Question about Irons
Morphy richards steam generator iron heating up but steam isnt working as it should?
  • Anonymous Mar 18, 2014
    morphy richards 42770
  • 43,501 Answers
Try bottled spring water... many times tap water will not steam right...
heatman101
Posted on Aug 31, 2010
Steam generation minimum morphy richards
If tap water is used in a hard water area limescale can soon build up and reduce water flow into the steam generator.
A propriety descaler might help but if the situation is too advanced it is unlikely.
Mar 03, 2015 | Morphy Richards Irons
Why is there No steam from morphy Richards 42247 model steam generator?
It may be calcified or have lime scale. If the heater is "gummed up", it cannot heat properly. Try using either vinegar (takes longer) or an iron cleaner. You pour it in and it breaks up the scale. CLR works quite well too. Use pipe cleaners to clear out the holes in the sole plate.
Jun 02, 2014 | Morphy Richards Jet Stream 42271 Iron
Water leaking from soleplate.....
Your Morphy Richards Jet Stream 42271 Iron is developing a leak. If the leak becomes worse, you may have to replace the iron.
Mar 05, 2018 | Morphy Richards Jet Stream 42271 Iron
Can't get my Morphy Richards steam generator off of standby
do this and use the common sense. God bless you
f the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber (see below). If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat (see the Appliance Controls Fix-It Guide).
If the iron does not spray properly, inspect and clean the nozzle (see below).
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water
Sep 24, 2012 | Irons
My team generator iron will not steam
Have you any other suggestions? Yes. Dump it.
Jul 16, 2017 | Morphy Richards Irons
MORPHY RICHARDS 42256 JET STREAM STEAM GENERATOR IRON does not provide steam
My MORPHY RICHARDS 42256 JET STREAM STEAM GENERATOR IRON has stop producing steam. I have changed the filter and although it heats up, it does not produce any steam.
Feb 29, 2012 | Irons
The iron will not steam and the standby button is constantly flashing
Always switch off the unit and allow to cool before cleaning or storing. .... If your steam generator does not work, check the following points: ... working temperature, the LOW STEAM ICON will flash whilst the heating cycle takes place ... steam. 9 When ironing is complete, press the POWER. STANDBY button.
Jul 27, 2011 | Morphy Richards Jet Stream 42271 Iron
Irons Logo
446 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
