Question about Lexmark Office Equipment & Supplies
My computer crashed and now it is not recognizing my printer. I have looked everywhere and cannot find my startup disk. What can I do?
  • 8,404 Answers
Get the driver you need from <a rel='nofollow' href="http://www.lexmark.com/support">www.lexmark.com/support</a>
Posted on Aug 31, 2010
Flashing folder when i turn on mac
Your hard drive may have crashed or it's settings have changed so it is no longer recognized as a startup (boot) drive. Try starting from your original operating system CD. (or borrow one). Press the C button at power up to force your computer to start from the CD.
Once started, don't install the operating system. Go to the pull down menu's and select Disk Utility. If Disk Utility sees your hard drive, select it and run the repair disk program. If it doesn't see it, your hard drive has likely crashed. You will have to replace it, install a new copy of the operating system, and likely have lost all your data and documents. This is where I would start.
Mar 08, 2014 | Apple MacBook Pro Laptop Computer with...
My macbook pro OS 10.6.4 either freezes or crashes on startup. Crashed when trying to startup with Drive Genious 3, TechTool Pro 5, System Disk or Disk Warrior. Not sure what to do next. Tried holding ...
Restart your mac. As it's restarting/booting up, hold down the command, option, R and P keys simultaneously. As it's booting up and you're holding these keys, you should hear the startup chime, continue to hold the keys down, it will cycle and you'll hear the startup chimes again. Let it go thru this cycle 7 (seven) times before you let up on those keys. Once it's cycled 7 times, let it boot up normally.
If that doesn't work, then reinstall the original system software that came with the Macbook. You may have to reformat the hard disk and do a clean install.
Jul 05, 2010 | Apple MacBook Pro Laptop Computer with...
Recently crashed. reloaded with original recovery
After you restore your computer, you must also reinstall the drivers for things like your wireless receiver. This is found on the Drivers disk, also gotten with your computer. Follow directions to recover all drivers are found on the disk.
Dec 13, 2009 | Toshiba Satellite A60 Notebook
Startup repair won't run
"Unmountable boot volume" this problem is your hard disk partition which is failure to recognize & identify the operating system running on the hard disk. Reformat your hard disk and put another operating system to run again your computer.
Jul 27, 2009 | Computers & Internet
After my computer crashed and then got fixed it
hi
you would have to reinstall the drivers for the printer again
if you have the original CDs that were given with the printer try installing using them else try the weblink
http://supportapj.dell.com/support/topics/global.aspx/support/product_support/en/product_support_central?c=in&l=en&SystemID=PRN_ALL_A940&cs=&s=gen
cheers
Jun 23, 2009 | Dell A940 All-In-One InkJet Printer
720 and 540 Dell printer communication problems
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came withthe printer. When the software program asks you to connect theprinter to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 28, 2009 | Dell Inkjet 720 Printer
X6570
printer did work with computer before it crashed.
Oct 19, 2008 | Lexmark X6150 All-In-One InkJet Printer
Installation
I need to know the model of your printer ????
Thank you !
Mar 26, 2008 | HP Officejet 5610 All-In-One InkJet...
LOST STARTUP DISC
Here is a link for driver and software. Just choose your operating system and it will show you what you need. If you're not sure, I would download the driver and the ez instructions first. Then you can get your software. http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=357&modelid=11642
If this was what you were looking for please rate a big 4 fix ya. If you need more help with this just post a comment and I'll be glad to come back and help you.
Mar 25, 2008 | Canon PIXMA iP1600 Printer
Installing windows without DVD
The hard disk is not recognized from USB because of SATA drivers not present on XP setup disk.
That happens because the BIOS uses a SATA controller that is not included in Windows XP install disk.
Usually you can solve the problem going to BIOS settings and changing SATA/RAID settings.Check your BIOS settings, and disable SATA RAID mode.This is done in different ways depending on the BIOS.
On HP/Compaq computers for example you press F2 on startup to enter BIOS, then disable SATA mode on bios settings.
On other makes the procedure can be slightly different.
Another way to fix the problem, is by creating your own XP setup disk with SATA drivers included, see:
Resolving "Setup did not find any hard disk drives" during Windows .
Mar 17, 2008 | Toshiba Portege M205-S810 Tablet PC
21 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
