Question about Samsung DV328AG Gas Dryer
The dryer is not heating up during drying cycle. The heat source is gas. I have cleaned out both the lint basket and the outlet that vents to the outside of the house.
  • Samsung Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Sep 04, 2010
Dryer taking to long to dry
Overloading
1. One of the simplest problems to remedy could simply be that you are putting too many items inside the machine during the drying cycle. Avoid overloading your dryer, as this might cause your dryer to work extra hard to dry your clothing, extending the length of the dry cycle.
Wrong Heat Setting
2. A common issue with clothes dryers could be the wrong heat setting. Most home dryers feature several settings, from low heat settings to high heat and permanent press. Be sure the setting you choose is right for your needs. Another setting to check is the load size of your dryer. If you are drying a large amount of clothes, be sure the setting for large loads on high heat is selected. Choosing the wrong heat setting or load size can cause your clothes and linens to take longer to dry.
Lint Trap
3. One of the simplest fixes for drying issues might just be that your lint trap is clogged. Each time you use your dryer, lint will form in the trap. If the lint trap and vents are full, this could block air going into your dryer and slow down if not completely stop the drying process. After you use your dryer, remove this lint trap and empty it fully. Even if the lint trap is full, your other dryer vents might be clogged as well.
Clogged Vents
4. If your clothes are in the dryer for a long amount of time, but still not drying, the reason for this could be a clogged vent. A sign that your vent is clogged is if your clothes are warm or hot to the touch after sitting in the dryer, but still damp. To unclog your dryer vent, you may need professional assistance. This is especially necessary if your dryer vent leading out of the house is particularly long.
Heat Source
5. If the dryer is not getting enough heat to dry your clothes,something could be wrong with the heating system. After the drying cycle, touch your clothes to see if they are warm. If not, this means that the heating mechanism is malfunctioning. It will need to be repaired or replaced by a professional.
Feb 28, 2011 | GE Profile Harmony DPGT750GC Gas Dryer
We have a Kenmore 400 Series dryer. It heats up but our clothes is not getting dry. We have to cycle it twice to get our clothes dry on high heat. Any idea why it would take 2 cycles to dry?
This was the out vent of my dryer... If it gets this bad... open up the dryer housing and clean inside too. Also make sure the intake is free of lint.
Aug 23, 2010 | Kenmore 74602 Gas Dryer
Dryer is taking multiple cycles to dry average weighted clothes/
Make sure the dryer heats up and that the proper cycle is selected. If the dryer doesn't heat, the cause will need to be determined. This can be an ignitor issue, the timer, or a gas supply problem.
If it's heating, check the vent line from the dryer to the outside of the dwelling for lint clogging. Also check the diverter (flapper valve) at the dryer vent outlet to be sure it opens all the way and that the air stream is pretty strong. Lint clogging is one of the most the most common causes of dryers not drying very well or taking an extended drying time period.
If the vent line is longer than 20 feet and has multiple bends, backpressure in the line can cause additional clogging.
Jan 25, 2010 | Whirlpool LGR3624JQ Gas Dryer
Dryer is emitting dryer dust during dry cycle. Vent is not clogged and vent screen is cleaned after each dry cycle. Lots of dust escaping the system during dry cycle.
You've got a hole in the 4" tubing that connects the dryer to the outside vent. Airflow in the dryer is a closed system and the only way lint can escape is if there's a hole somewhere. The vent hose is by far the most likely source of your lint problem.
Aug 21, 2009 | Dryers
Dryer heats up ands pins, but it takes forever to
Hi, First thing to check is the 4" venting to the outside. Make sure it is free of any lint and that there are no kinks in the hose. If this is a gas dryer, the couls on top if the gas valve could be getting over heated and not opening the gas valve later in the cycle so there will be no heat.
Please let me know if this helps you or if I can assist you further.
Thanks
Vic
Jul 15, 2009 | Dryers
Dryer not drying after 2 or 3 cycles
I would say so if the blower is not blowing then the hot air is not moving through the clothing as well and the lint would build up if you go outside and check the outlet vent and your not feeling any air then its not blowing. also if it is an older dryer make sure that the vent is not blocked my mother lives in the country and on windy days she has to go through at least 2 cycles to get them dry because tthe wind blows the vent shut... she has a brand new maytag dryer. good luck
May 22, 2009 | Kenmore Dryers
Lint basket keeps falling out during drying.
Bent the spring tabs to tighten the hold of the basket to back of the drum . If that doesn't work you will have to buy a new one. I found that a lot are damaged by heat.
Apr 27, 2009 | GE WSM2780DWW Unitized Spacemaker Washer...
Heating element stays on
stat or a clogged vent system. Clean any lint from the internal and external ductwork, and/or replace the cycling thermostat (read about cycling thermostats in "Drying is too slow," above).
Drying is too slow It normally takes about 45 minutes for a dryer to dry a full load. If your dryer is taking more than an hour, check these.
Vent
Heating element
Internal ductwork
Cycling thermostat
Vent Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance.
Heating element Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it.
Internal ductwork Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician.
Cycling thermostat Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork with two screws.
Mar 07, 2009 | Whirlpool LER7646J Dryer
Will not dry clothes fully. the machine heats fine but it takes two or more cycles to fully dry a little load. someone told me about a part that may need repaced around the lint trap.. Any ideas?
Your lint exhaust is blocking the heat flow.
Remove the vent from the rear of the dryer and run a timed cycle load for 40 minutes.
If laundry is dry, repair the outside vent.
If not dry,open the dryer cabinet and clean the inside lint and heat vent.
Mar 05, 2009 | Kenmore Dryers
Kenmore 110.72512101 gas dryer
Are you getting little or no lint on the lint screen? Are the clothes coming out nearly as wet as they went in, but feel warm? If so, you probably have a blockage somewhere in the vent/duct. Don't just check the back of the dryer, but also check the duct thru the wall and the point where it exits the house (exterior wall or roof). Many times birds will nest in the exterior vents or if they have a screen to keep the birds out it may become clogged with lint. If you have a window nearby try drying a load with the vent hose disconnected from the wall and hang it out the window (you COULD vent it into the house, but you may end up with lint everywhere and a lot of moisture in your house).
Jan 02, 2008 | Kenmore 75944 Gas Dryer
Samsung DV328AG Gas Dryer Logo
239 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
