Resistores averiados ecualizador aiwa ge-z7000
Resistores R82 y R83 ┬┐cual es su valor? Estan muy deteriorados y no se ve su codigo.
bunnydawg
  • 5158 Answers
SOURCE: TRASMITE IMAGEN DESASIADO BORROSA DE MUY BAJA CALIDAD
tiene usted intentado enfocar la leva. hay generalmente un anillo externo en la leva que permitirá que usted haga eso. ¿cuál es la leva que usted está utilizando así como el sistema operativo? Roberto
Posted on Aug 29, 2008
SOURCE: conoces el codigo de control que le corresponde a
buenos dias, necesito el manuel del control jenser 323, para codificarlo con un dvd, por favor si alguien puede ayuidarme, lo agradeceria mucho mi correo es asdruba_yo@hotmail.com, mandenlo aqui por favor, muchas gracias, que tengan buen día.
Posted on Apr 27, 2009
moparhart
  • 245 Answers
SOURCE: mi dodge neon sxt 2.0Laut 04.me da un codigo p0300
Basically this means that the the car's computer has detected that not all of the engine's cylinders are firing properly.
A P0300 diagnostic code indicates a random or multiple misfire. If the last digit is a number other than zero, it corresponds to the cylinder number that is misfiring. A P0302 code, for example, would tell you cylinder number two is misfiring. Unfortunately, a P0300 doesn't tell you specifically which cylinder(s) is/are mis-firing, nor why.
Symptoms may include:
  • the engine may be harder to start
  • the engine may stumble / stumble, and/or hesitate
  • other symptoms may also be present
Causes A code P0300 may mean that one or more of the following has happened:
  • Faulty spark plugs or wires
  • Faulty coil (pack)
  • Faulty oxygen sensor(s)
  • Faulty fuel injector(s)
  • Faulty catalytic converter(s)
  • Stuck/blocked EGR valve / passages
  • Faulty camshaft position sensor
  • Defective computer
Possible Solutions If there are no symptoms, the simplest thing to do is to reset the code and see if it comes back.
If there are symptoms such as the engine is stumbling or hesitating, check all wiring and connectors that lead to the cylinders (i.e. spark plugs). Depending on how long the ignition components have been in the car, it may be a good idea to replace them as part of your regular maintenance schedule. I would suggest spark plugs, spark plug wires, distributor cap, and rotor (if applicable). Otherwise, check the coils (a.k.a. coil packs). In some cases, the catalytic converter has gone bad. If you smell rotten eggs in the exhaust, your cat converter needs to be replaced. I've also heard in other cases the problems were faulty fuel injectors.
Random misfires that jump around from one cylinder to another (read: P030x codes) also will set a P0300 code. The underlying cause is often a lean fuel condition, which may be due to a vacuum leak in the intake manifold or unmetered air getting past the airflow sensor, or an EGR valve that is stuck open
Posted on Jul 15, 2010
SOURCE: Monitor XVM-R70, NO SE ENCIENDE NI SE PONE EN MARCHA.
Tengo el mismo problema, lo pudiste solucionar.?, gracias
Posted on Aug 05, 2011
ercupa190
  • 12223 Answers
SOURCE: codigo para tv magnavox
vavya a la siguiente pagina;
www.fitness.manualsonline.com o www. remotecodelist.com
sinceramente.Dios le bendiga
Posted on May 08, 2012
Necesito los codigos del control remoto dish ir remote 103602 para programar television jvc de 27 pulgadas
Juan Francisco! Mi nombre es Kimberly y formo parte del departamento Social Media con DISH. Se que a este punto quizas mi ayuda ya no la necesite. Le proveere los pasos a como programar el control a su Tv por si en un futuro necesita la informacion. para que su control funcione con su TV, el control tiene que ser programado a la TV. Tendra que hacer lo siguiente: Siga este vinculo, http://www.mydish.com/support/apps/remotecodes.aspx seleccione el modelo de control (este se encuentra en la parte de atras del control) Una vez usted haga esto, seleccione el tipo de aparato al cual necesita programarlo (en su caso es TV) Y despues la marca de la TV. Una vez usted haga esto le aparecesaran los codigos que posiblemente funcionan con su TV. El procedimiento a programar su control es el siguiente Oprima el boton de T.V localizado en la parte de arriba en su control por 5 segundos, despues cuando vea que los botones de arriba se iluminan ingrese un codigo seguido por el signo de numero por ejemplo: 585#. El boton de t.v debe de iluminarce 3 veces, despues de esto puede intentar apagar el televisor, deberia funcionar. Si tiene preguntas adicionales por favor sientase libre de dejarme saber a kimberly.escobar@dish.com
May 10, 2013 | JVC Televison & Video
Manual aerio 2003,maf sensor
El sensor MAF (Mass Air Flow sensor) esta dise?ado para medir el flujo de aire que ingresa al motor, este dato viaja hasta el PCM (Powertrain Control Module - Computador) por medio de un cable el cual env?a una se?al de voltaje que cambia de acuerdo al flujo.
En algunos sensores MAF la se?al entregada es una corriente pulsante de frecuencia variable (en modelos General Motors, por ejemplo).
