Question about Samsung WF203ANW Front Load Washer
Samsung front load washer model wf210 door won't lock closed
  • 641 Answers
SOURCE: Frigidaire Front Load Door Lock Broken and Noisy FWT449GF
Its looks like a lid switch issue. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. Good luck!
Posted on Sep 08, 2007
  • 105 Answers
SOURCE: front load washer won't start unless door open and closed over and over
the door latch needs a spray of crc into it as it may be a little dry inside there
that should fix problem
if not replace door switch
Posted on Mar 16, 2008
SOURCE: Door won't open on Samsung washer
This has happened to me twice. Both times I found the drain pump seized up with
1st time) The right rim from a pair of reading glasses
2nd time) A plastic toothpick
Both times the object was in the discharge port of the pump. You can see this by lifting the check valve with the pump removed. Removing the pump is simple. Unplug the washer. You have to remove the drain line from where its attached to the rear of the machine (one screw) to remove the rear access panel which slides into upper and lower slots. You will see the pump with an inlet and discharge line attached. The lines have simple squeeze clamps. When you remove the lines, you will drain the wash basin so have towels and a squeegie handy. Remove both lines and wait until the basin drains. When it stops draining remove the pumps electrical connector by squeezing the release catch on it while pulling it. The connector can only go on one way. Remove the 3 hold-down bolts on the pump baseplate. Remove the pump and lift open the discharge check valve and you'll find something there I guarantee it. Remove with needle nose pliers and re-assemble in reverse order.
This is actually a good design because the computer protects the pump by sensing a higher than normal current draw when foreign debris gets jammed in it. It will trigger the ND (No Drain) code and sometimes lock the door. Always check this first before you call the expensive repair man. If its not a jammed pump it will most likely be the control panel/processor. Good luck and always clean out pockets before loading the washer to prevent this,
Posted on Feb 14, 2009
Your water pump probably has debris in it. Remove the back center cover. The water pump is right there. Thread the drain line back through the machine and put the end in a bucket on the ground, most of the water will drain. I used towels to deal with the rest. Remove the water pump and open it up, I found a quarter. Reinstall and if you found debris the machine should work. It took me 1/2 an hour to do this, not worth calling for service.
Posted on May 20, 2009
SOURCE: samsung silvercare washer stopped working, won't unlock
here is the most common cause for this problem, according to the Samsung repair guy that was here to fix mine today.
On these washing machines it is possible for some debris (in my case it was a small screw from my packet) to make its way passed the drum and into the pump. Once this happens then the impeller of the pump becomes restricted or completely blocked which will result in the above mentione symptoms.
On some machines the pump is on the front, on others at the rear of the machine. In my case it was at the rear, removing the rear panel will allow easy access to it. Have a bucket ready, when the hose is removed from the pump the water will be draining from the machine. 3 bolts and a hose clamp on the inlet and another on the outlet hose. Disconnect the electrical plug from the pump and you can remove it from the machine for cleaning. A very easy job, requiring little skills and not much in terms of tools. (make sure machine is UNPLUGGED from AC outlet)
Remove obstruction(s) from pump and reinstall in reverse order of disassembly. The guy says these pumps are really tough so if you hear it buzzing, trying to go while it's jammed it's a good sign it will work. If not, replacement will be necessary.
Cost me $140. Could have been worse I suppose. Advise: Empty pockets BEFORE washing clothes...
Posted on May 26, 2009
Lights flash
In the most front load washer this is very common problem and in these new washers such problems are due to malfunction on the door lock or control panel or control board ,you have to check them all one by one
Apr 24, 2014 | Hotpoint Aquarius WF210 Front Load Washer
My Kenmore front load washer will not fill--it sounds like it is draining instead. The last load washed did not spin correctly and the clothes were very wet when cycle completed.
Washer Not Filling:
  • Door Not Closed and Locked
    • Front load washers won't fill if the door is not closed and locked. Listen for the door locking when starting a cycle, then pull on the door to make sure the door is closed and locked.
  • Delayed Start Feature
    • Some washers have a delay prior to filling, where the electronic control is checking the dispenser function. This is Normal.
  • Flashing Lights or Error Code on Display
    • When there is a filling issue, the washer may shut off and display one of the following codes: LF, LE, nF, IE, FH, E10 or F20.
    • If the washer is displaying one of the above error codes, then do the hard reset procedure listed below.
If the appliance is not accepting input from the control panel, follow the steps below to reset the control:
  1. Unplug or turn the circuit breaker off for 30 seconds.
  2. Plug the power cord into the wall outlet or turn the breaker back on and wait 30 seconds.
  3. Press the Pause / Cancel / Stop button twice to clear the display.
  4. Start a short cycle, to check operation of the appliance, by selecting a cycle and pressing and holding the start button until the appliance starts.
Oct 15, 2012 | Kenmore Washing Machines
Affinity frigidare front load washer won't start. It beeps with message flashing (DR)
Hello zabbster - Typically the DR or DO error code indicates that the door switch is not closed. Make sure that the door lock is completely closed. If the door is closed, make sure the door latch is not broken. If the latch is broken, you may possibly need to replace the door lock switch.
Sep 25, 2012 | Frigidaire Affinity ATF7000E Front Load...
Kenmore front load washer door won't latch lock light on
On some Kenmore front load models, if the black gasket around the door opening is unseated (for example, because you drag some heavy wet laundry over it) the door will not engage the lock and stay closed. This is a feature to prevent the washer from leaking when the gasket is not sealed. To fix it, simply reseat the gasket and the door will close and lock.
Jun 21, 2012 | Kenmore 44102 Front Load Washer
I'm trying to find instructions to remove and then fit new door seal on hotpoint WF210, have lloked at tsome online videos but the wf210 doesnt seem to have the outer retaining ring releases as shown on...
I find it easy to remove front casing to fit new door boot seal First remove soap drawer then the 4 screws here next pull off control know of timer next 3 screws on front panel this then now drops down with wiring attached the front of the machine has 3 top and bottom screws remove them along with the door interlock switch 2 screws......detach the band or wire around the door seal the front panel can now be removed.....Seal is in front of you secured by large metal band and screw undo this fit on new seal refit ring and bobs your uncle as they say Good luck....
Apr 21, 2011 | Hotpoint Aquarius WF210 Front Load Washer
I have a front louder newer model samsung washing machine. The door was forced opened during cycle and now the lock is still in the locked position and I cannot reclose the door or get the locked to unlock...
The machine has to reset to bringg tthe lock to release, check the link to the lock settings to make the program complete the cycle and release the lock. Do not force it as you end up damaging.
Sep 01, 2010 | Samsung WF206ANS Front Load Washer
Ive pulled the door handle to hard when it was locked and now it wont open.is there anyway i can open it thanks
Make sure there is no water left in washer, and try door again.
If it still will not open,then remove top cover, and force door lock open from inside at the front.
You will possibly damage the door lock by doing this, but i am afraid there is no other way of doing it.
Jan 30, 2010 | Hotpoint Aquarius WF210 Front Load Washer
Door seal needs to be repleced
sorry not a answer as such. I found out the machine is still under guarantee. So I just called out the repair man.
Feb 12, 2009 | Hotpoint Aquarius WF210 Front Load Washer
Samsung WF203ANW Front Load Washer Logo
400 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
