Question about LG WD-3632HW Front Load All-in-One Washer / Dryer
Error code dHE, manual says to check water supply. No issues there, cleaned filters, valves are open. Now machine won't power on. Unplugged and plugged back in, still no power? Why is it not working?
  • 1462 Answers
SOURCE: Washing Machine fills slowly how to change inlet valve
switch off power remove top switch off water and remove hose. remove inside pipe from valve - usually held by just a spring clip remove electrical terminals valve is just held with a couple of screws usually - remove these and valve will come away. put back in same order
Posted on Jun 22, 2007
SOURCE: Error code dHE
Several reports in Australia of brand new LG Washer/Dryer combo (model number WD14700RD) getting dHE error's with very 1st dry cycle.
I bought a LG WD14700RD last week, and yup, washed fine.
Dryer cycle results in dHE error.
Everytime.
Cycle stops & you just have to power off the machine.
Service man found several possible causes.
He unscrewed the top of the machine off & said dHE errors are related to the dryer components. He started a dryer cycle & watched & lisened to machine.
He observed the dryer fan was not starting up.
He unplugged the power cable to the dryer & replugged.
The fan now started up, but only with cold air.
He then looked towards the front of the machine & noticed several cables had come loose from their sockets, one he identified was the heater element cable.
He plugged that back in & another unknown cable was also loose. He plugged that back in.
It worked.
dHE error gone & dryer fan started & pumped out hot air.
It seems at least a few of these machines during transit (from South Korea?) fail due to cables coming loose from their sockets.
dHE errors result if fan cable & fan heating element cable come loose.
My thanks to WAM electrical repairs in Box Hill (Melbourne) for helpfull advice & successfull repair.
For people looking at buying this machine, it washes & now dries perfectly well & I am happy with the machine.
But beware that this problem is out there (there are several other reports I read) and it have this problem, which is easily fixed but does require a service call out, under warranty of course.
Steve, East Melb.
steve_aust@hotmail.com
Posted on Jan 19, 2008
  • 497 Answers
SOURCE: Hotpoint Aquarius WT540 washing machine. will not fill with water
Sounds like a timer switch malfunction.
Posted on Sep 06, 2009
SOURCE: lg 801 3f washing machine. 15 seconds after selecting any cycle a
I had the same problem. Redistributing the clothes inside the machine seems to do the trick. Even though the clothes seemed evenly distributed and I had far less than maximum capacity in the machine- it seemed to think that something was out of sync- simply moving the clothes around did the trick!
Posted on Oct 05, 2009
woodchuck789
  • 4070 Answers
SOURCE: Machine will not fill with water, it acts like
Your pressure switch stops the water and allows it to start the next cycle. It's a switch either in the control panel or at the top of the tub with a small tube connected to it which goes down between the inner and outer tub. As the water level increases the air in the tube is compressed until there is enough pressure to "make the switch" stopping the water from filling. This tube can get clogged and the switch won't work. Remove the tube and clean it out. Blowing on the tube when it's still connected to the switch will make the switch if it's working and clear.
Part 5 on this diagram is your pressure switch. http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Washer-Parts/Model-PAV2300AWW/3048/0153200/M0606007/00001?blt=06&prst=&shdMod=
Posted on Nov 11, 2010
My LG dishwashing machine model LD 2131 SH displays a F error. What does it indicate?
LG DISHWASHER ERROR CODES AND DESCRIPTION MODELS LD 1420W2 D1420WF LD...
ERROR CODES; FAULTS & REMEDY ERROR DISPLAY [IE]
Inlet error.
Condition: Not reached to the normal water level in spite of 10 min. water supply.
Possible causes:
  1. The Water Tap is not opened.
  2. The Inlet Hose is twisted.
  3. The Filter of inlet valve clogged by impure water.
  4. The Inlet Water Valve is normal ?
  5. The water pressure is very low. ( below 0.5 kgf/ )
  6. Inlet valve is blocked by safety device for leakage sensing.(In case of Inlet Valve).
Remedy
    • Open the Water Tap.
    • Repair the Inlet Hose.
1.Close the Water Tap.
2.Unscrew the Inlet Hose (Inlet Valve side)
3.Clean the Filter of Inlet Valve.
> Replace or repair the Inlet Valve.
> Check the water remain on the base.
1.Check the point of damages and repair or replace the related parts.
2.Disconnect the inlet hose to dishwasher to unlock the safety valve.
ERROR DISPLAY [OE]
Drain error.
Condition: Not fully drained out in spite of 5 min. drain operation.
Possible causes:
  1. The Filter clogged.
  2. The Drain Hose twistec or blocked.
  3. The Drain Pump/Motor or circuit is troubled.
Remedy
    • Clean the Filter.
    • Remove the cause of twist or block.
    • Replace the Drain Pump/Motor or repair the Circuit.
ERROR DISPLAY [E I ]
Leakage error.
Condition: The water level in Tub goes down during operation.
Possible causes:
  1. Water leakage in Hose connections.
  2. Water is leaked by damages.
  3. Impeller of the washing Pump is worn away.
  4. The Thermal Protector of the washing motor is functioned
Remedy
    • Replace the connections of Hose.
