Question about Sony CDX-L280 CD Player
Cdx L-280 display gas failed. Unit works OK, button lights work, but no display of clock / frequency / track number etc. Is problem likely to be in the detachable panel? (Contacts have been cleaned, look OK.)
  • cjduffill Sep 01, 2010
    Thanks - I thought so, but can't find a source of parts, so I guess the unit has to be junked, Sad, not very eco-friendly, but the way of the world. Maybe 4 years service is all I should expect from Sony today!
  • Sony Master
  • 17,130 Answers
Unfortunately the display is damaged as it is the gas filled type. You cannot anything than to have this display unit replaced.
But first of all unless you have noticed a crack or a broken bulb end of the gas filling, the filament continutiy can be checked.
Then check on the 2.5 volt AC to the filament of the display.
If the glas is not damaged, filament voltage is ok, then the fault can be the display driver IC, check the rail negative voltage of the --32V and the working supply voltage of +5.
Only if the glass is intact.
Posted on Sep 01, 2010
  • 404 Answers
It is definitive the LCD display that is gone on the detachable panel. As much as I remember they can be replaced but am not sure about the cost.
Posted on Aug 31, 2010
Sony CDX-GT210 Can't find the reset button. Radio plays fine, but No sound comes out when I use CD player. Panel displays that it is able to read disk (numbers for time played goes up and displays...
Usually Reset button located underneath front panel, remove front panel and look at unit, hopefully you will see reset button, press it with some pointed thing like paper clip etc to reset the unit.
Thanks.
Aug 11, 2011 | Sony CDX-GT210 CD Player
We have a radio in our RV and no manual. It is a Jensen VR185. Can you help us to set the time on this radio.
Press T/F (7) momentarily to change the information displayed by the unit from mode-specific
information (radio frequency, CD track number, etc.) to the clock display. Press T/F again to
return to the default display.
The T/F button is also used to set the clock to the correct time. Press and hold T/F to enter into
clock set mode. When the time flashes on the display, rotate the volume control to adjust the
hours. When finished, press T/F again and rotate the volume control to adjust the minutes.
When no adjustments have been made for five seconds, the unit will resume normal operation.
You may also download the manual here:
http://www.jensenheavyduty.com/downloads/dl/file/id/96/vr185_owners_manual.pdf
Mar 07, 2011 | Jensen Car Audio & Video
SETTING CLOCK ON JENSEN PHASE PCD120U
Display Selector (DSP)
This unit can display either the clock time or
radio frequency/CD player functions. Ordinarily,
the radio frequency or CD player track
indication is displayed, but the unit will display
the time when the DSP button (18) is pressed.
The time will display for approximately 5
seconds then return to the radio or CD player
function display. The correct time-of-day can be
set by pressing and holding the DSP button.
Setting the Clock
To set the clock, perform the following steps:
1. Turn the vehicle ignition and radio on.
2. Press and hold the DSP button (18) until
the time display flashes.
3. Within 5 seconds, turn the MULTI/JOG
control (3) clockwise to adjust the minutes
to the desired setting.
4. Turn the MULTI/JOG control counterclockwise
to adjust the hour and the “AM”/
Jan 28, 2010 | Vehicle Parts & Accessories
Sony CDX-S2210 CD Player stuck on demo mode , cant adjust volume eq, skip track or anything
make sure the unit is switched off and the clock is displayed then
1 Press and hold (SEL).
The setup display appears.
2 Press (SEL) repeatedly until the
desired item appears.
3 Press the volume +/– button to select
the setting (example “ON” or “OFF”).
4 Press and hold
(SEL).
The setup is complete and the display returns
to normal play/reception mode.
Note
Displayed items will differ, depending on the source
and setting.
With the card remote commander
In step 3, to select the setting, press
< or ,.
The following items can be set (follow the page
reference for details):
“z” indicates the default settings.
*1 When the unit is turned off.
*2 When the audio output is set to “SUB.”
CLOCK-ADJ
(Clock Adjust)
(page 4)
BEEP To set “BEEP-ON” (z) or
“BEEP-OFF.”
SUB/REAR*1 To switch the audio output.
– “SUB” (z): to output to a
subwoofer.
– “REAR”: to output to a
power amplifier.
DIM (Dimmer) To change the brightness of the
display.
– “DIM-ON”: to dim the
display.
– “DIM-OFF” (z): to
deactivate the dimmer.
DEMO*1
(Demonstration)
To set “DEMO-ON” (z) or
“DEMO-OFF” (page 4).
A.SCRL
(Auto Scroll)
To scroll long displayed items
automatically when the group/
track is changed.
– “A.SCRL-ON”: to scroll.
– “A.SCRL-OFF” (z): to not
scroll.
LPF*2 (Low
Pass Filter)
To select the cut-off frequency
“78HZ,” “125HZ” or “OFF
Jan 28, 2010 | Sony CDX-S2210 CD Player
Buttons don't work. Sometimes when I click Source button several times, radio gets turned on if I have enough luck, but in most cases it's pointless), then I can change nothing. Volume change, programm...
Try resetting it. Remove front panel, on main unit is an indent that says reset, insert ballpoint to reset and replace front panel. Everything should now work although you will need to reset stations and clock.
Apr 18, 2009 | Sony CDX-L480X CD Player
Display doesn't display info....just bright light
Have you tried resetting the unit? Remove faceplate and push the reset button with a ball point pen. If it's a bluetooth model there is a different procedure.
Aug 25, 2017 | Sony CDX-M610 CD Player
SONY CDX-SW200 only tunes into odd frequencies?
Not unless he unit is capable. I know that Cadence made their decks with this feature, and I haven't seen anyone else as of a year ago.
Jan 26, 2009 | Sony CDX-SW200 AM/FM Compact Disc...
Set time on Sony CDX-L400x
Press and hold the [DiSPLay] button (in the bottom row of black buttons -number presets etc.- most to the right side) for a while, then the unit should enter "Clock Set" mode.
(likely that you've found a solution by now; but i might aswell add one for others having the same problem).
Nov 11, 2008 | Sony CDX-L400X CD Player
SETTING THE CLOCK IN THE CDX-F7700
press the display button until the time appears on the display (instead of the radio station or cd track). once on the time press and hold the display button and the time should flash. use the sel (aka select) button to jump from hours to minutes.
Oct 16, 2007 | Sony CDX-F7700 CD Player
Front display panel has power, but won't open
its usually the flexible pcb that connects the fascia to the main board thats snapped and therefore needs replacing
Aug 28, 2007 | Sony CDX-M800 CD Player
Sony CDX-L280 CD Player Logo
96 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
