Question about Ricoh Office Equipment & Supplies
How to install ricoh aficio mp 2000le scanner
  • Anonymous Mar 22, 2014
    the paper is getting creases while coming out
    Guru:
  • 377 Answers
If you have user manual read it
do you have driver cd?
In most cases you will find that the Windows drivers found here are "self-extracting" (.exe) archives. Click the desired file. When prompted, we recommend setting the destination to your desktop. Create a new folder and move the archive into it. Click the file, it will then extract the software and related files inside of your new folder automatically. Alternately you may extract or move these files to a floppy disk. Please note that these files will only self-extract if executed from Windows. After extracting the files to a disk or a special directory, you should look for the installation program which is usually called "setup.exe" or "install.exe", click it to begin installation. If neither of these files are present, you should look for a text file containing special instructions called "Readme.txt" or something similar.
Sometimes there is no installation program because you must install your driver via the Windows "Add Printer" function. Instructions for installing printers can be found in the Windows help file.
Our Macintosh Archives are also self-extracting archives. These files should be downloaded and then executed. The installer will be present on the desktop when done. Click the installer and follow the instructions to install.
Types of Printer Drivers:
  • PCL5e Driver - Technically, the PCL5e has been superceded by PCL6, however, we make this driver available because the layout of some documents may be altered if they are originally created for a PCL5 compliant printer, but are printed using PCL6. PCL6 Driver - PCL6 is a good general purpose text / graphics driver. Ideal for Spreadsheets, Word Processing and Database printouts. It features superior graphics handling, although graphically better than the PCL5e driver it's speed is typically slower.
  • PS3 Driver - The Adobe Postscript Driver is generally superior to all, but it requires a Postscript compatable printer and can be a little more complex to install.
  • IPDL-C Driver - This is a color printer driver designed specifically for optimal perfomance under Windows.
Posted on Aug 31, 2010
Our Gestetner MP 2000Le have an error sc551 and we can't troubleshoot it using the (Clear mode+107+hold the Clear/stop button) ..can you pls. advice us for other options ? tnx
Enter in the service mode: Clear(yellow key) 107 press/hold Clear/Stop more 4 second,enter in the SP mode open the front cover ,turn OFF the copier,wait 1-2 minutes close the front cover and turn ON the copier.
Jan 30, 2013 | Ricoh Aficio MP 2000 Black and White...
I want driver full Aficio mp 2000Le
I believe this is what you want:
http://support.ricoh.com/bb/html/dr_ut_e/re/model/mp16/mp16en.htm
Hope this helps!
Remember to Thumb me Up lots for all the hard work! :D
~~Dayminner
Jun 03, 2011 | Computers & Internet
I would like to install recoh aficio MP 2000Le for window7
you can download printer driver for ricoh offical site. for windows 7
Apr 11, 2011 | Ricoh Aficio MP 2000 Black and White...
We have a network ricoh aficio mp 1600 pcl printer we recently upgraded to windows 7 printer and copier are working ok but scanner is not working is there a problem with the scanner driver for windows 7
please go to www.ricoh.com and instal the scanner drivers of windows-7 other wise you can instal the scan to folder which dos not required any drivers or you can install scan to mail this also does not required any drivers - thanks
Mar 10, 2011 | Ricoh Aficio MP 1600L Black and White...
My 2000le says error occured 982
you machine language does not match your country language. you have to change the language settings in the copier SP mode. only a Ricoh technician can change it. please consult a Ricoh Technician as you cannot enter the machines SP mode.
Nov 29, 2010 | Ricoh Aficio MP 2000 Black and White...
Sir, My copier model RICOH MP 2000Le shows error . ADD TONER & some time it shows SC 302
sc 302 - charge roller current leak. strip the drum unit (dmu) and clean the unit
Sep 04, 2010 | Ricoh Aficio MP 2000 Black and White...
I would like to install ricoh aficio MP 2000 Le printer driver form the net.
how to install ricoh mp 2000le printer driver for windows 7
Jun 19, 2010 | Computers & Internet
Scanning problem printer name is ricoh aficio mp 2000le
parinter in 1 print but cantinu print in sol inhelp
Apr 30, 2010 | Ricoh Aficio MP1600L Printer
5,555 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