    • Check the point of damages and repair or replace the related parts.
    • Replace the washing pump.
    • Check the applied voltage.
ERROR DISPLAY [ F E ]
Excess error.
Condition: Excessive water is supplied than normal water level.(Automatically drain Pump operated.).
Possible causes:
  1. The Inlet Valve is troubled.
  2. The Air Break is troubled.
  3. The Sensor Assembly is troubled.
  4. The Controller is troubled.
Remedy
    • Replace the Inlet Valve.
    • Replace the air breaker.
    • Replace the sensor assembly.
    • Repair or replace the controller.
Jul 09, 2017 | Washing Machines
What does error code ie indicate?
IE error mostly means not filling completely with water or very slow fill
Jan 31, 2016 | LG WM2688HWM TROMM SteamWasher
HOW DO I STARTS MY WASHING MACHINE AGAIN CAUSE IT ALWAYS `IE` ERROR EVEN I ALREADY CLEAN THE FILTER,CHECK HOSE,THIS ERROR HAPPENS WHEN SOMEONE USE IT MANUAL WHEN NO WATER IN SERVICE,I MEAN HE MANUALLY
The IE or E1 error or fault code indicates that the washer is not filling with water. Check to be sure the water supply valves are open. Also, check to be sure the water supply hoses aren't kinked or clogged. Next, remove the hoses from the washing machine and run water into a bucket to test the pressure and flow of the water. If all of these check out and you have good water pressure and flow to the machine, you should replace the water inlet valve
If you are trying to use the machine manually, there needs to be enough water in the machine to tell the level sensor when to switch off the water inlet solenoid valve. Failing this, the machine will only show IE (Inlet Error) and refuse to work.
Feb 15, 2015 | LG WD-1070QDP 7 Kg Direct Drive Washer
Samsung front load washing machine, WF42H5200AF, less than 4 months old giving code 4e when warm or hot temperature is pushed. Can only wash in eco warm or cold. I have drained and cleaned out to front...
Error code 4E is a water supply error.
Check the following:
  • Foreign material is entering the water supply valve.
  • The water supply valve terminal is not connected.
    (Wire disconnected)
  • The warm water and rinse connectors are wrongly connected to each other.
  • This occurs if the PCB terminal from the drain hose to the
    detergent drawer is not connected. Check whether the transparent hose is folded or torn.
Possible Parts Affected are:
  • Water supply Valve
  • Main PCB
  • Obstruction of the water line.
To Check the water supply:
Check the resistance for the water supply valve. Resistance: 0.9~1.1k? between the terminals of the water supply valve
Jan 28, 2015 | Samsung Washing Machines
Kenmore Elite 22062 washer, code FL. FL flashes and motor hums for about a minute then shuts off. There is about 1 inch of water in the tub yet. I shut off cold and hot water and unplugged power over...
Hi
Thanks for using FixYa. Error LF indicates long fill, which flashes when the water level won’t change for a period of time after the valves are turned on or the water has disengaged the basket but control does not detect a water level change. TO resolve this issue check if the water supply is turned on and the hose screens are not plugged or kinked. If the water is not entering the machine then check the water valve, also check the pressure hose connection to the machine/motor control. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 06, 2010 | Kenmore 22062 Top Load Washer
I started a cycle, added the detergent to the water compartment but then FL code showed on the display and the cycle stopped. I turned the washer off, unplugged but nothing change.
Thanks for using FixYa. Error LF means long fill, which flashes when the water level won’t change for a period of time after the valves are turned on or the water has disengaged the basket but control does not detect a water level change. TO resolve this issue check if the water supply is turned on and the hose screens are not plugged or kinked. If the water is not entering the machine then check the water valve, also check the pressure hose connection to the machine/motor control. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 26, 2010 | Maytag Neptune MAH5500B Front Load Washer
Samsung washing machine J1045 water over filling
If you are getting this code it is because your washing machine has tried for at least ten minutes to drain the water out of the machine. The most likely cause of this problem is that you have a plugged pump filter or you have something stuck in the pump filter.
Make sure that you unplug your washing machine.To clean out the pump filter you must empty the washing machine water. The best way to do this is to manually drain the water into a low bucket or basin. Then lay a towel down to catch to remaining small amount of water. Remove the pump filter, clean out any debris, and wash out the filter. Then plug your washer back in and restart the washing machine.
Check that your machine is properly leveled. A washer that is too far out of level may not drain properly. Make sure that you are level front to back as well as side to side.
This solution will solve your problem
Apr 08, 2010 | Samsung Washing Machines
Keep on getting the IE erorr
Error code IE means an water inlet error. Correct water level is not reached within 8 minutes after water is supplied or it does not reach the preset water level within 25 minutes.
Make sure water supply tap is open and not frozen. Check and clean water inlet valve from debris. If the issue persists, replace water inlet valve.
Oct 18, 2009 | LG WM1814CW Front Load Washer
Error code dHE
Everytime.
It worked.
Steve, East Melb.
Oct 06, 2007 | LG WM3431 Front Load Washer / Dryer
LG WD-3632HW Front Load All-in-One Washer / Dryer Logo
42 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
