Question about GE Refrigerators
Temp and freezer adjust displays are blank with power on. m/n:psc23sgrb ss
  • GE Master
  • 1,606 Answers
Your display panel has lost communication with the main control board . Replaceing the board is the only solution . The main control board , is behind the refrig , behind an 8X10" panel . Pt # WR55X10942 . Easily replaceable due to the 6-7 group plug ins , will only fit to certain recepticals ( with the same amount of pins in the same amount of recepticals ) . Be sure to unplug the refrig when replaceing .
Posted on Aug 31, 2010
  • Ed Mallory
    Ed Mallory Dec 18, 2015
    I replaced the Main Board with the WR55X10942 fridge is running and cooling, but both temp displays are flashing 0's and wont adjust at all. No function on the water or ice displays at all.
    my model is the GSH22JSTA SS
Frigidaire model ffu2065fw1 light and alarm works but the control module is blank???
Good Morning Friend,
I understand that the light and alarm are working fine on your Frigidaire freezer, model# FFU2065FW1. I also see that you are receiving power to the control module, however it is blank. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and try adjusting the temperature. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully.
-Best Regards-
WP
Jun 21, 2014 | Frigidaire Freezers
Kenmoore 76523 ss bottom freezer, freezer works, refrigerator does not
This is not my main field of expertise . However, as I see you are not getting more support I can address you to this link. It may help you
goodbye
Feb 22, 2008 | Kenmore 73503 Stainless Steel Bottom...
The digital display resets to 0 F for BOTH the Freezer and Refrigerator after I change the temps (for eg to -4F for the freezer and 34F for the refrigerator) Also the the refrigerator and freezer are...
The OF OF display is the OFF setting, used for display purposes, so the light and controls light, but the refrigerator does not run while it is on display at a dealer. Try pushing in and holding the top two buttons on the left side of the display for about 5 seconds at the same time to get it out of the display mode. You should be able to set temps then.
Jun 20, 2010 | Samsung RFG297AARS (285 cu ft) Bottom...
My 7 year old GE Profile Side by Side will not get
Self Diagnostics
To enter Self Diagnostic mode, both temperature control panel displays must be illuminated. A display
can be illuminated by pressing an adjacent temperature adjustment button. When both displays are
illuminated, set the freezer and refrigerator temperature settings to 5. Simultaneously press and hold all
4 temperature adjustment buttons for approximately 3 seconds. A flashing 0 in the refrigerator and
freezer displays will indicate that the refrigerator is in Self Diagnostic mode.
For temperature control panels with single-digit displays, the COLDER temperature adjustment button
will increment the numbers up and the WARMER temperature adjustment button will increment the
numbers down. Use the freezer temperature adjustment buttons to enter the test code number in the
freezer display. Use the refrigerator temperature adjustment buttons to enter the test code number in
the refrigerator display. When a test code has been entered, the displays will flash to confirm the test.
Press the HOLD button for 3 seconds to begin the test.
For temperature control panels with 3-digit displays, the COLDER temperature adjustment button will
increment the numbers down and the WARMER temperature adjustment button will increment the
numbers up. Use the freezer temperature adjustment buttons to enter the test code number in the
freezer display. Use the refrigerator temperature adjustment buttons to enter the test code number in the refrigerator display. When a test code has been entered, the displays will flash to confirm the test
code. Press any button other than a temperature adjust button to begin the test.
When testing has been completed, do one of the following things:
• Enter code 1 5 to completely reset the system.
• Enter code 1 6 to exit diagnostic mode. GSS manual
May 15, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE PROFILE REFRIGERATOR MOTHER BOARD PROBLEMS i REPLACED THE MOTHERBOARD AND IT STILL DOSEN'T KEEP THE PROPER TEMPERATURE. It varies from 36 to 45 degrees.
Go into the diagnostic mode on your touch display .
1) . Press any button on the display 1 time except the temp adjust buttons.
2) Press the temp up and down on both the freezer AND refrig (all 4 at the same time)
3) when 0's show , release the buttons and press any button except for the temp adjust buttons .
4) NOW , fress the temp adjust buttons until the freezer side displays 0 and the refrig side displays 7 . 0 and 7 is for the thermistors test .
5) After 0 and 7 display , press any button again except temp adjust , and this will start the thermistor check .
6) You will have 7 thermistor tests , indicated on the refrig display , starting at 1 , then 2 then .......
7) The feezer display will tell for the corresponding thermistor , indicated by the refrig display , if the thermistor p = pass , s = short , b = bad (replace board)
After determining if or which thermistor is bad , then adjust the display to 1 on freezer display and 6 on the refrig display . This ends the testing procedure and resets the refrig back to normal .
Sep 26, 2009 | GE Profile PFCS1NJWSS Stainless Steel...
Fridge temp will not drop to set temp
if you have had a sudden power failure or power spike, you may need to reset the fridge. This can be done by holding down the power freeze button and the fridge temp button together for about 5 seconds. The fridge display will go blank. press the buttons together again, the fridge display should return and both fridge and freezer should be reset
Apr 19, 2009 | Samsung RS2630SH Side by Side Refrigerator
GE Fridge: PSS26SGPA SS Model
CallMe-
Your "freezer" and "refridgerator" temps are not jumping back to 14 and 44 respectively. When you change temps, they both wait 3-5 seconds before they revert back to a temp reading, not a temp setting.
Does your "freezer" make any loud or thumping noises? If not, do you hear a quiet whisper when both compartment doors are closed?
Solutions could be :
1. Servicing the coolant (might have a small leak)
2. Checking the seal on your freezer compartment (black rubber that meets the metal frame)
3. Your internal cooling fan is not operating and needs replacing (but I think your temps would be significantly higher).
Best of luck.
Jul 28, 2008 | Refrigerators
Kenmore Elite bottom freezer refridgerator
I just went through this with my refridgerator and actually posted one of the questions. Here is what I found ........
In the freezer compartment behind the panel there is an evaporator fan which pulls cold air from the freezer and pushes it up into the refrridgerator compartment. If the fan is not working it is one of three things.. 1) there is so much frost in the fan area the fan blade is stopped and cannot push the cold air into the refridgerator compartment or the air channel is blocked. 2) there is no electricity going to the fan (usually tied to the door switch of the refirdgerator compartment, and 3) the motor is dead and will have to be replaced.
Solution to #1 - defrost but there is another problem in the "frost-free" part of the system which must be addressed or the frost will return and it will happen again in the future.
Solution #2 - check to see there is power to the fan. (most are 110VAC but some are 100VDC. Use a meter and check)
Solution #3 - If there is power, the motor is dead. Replace the motor. Be aware that AC and DC motors are different and replace per manufacture's specifications.
Feb 21, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerators Logo
229 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