El sensor MAF mayormente difundido es el el llamado Sensor MAF por hilo caliente. En este sensor, internamente funciona mediante un hilo muy fino met?lico el cual se encuentra a muy alta temperatura, en el momento que comienza a entrar aire el aire enfr?a este hilo y las cargas cambiantes de aire causan un efecto diferente sobre la temperatura del hilo, entonces todo el circuito que maneja el tema del calentamiento del hilo generara una se?al de voltaje de acuerdo a que tanto es enfriado.
Esto se encuentra incorporado dentro del sensor, el cual va ubicado en el sistema de admisi?n del veh?culo, lo m?s pr?ximo al filtro de aire del motor.
Internamente existe un circuito que permanente monitorea los cambios de temperatura del hilo por medio de un transductor el?ctrico, esto dentro del sensor.
Espero que esto le ayude. Su opini?n es importante y yo agradezco su tiempo y consideraci?n si se deja alg?n comentario testimonial sobre esta respuesta.
Gracias por usar FixYa, y que tenga un gran d?a.
Oct 26, 2011 | 2003 Suzuki Aerio
CODIGOS PARA TV GE
HOLA TENGO UN CONTROL REMOTO UNIVERSAL STEREN RM 11 Y MI TELEVISOR ES GENERAL ELECTRIC ALGUIEN SABE QUE CODIGO ES
Mar 08, 2011 | DISH Network IR Remote Control
Transmicion
el aceite de la transmision es rosado y la pieza para checarlo se parece al del aceite del motor. dependiendo si es traccion trasera o delantera. si es trasera estara asta atras del motor a cual quier lado. si es frontal tendria que estar casi en el medio del compartimiento del motor casi a un lado de el bloque del motor.
Feb 21, 2010 | 1993 Honda Accord
COMO PROGRAMO LA TV A MI CONTROL REMOTO DE DISH
Hola! mi nombre es Kimberly Escobar trabajo con DISH Network. Para programar el control remoto con su television hay ciertos codigos que se pueden integrar al control para que pueda funcionar con la television estos codigo son diferentes dependiendo de la marca de televisor que tenga. Es importante saver cual es la marca para saber que codigo se va a integrar este link puede ser de mucha ayuda aqui puede encontrar los codigos necesarios y el procedimiento a como integrarlos http://www.dishnetwork.com/SupportSection/remote-setup si tiene preguntas adicionales o necesita mas ayuda por favor contactenos directamente al 1800-333-DISH.
Jan 16, 2010 | DISH Network IR Remote Control
Mi Equipo de sonido KENWOOD modelo UD-551M se apaga solo...
hola mi equipo kenwood ud551m tiene averiado micro funciones del amplificador donde lo puedo conseguir al componente gracias ana desde uruguay
Sep 19, 2009 | Kenwood CT 401 Hi-Fi Stereo Dual Cassette...
Unidad para disco duro SATA serie hitachi modelo
Sin importar el Sistema Operativo, este problema está relacionado con si el tablero principal de su sistema tiene o no los conectores necesarios para su unidad de disco SATA. La fuente de energía (en sistemas modernos) trae al menos dos cables de poder de este tipo, y dos más para IDE. Los cables SATA para la transmisión de los datos se compran por separado.
Si su sistema es de varios años de edad, es muy probable que no tenga ni los conectores SATA salientes de la fuente de poder para conectarlos a su nueva unidad, ni aquellos que se requieren para conectar el disco al tablero.
Una manera de hacer que funcione un disco SATA en un sistema que carece de sus conectores SATA es algo o muy fácil, o algo caro, pero ambos factibles.
1) Fácil: Compre un adaptador de SATA a IDE y conecte la nueva unidad de disco al adaptador, y luego éste al terminal existente IDE en el tablero. El único problema aparente es que no va a aprovechar de la velocidad mejorada del disco SATA.
2) Es posible que alguien venda un controlador SATA para estos sistemas, aunque personalmente no he visto un solo anuncio en las revistas que cubren la industria. Es muy probable entonces que esta opción no exista.
3) Una mejor solución es reemplazar el tablero por uno más moderno, aunque se corre el riesgo de que se necesite cambiar también otros componentes como la memoria, etc. lo cual no podría ser económico, pero se quedará como un equipo del último grito, dependiendo de cuánto esté dispuesto a gastar. Eso sí, si llega el momento que los componentes separados le cuestan más que un sistema nuevo, entonces esta última es su mejor opción.
Jul 12, 2009 | Computers & Internet
Mi problema es con una laptop Toshiba Satelite L300 es que me detecta vbarias senales de internet inhalambrica que se encuentran donde vivo pero no me deja conectarme me sale que tiene coneccion limitada...
Sabes que es encrypcion WEP o WPA?
Necetitas la llave correcta par decodificar un señal WIFI.
Parece que todos alrededor de ti han puesto en uso su encrypcion en el "router". Gratis no hay. No tienes subscripcion con un ISP (Internet Service Provider)? Regresa donde tu prima y pregunta si ella anda cual conexion con cual codigo :)
Mar 04, 2009 | Mozilla Firefox
Noggin
Cual es el numero de chassis?
Me parece que la r414 esta conectada al yugo y su valor es de 0.18 ohmios y 2 watt y el dz402 es un zener de 5.6 voltios.
Si la resistencia se esta quemando es posible que hay un corto circuito en el yugo.
Jan 31, 2008 | Televison & Video
183 people viewed this question
 Grubhead
Grubhead
