Question about Vacuums
Went to turn it on after not using for several weeks and it states not ready to brew like usual but after about four minutes it just turns off. Wont let us brew a cup or access the menu even to choose size of cup or anything. It sounds like it's sucking up water to make cup and pokes hole in the coffee but nothing more than that. It is almost brand new
  • A Miller Aug 31, 2010
    Is this a coffee pot vaccum cleaner combo?
  • 17,130 Answers
You have posted the fault in the wrong column with no instruction of the make/model.
Assuming it to be new , Is it passed the warranty period before we take a look ,?
Just lave it on for sometime and see if there is any change. perhaps the controller is thinking different with some errors , so lets try that it will stabilise with the stteady power inside.
check this out and comment.
Posted on Aug 31, 2010
I HAVE THE BISSELL 3031123, BOUGHT USED, NOTICED IT WOULDN'T PICK UP ANYTHING, THE BELT IS BROKEN, LOOKS MELTED, WHAT WOULD CAUSE THIS AND IS THERE ANYTHING I CAN DO TO FIX THIS?
Sounds like the brush is stuck. When that happens the belt continues to run, quickly burning up. Take the brush out and clean both ends(bearings) and check that something is keeping the brush from turning. It's a fifteen minute procedure, and to save time pick up a belt or three (usually come 2+ in a bag) and you'll be ready.
Apr 04, 2017 | Bissell Vacuums
After operationg for approximately 10 minutes my Dyson vacuum shuts off and wont restart for several hours.
Hello, this is Ava with Think Crucial.
Most Dyson vacuums have a built in safety system that stops the machine if it begins to overheat. This usually happens because the filter needs washing or your machine is blocked. If your machine turns off on its own, unplug it and leave it for at least an hour to cool down. Remember to check the filter and look for blockages before re-starting.
You can purchase a wide variety of high quality Dyson replacement parts for your Dyson vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=dyson
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
May 01, 2012 | Dyson DC15 All Floors - The Ball Bagless...
What does "check OP" mean
This means that the weather radio has not received the weekly test signals for over a week. Turn the radio off and then back on. Next set the radio to announce the current weather (on my unit the button is marked Weather) and listen to the broadcast. If you do not hear the broadcast, move the radio until you do.
If you can't get a good signal, check the NOAA site for your coverage area to see if the local emergency alert broadcast towers are under repair. If needed try one of the other towers that cover your county. Sometimes you may get one location better than the others if you are near the edge of the county or are surrounded by hills. http://www.weather.gov/nwr/Maps/ has the maps by state and those link to the frequency of each tower that can be heard in a given county.
If the radio still fails to hear the test alerts, you may need an external antenna or a new radio. (Caution: the external antenna may hear a more distant tower and not give your local alert. We got the wrong state on one radio.)
(who has one weather radio on each side of the house set to two different towers. I live 2 miles from the state line. We had severe weather a few days ago and only the in-state tower broadcast the severe weather watch. The local television stations displayed different watches and warnings depending on which NOAA coverage area they checked.)
Apr 16, 2011 | Vacuums
Poor flow takes two cycles to brew one cup. Heater working etc. Something stuck inside inner tube? Sucking air somewhere? can it be dis assembled?
This problem is usually caused by calcium carbonate deposits from hard water collecting in the thermal pump mechanism. The fix is to make a 1/2 pot mixture of white vinegar and cold water (about 50:50) and run through several times. Let cool off each time, and use a clean filter to catch the deposits that are removed. Finally, run several pots of cold water to wash out the vinegar taste. Hope this helps!
Jun 25, 2010 | Vacuums
Fairly new Platinum series Hoover Max extract wont turn on
I have the same problem. Fairly new machine, only been used a handful of times and now it wont turn on.
Feb 18, 2010 | Vacuums
I bought it in may , I can honestly say , it is THE worst vaccum
There are several filters on bag-less vacuums that need to be cleaned. Dig out your owners manual or open the one below. See section 3 for filters and maintenance. If you are vacuuming a house bigger than about 1500 square feet, you should be cleaning the filters every other use. Personally, after using a bagless for a couple of months, I went back to my bagged vacuum.
http://www.hoover.com/pdfs/manuals/U6630900.pdf
Dec 20, 2009 | Hoover U6630-900 WindTunnel Bagless...
Vacumm when hot will not turn on
My hoover Windtunnel has a 30 minute delay according to the instruction book, if it overheats. Then it resets itself and is ready to go again.
You might check for blockages and check your filters if it is doing this so easily.
Aug 03, 2009 | Hoover U5753-900 WindTunnel Bagless...
My electrolux ergorapido wont power on . Have only used it a few times. It has been on the charger for approximately 2 weeks without use.
If it will not come on there are several things you need to check. First off you should call and have your model type and serial number checked to be sure your unit isnt affected by the recall they had due to expanding batteries. Second you do have a 2 year warranty on the unit and if it wont even turn on there may be a defect. Are the blue charging lights coming on? If they are and your transformer is warm then there is more then likely a defective battery in the unit and you should contact customer service at 1800-896-9756
Jul 18, 2009 | Black & Decker AV1200 DustBuster Handheld...
Will not turn on
Leave it unplugged for a half hour then try it. But it sounds like it may have received a power surge or several. This could have fried the motor. The motor may have to be replaced.
May 11, 2009 | Rainbow E series Canister Wet/Dry Vacuum
I was vacuuming then all of a sudden the vac turned off and wont go back on. i thought the bag might be full so i emptied it and still it wont go back on
Greetings from GoVacuum.com,
There maybe several things wrong with the vacuum at this point. When a vacuum cleaner doesn't turn on, it usually is 1 of several things. It's either a reset button on the machine, the cord, the plug, the switch or the motor. One of these things have gone bad in your machine.
If you'd be so kind as to let me know your make and model, I can help you diagnosis the vacuum to find out what went bad.
Please email me your make and model to chris.jones@govacuum.com
Chris Jones
GoVacuum.com
Oct 15, 2008 | Vacuums
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
