Question about Troy-Bilt Pony Garden Tiller
My pony troy bilt 4 cycle 206cc BS wont pull/pulls weak is there a place for tranny oil
  • 112 Answers
SOURCE: i'm trying to find an operating and parts manual
go here http://troybilt.manuals-website.com/cgi-bin/pony_manuals.pl
Posted on Jul 15, 2009
  • 112 Answers
SOURCE: I have an older Troy-Bilt Pony Garden Tiller witha
From what I read you need a new rewind clutch and the spring and cord go into the housing. Briggs is easy to fix. contact me at kerryjonjon@yahoo.com and I can send you what you need or you can send it to me and I will repair it very cheap!! Parts are available at almost any small engine parts place.
Posted on Jul 18, 2009
al_kupchella
  • 843 Answers
SOURCE: broken pull cord on my manual start Troy-bilt Pony
It's definitely do-it-yourself in that no special tools or skills are required, but it can be a little tricky. You can see that the the recoil starter is in an assembly which is spot welded onto a metal cover. You have to remove the entire metal cover that includes the recoil starter. There may be 6 to 10 screws to remove to do that. When you get it off you will see a plastic spool that holds the cord. This spool is probably held in place by a couple of metal tabs that are bent down. Bend those tabs up with pliers. Underneath the spool is a spiral spring that provides the recoil. Take careful note of how this all goes together. Buy a new cord (available by the foot at a hardware store) and wrap it around the plastic spool. Use a piece of tape to hold the end of the new cord above the spool so you can thread it through the hole in the metal housing later. Put the spring and the spool in place, then wind the spool to put tension on the spring - about 5 turns in the direction that would push the string out through the hole. Once you have the spring "wound up" remove the tape and thread the end of the cord through the hole. Now bend those metal tabs back down. Put the handle on the cord end (or tie a knot) to keep the spring from pulling the end of the cord back through the hole. Reassemble the rest and you are in business.
Posted on Jun 15, 2010
  • 26 Answers
SOURCE: i need a free owners manual
http://manuals.mtdproducts.com/mtd/Public.do
Go to the above website and type in 12211 for your model number and 1 for your serial number. You will be able to download a free copy.
Frank
Posted on Oct 08, 2010
jyackle5
  • 8197 Answers
SOURCE: looking for manuel for pony
You can get the manual on the link below.
http://www.troybilt.com/wcsstore/TroyBiltUS-CAS/Attachment/ownersManuals/tillers/769-03556.pdf
Posted on Feb 20, 2011
Troy bilt pony,moves so fastu cant hold it back,??????
I found that when you have the tiller at full throttle it can get away easily. Try pulling back the speed a bit and change the depth of the tines to grab a bit more but not enough to launch it. Good luck! Hope this helps you. Cheers, Michele
Oct 20, 2014 | Troy-Bilt Pony Garden Tiller
Troy bilt pull cord wont retract
Recoil spring is broken or slipped out of retention slot. Coil needs to be retentioned or replaced. Unless you have done this before I recommend taking to pro. This is easy job if you have the jig but almost impossible if you don't.
Jun 29, 2014 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
My 4-cycle troy-bilt string trimmer: string is locked up. I can not pull the string
Your String needs to be re-wound. You are almost out of string or your string has Jammed under the Motor and placing a DRAG on the Trimmer
Apr 08, 2013 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
What oil used in transmission
Troy-Bilt says that if adding a few ounces only, use GL-4 or GL-5 gear oil. If refilling an empty transmission, use GL-4, with a viscosity of SAE 85W-140 or SAE 140.
Best regards, --W/D--
Mar 08, 2011 | Troy-Bilt Pony Garden Tiller
Reverse belt or transmission won't lock into place
The reverse on the Pony tiller will not lock. You pull back on the reverse lever and as soon as you let go it will stop. This is normal operation for reverse.
Frank
Aug 30, 2010 | Troy-Bilt Pony Garden Tiller
What oil goes in the gearbox behind the motor , I have a junior
any type of gear oil will work for this. I know some gardners that use tranny fluid for heat
May 04, 2010 | Troy-Bilt Pony Garden Tiller
Jul 17, 2009 | Troy-Bilt Pony Garden Tiller
Trot Bilt 4 cycle weed eater catches, but wont run.
rebuild carb to fix problem.let me know if this help you.ok
Jul 12, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
What type oil goes in the tranmission?
Trans oil! 90 or 140 wt.
I use 140 in my older tiller.
G
Feb 10, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Troy-Bilt Pony Garden Tiller Logo
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
