 | Dryers
Dryer keeps burning out thermal fuse and thermostats
If the thermal fuse and thermostat are bad,something is causing them to overhea,t before tackling the heating element, you should check all connections to the stat and fuse as a loose connexion could be the cause of the over heating.
Dec 11, 2008 | Kenmore Dryers
Whirlpool 24" White BuiltIn Dishwasher Dishwasher Logo
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
