Question about Samsung Star GT-S5233 Cell Phone
I can't access you tube video - Samsung Star GT-S5233 Cell Phone
Why do I get you tube error loading messages when trying to access you tube videos on my I pad
Most likely your iPad is full... of pictures, videos, music, etc. Visit the Settings app, tap General, then Usage. In the STORAGE section at the top, you'll see how much of the storage is available on your iPad and how much is used. If the available number is small, you need to remove stuff until you have enough to handle incoming video streams (YouTube, for example).
The STORAGE section also identifies the apps that are using your space - if Music, Photos & Camera, or other apps seem to take a large portion of the space, either remove some of the data associated with those apps (pictures, movies, music) or remove apps themselves (apps you don't use don't need to be taking space on your iPad).
Portable devices aren't meant for large permanent storage. You should save things you intend to keep forever on your desktop device or in the cloud.
Oct 18, 2014 | Apple iPad 2
How do I access **** videos?
You Type: You Tube Video
Then at the top left of the site, put in your question, to watch
hundreds or thousands of videos
May 24, 2014 | YouTube Videos
I forget my password for you tube
On the YouTube sign-in page, click the "Can't access your account?" link just below the "Sign In" button.
Feb 22, 2013 | YouTube Videos
Kenmore 41784082500
To access the heater on this one you must remove the drum. To do so you pop the top. Then you remove the front. Then you release the idler after removing the rear access panel. Lift out the drum and inspect the heater for breaks. My home video:
My Blog with service manuals and more
Sep 03, 2012 | Kenmore Dryers
When I try to access my cisco e1000 router on firefox or google it keeps saying that it is busy and will not connect
Are you trying to access the setup page of the router?
Did you install the Cisco connect software on your main computer?
If you have cisco connect software installed then open Cisco connect.
Go to Router settings. Click on Advanced settings. It will open the setup page of your router.
If the cisco connect is not installed then try to power cycle the router. Unplug the power to the router, wait for 30 seconds. Plug in the power cable. Wait for 30 seconds.
Now try to access the setup page.
If that is also not working then I will suggest you to reset the router and reconfigure it manually.
Watch video.
How to reset Linksys router.
Watch Video:
Linksys router setup
Feb 24, 2012 | Cisco Linksys E1000 WirelessN Broadband...
Pakistan block the you tube
Youtube website is unblock now.
May 27, 2010 | YouTube Videos
You tube is being blocked in pakistan how i can access you tube
How i opened Youtube in pakistan as u know that its been restricted...
May 23, 2010 | YouTube Videos
You tube
IT SAYS NIETWORK ERROR IT CANT ACCESS IT TRY ANOTHER
Apr 22, 2009 | YouTube Videos
No you tube at all
Yue tube is going through a maintainance for due time , mean while to clarify it please to access youtube in different browser.
Dec 01, 2008 | YouTube Videos
GE 46GW9545 46" Rear projection
Sounds like that it could be a loose ground on the main board or the resistor r 4703,this resistor is next to the flyback,check to see if the tubes are lit at the video boards,access to see if they are lit is behind the speaker grill,there is a access panel behind the grill,if the tubes are not lit,then the ground or resistor is the trouble
Nov 12, 2007 | GE 46GW945 46" Rear Projection Television
Samsung Star GT-S5233 Cell Phone Logo
23 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
