Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
The freezer of my whirlpool fridge/freezer does not work - but the fridge is ok. Sometime back I tried connecting it to a solar power system. Could this be the reason. If so what component could have gone wrong
  • Whirlpool Master
  • 43,501 Answers
No,
Check and make sure the unit is not froze up...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Aug 31, 2010
Whirlpool fridge WF258 freezer works perfectly; but fridge is in room temp, not working at all,light is ok
Damper door between freezer and fresh food not opening or build up of ice not letting cold air in fresh food side may have a defrost problem if you have a lot of ice on back wall of freezer
Nov 20, 2016 | Whirlpool Refrigerators
Side by side , fridge & freezer both stopped cooling last night, cleaned every thing this morning, unplugged for about 2 hours, plugged in and can hear fan running, but fridge and freezer do not seem...
did you feel the compressor runing?if not , need to check have power to the compressor. if power ok. i think the start relay or capacitor is bad. but make sure the condensor not drity. sometime it cause the problem. good luck
Jan 09, 2011 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
Whirlpool refrigerator
When you switch on the fridge, do you hear the sound of compressor working OR when you touch the fridge there is little vibration. If not then the power is not properly connected. Check the power supply cord and ensure that wires are connected properly. Also check the power outlet in the wall. If above is OK then you have to get the gas checked up. There may not be sufficient gas. If the gas is OK then the condenser/compressor is not functioning for that you have to call a technician from the technician from the service center.
Jun 30, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Whirlpool side by side Fridge Freezer S20BRBB20
Your fridge is simply not defrosting itself or moving air off the freezer coil. Try defrosting it and make sure the fan is operating. If the brains have been replaced already i do not think you should have to deal with them again unless consumer reports suggest otherwise.
Apr 30, 2010 | Whirlpool GC5NHAXSQ
I have a ten year old Whirlpool top freezer refrigerator that was recently repaired for non cooling. I believe my landlord replaced the thermostat but somehow was unable to properly reinstall the drainage...
Good day,
There is a drain cup in the rear top center of the fridge compartment that drains the water to the outside of the machine, down a drain pipe into the drain pan.
Hard to see the cup unless you use a hand mirror.
Dirt, can plug this cup and as well the hose and fittings in the back of the machine.
Removing this cup requires removing the front cover, and between cleaning it, the connection between the inside and outside of the machine and the drain hose can be tedious.
Don't force the situation. Shut the machine down, until it is completely defrosted.
Nov 21, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
User manual whirlpoolfridge freezer 20rid3 sf i have lost user manual
Call Whirlpool. The number should be on model tag inside freshfood. Either upper right or upper left.
Sep 08, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool Fridge Freezer not working fridge is
ID THERE FROST BUILDING UP IN THE FREEZER?IKE
Mar 14, 2009 | Whirlpool ET4WSKXS Top Freezer...
Whirlpool side by side refrigerator not defrosting.
take back panel off inside freezer. check continuity thro heater and thermal fuse in series with heater
Nov 17, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool side by side fridge freezer
 if posible try turning off over night, if its ok when you start it back up after 24hours, defrost not happening, ice builds up air flow is restricted
Oct 18, 2007 | Whirlpool ED2FHEXN Side by Side...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
101 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
