Question about HP DeskJet 712c InkJet Printer
Deskjet 712c i try to print and it tells me that my printer spools are not running
    Genius:
  • 3,587 Answers
Yes..that means there is something amiss with your print drivers or print manager.
www.hp.com is a good place to get new versions of each.
Posted on May 10, 2008
My DeskJet 712C will not print anything when I try printing in color, it will, however, print with just black when I set it to do so. How do I get it to print in color, too?
Blocked print head nozzles
Inkjet printers need to be used frequently to prevent blocked print head nozzles. You may have blocked print head nozzles.
Try the printer maintenance to clear the printer nozzles.
After several deep cleaning attempts and there is no improvements in the print then a new print head is required. Also try - Removing the print head, run it under hot water for 2 mins, then let soak for 10 min. then used a can of compressed air to dry thoroughly. It may fix the blocked nozzles.
A new print head maybe expensive and it maybe more cost effective to purchase a new printer.
Sep 07, 2012 | HP DeskJet 712c InkJet Printer
My HP DeskJet 712c InkJet Printer's "ink light" won't stop blinking!! I have tried changing ink cardridges, checking for paper jams, unplugging and replugging cords and re-starting computer. None...
Hello.
Give this a try:
1. Power off your printer
2. Remove and reinsert the cartridges. You should hear a "click" when properly seated.
3. Power on printer.
4. If light is out, print a test page for realignment.
Note: Be certain that the tab is removed from the cartridges and you are using "genuine" HP cartridges.
Hope this helps.
Oct 31, 2010 | HP DeskJet 712c InkJet Printer
My hp 712c printer prints only the pink band when I run a color test. I have replaced the original cartridge. Any ideas about the cause and solution.
The cause is either:
* clogged ink-jets not allowing yellow & blue ink to move from the ink-cartridge onto the paper;
* busted electronics inside the printer, causing the ink-jets to not "spray" at all.
Use the software to try a "print-head-cleaning" cycle.
If that fails to improve things, it's time to replace the printer.
Jun 24, 2010 | HP DeskJet 712c InkJet Printer
HP Deskjet 712c Printer will not print in black & white
you need to check the head of the printer, im sure is bad, it depends how old is the printer but the head on the printer goes bad if printer has not been used for long time or if you left the old empty cartridge seating inside for a lont time, you can do a head check on the settings of the printer and also do an alignment thank you
Jun 16, 2009 | HP 5069-4515 Keyboard
1: the paper jams when it tries to print
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 11, 2009 | HP DeskJet 712c InkJet Printer
Can't get rid of blinking cartridge light on hp deskjet 712c
maybe they need replaced..if already done..then run a calibration and clean cycle from print manager panel
Oct 13, 2008 | HP DeskJet 712c InkJet Printer
HP Deskjet 712c prints only blank
I had the same problem and what worked for me was to make a PDF and then check the box "print color as black" I only say this is a fix because I was desperate. I realize this is a time consuming workaround. also if you are going to do this make sure that your printer settings are for Color but then the print color as black box is checked. hope that helps.....
Jan 25, 2008 | HP DeskJet 712c InkJet Printer
Macintosh Printer Driver for HP Deskjet 712C
Try downloading GutenPrint 5.1.4 It is a collection of open source printer drivers. Based on reviews and comments, it seems to have worked with older printers.
Dec 24, 2007 | Apple MacBook Pro Laptop Computer with...
Hp deskjet 3325 not printing
I don't think it is a printer problem as such more a communication problem. Un install the printer software. Close down the Computer. Unplug the printer. Start the computer. Come off line. Disable the A/V software. Run the installation disk only plug in printer when prompted Tell us what happens
Jul 10, 2007 | HP DeskJet 3325 InkJet Printer
HP DeskJet 712c InkJet Printer Logo
54 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
