Question about Hotpoint Washing Machines
F05 - Hotpoint Washing Machines
It is very hard to understand what's this question is about.
Posted on Aug 31, 2010
HOTPOINT WASHING MACHINE aq9f49u f05 fault code is coming on
Hello , I have the F05 fault also ... I have changed preasure switch and have checked the pump and no blockage. It goes through half a cycle then the F05 fault comes up and flashing lights .. Question ... should the pump turn freely if you turn it with your finger ?? Mine sort of judders ... Also when you tru it on a wash it does not draw any water in ??? Can you help please ??
thanks in advance
Malcolm .
Mar 06, 2013 | Hotpoint Washing Machines
Its dispalying error code F05
Code F05
Description:
Water temperature sensor error. If during the water heating step in the wash cycle, the water temperature sensor (NTC) value is out of range, the "F05" error code will be displayed.
Possible Causes / Procedure:
1. Unplug washer or disconnect power.
2. Check the water temperature sensor. Check connections to the water temperature sensor.
3. Check resistance of heating element, if present on this model. (abnormal = infinity).
Replace failed component.
Hope this helps (remember to rate and lave a testimonila about this free answer).
Sep 30, 2011 | Washing Machines
Whirlpool AWOEAST912 - Error code F05
Well An F05 is a water temperature sensor error.
This occurs if there is a problem detected during the heating step of the wash cycle.
You will need to check the Water Temperature Sensor, Heating Element and the Heating Element Relay.
But as you says that your washer is only 4 months old so why don't you ask for warranty......
Please post comments if you need more help or information........
Good Luck!!
Thanks
Mar 02, 2010 | Whirlpool Washing Machines
F05
F05 means pressure switch jammed on full.
Remove lower rear panel of washer.
Remove large black hose on bottom of drum.
Remove and clean filter inside hose.
Refit and test.
Please rate my solution.
Thankyou.
Feb 03, 2010 | Indesit W 123 Front Load Washer
Coming up on screen F05
Error code F05 means pressure switch jammed on full.
Remove lower rear cover of washer.
Locate and remove large black hose fastened to bottom of drum.
Remove hose onto pump, and check for blockage or obstruction here as well.
This should solve the problem.
Please leave feed back.
Thankyou.
Jan 10, 2010 | Hotpoint Ultima WF865 Front Load Washer
F05 on screen
Hi. This is a water temperature sensor issue.
Replace any parts that is malfunctioning or defective.
Oct 04, 2009 | Washing Machines
Err F05. We load it, then on start, it will seem to be
F05 fault is the pump circuit so it is probably blocked(check all outlet hoses as well)or at worst the pcb
Jul 06, 2009 | Washing Machines
Error code F05 after the start of wash cycle
F05 is a water temp sensor error ,could be a bad heating element, or the temp sensor may be faulty, try checking the connection's to the temp sensor and heating element, also check the element relay.
Apr 20, 2009 | Whirlpool GHW9100L Front Load Washer
ERROR CODE F05, FOR KENMORE ELITE HE3 WASHER MOD.110.43862400
Click on the following link for diagnoses and troubleshooting tips for the "F05" Error code.
http://www.fixya.com/support/r629462-f05_error_code_whirlpool_duet_kenmore
If you have questions and/or require further assistance, please post back and let me know. I hope this helps you.
Jun 12, 2008 | Washing Machines
F05 fault
Dear sir, F05 indication is for Video head hard indication. Check Video head is hard. If it is not clean Loading mechanism & Video head. Then check play with pre recorded cassatte. thank you & best of luck. Reply if any problem occurs. bye udupi
May 10, 2007 | Panasonic NV-MD9000EN Mini DV Digital...
Washing Machines Logo
24 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
