Question about Panasonic TOUGHBOOK CF-18 Tablet PC
I have a panasonic toughbook cf18KHHZBZZ with 60 GB HDD and when i turne it on i get the panasonic screen.....the xp windows screen.... and then a black screen with only the mouse pointer to work but on a black screen. I tried the safe mode but the same result except that it says safe mode on the four corners of the screenand the xp version on top of the screen. I tried the normal mode with the black screen finally again. before it showed up with the problem it was for a long time trying to configure windows office 2003 for un upgrade, and i tried to stop the procedure with the task manager, and finally i turned it off with the power button
  • Piyal Perera
    Piyal Perera Aug 31, 2010
    Do you have the Windows XP CD with you?
  • cnstt Sep 01, 2010
    yes, but i would not like to proceed with any kind of frmat
  • 528 Answers
OK, you don't need to format. You can insert the CD and restart. You can ask to install but then the computer will say you already have a OS installed. You can press R to repair the OS. Your computer may have a recovery method. Some vendors don't give you a CD but recovery system is fed into a separate partition of the hard disk. See the documentation and check whether you have such a system.
Please feel free to ask for advice any time.
Repairing a OS is quite safe. You will not loose any software or updates.
Remember, don't press R at the first screen where you are given a chance to go to recovery console. There is very little you could do there. First ask to install then ask to repair the existing one.
After repairing the system, the first thing you need to do is to install a reliable Antivirus Software.
Posted on Sep 02, 2010
How can I fix Toughbook
If you screen was dimming on your Toughbook, then try to
attach an external VGA monitor when the Toughbook is
turned off, then power on the external monitor,
then power-on the external screen.
If the external screen works, then you may have a bad
inverter if you TB is 2007 or before.
If the TB is 2008 or 2009 or later, then probably your screen
is NOT LCD with an inverter but instead LED. Which means
that you have to replace the entire LED screen.
Good Luck!
Regards,
Richard - Montreal Based
Panasonic Canada Toughbook Authorized Dealer since 1989
Apr 16, 2014 | Panasonic Toughbook Tablets & eReaders
Rotate windows on a toughbook
Is it just that the window is upside down??
1. Try pressing Ctrl + Alt + arrow (left, right, up or down) to rotate the screen.
2.Press the hotkeys and arrow keys until you have the desired rotation. This works with most video drivers on Windows XP. If this doesn't work let us know.
Dec 09, 2010 | Panasonic TOUGHBOOK CF-18 Tablet PC
Hello i have a panasonic cf18 toughbook that it need to change its windows xp all,after change of it there is a problem left, and it is :all of its facilities such as touch screen,modem,bluetooth...dont...
you should find those drivers on the panasonic support site---if not, go to driverguide.com---
there are 1,000's of free drivers you can download for free.
Oct 14, 2010 | Panasonic TOUGHBOOK CF-18 Tablet PC
Screen is illuminated but blank.
Can you try restarting the Tablet and see if you get a result by tapping the F8 key?..on windows,that will put it into safemode and allow you do fix certain problems...please let me know..will try to get u fixed up
Apr 13, 2010 | Panasonic Toughbook-19 Tablet PC
Panasonic TOUGHBOOK CF-18 Took out HD to reload windows as it would not load but stuck at the safe / last known good config etc. Loaded XP onto HD via an ACER laptop and reinserted it into ToughBook -...
I think your actually having issues getting it to run on the toughbook because it uses different drivers for everything from the Acer computer. If you press F8 while booting up you can choose the option "Disable automatic restart (of system errors or something)". Then when the machine boots up you should get a blue screen giving you an error code like "IRQ_EQUAL_TO_OR_GREATER_X Error: 0x0000005f. You could try to see what the message is trying to tell you to resolve it but the error msg would likely point to the driver that its trying to load that's most likely different from the toughbook you have. I'd suggest getting an external cdrom/dvdrom and install windows from a disc onto the toughbooks hd while its in that toughbook machine.
Dec 21, 2009 | Panasonic TOUGHBOOK CF-18 Tablet PC
I need to buy a CF-18 HDD caddy and HDD where can I find one
Hello there:
Here is a couple of links for this for you to consider
I know that ebay has them but here is a couple of diffferent places for you to look at
  1. Hard drive for Panasonic cf18 - TabletPCBuzz - The Best Place to ... 3 posts - 3 authors - Last post: Aug 11Hard drive for Panasonic cf18 General Tablet PC Discussion. ... The ruggedness comes from the drive cage/caddy, not the drive itself. ...
    www.tabletpcbuzz.com › ... › General Tablet PC Discussion - Cached - Similar
  2. Replacement HDD for Toughbook CF-18 - CNET Miscellaneous laptop ... 7 posts - 2 authors - Last post: Nov 6, 2007... HDD for Toughbook CF-18 - Get tips and advice on this topic, ... to purchase is a caddy (shopping for a good price), HDD,(naturally, ...
    forums.cnet.com/5208-7587_102-0.html?threadID=270788 - Cached - Similar
Dec 16, 2009 | Panasonic Toughbook-18 Tablet PC
Can I install windows 7 on a panasonic toughbook cf-18 tablet
I don't thank they have it out for tablet yet. Wait a bit and they should.
Nov 11, 2009 | Panasonic TOUGHBOOK CF-18 Tablet PC
Installation of windows xp to toshiba satellite 1695CDT
10gb of RAM is not enough for Windows XP. You need to upgrade your HDD to about atleast 40 GB HDD Minimal... I'd recommend a new PC if you can get that to work out, but I understand the tuff economical times.. If you need any mroe help ..throw me an email at joey@joeysitservices.com I'll give you some bootable tools that may help!
Apr 16, 2009 | Toshiba (K000680310) for Satellite...
Panasonic touchbook cf18
When I touch the touch pad my screen display goes off. it comes on sometimes by itself or when touch pad is touched. I have connected the toughbook to an external dispaly and can work no problems. help
Oct 22, 2008 | Panasonic TOUGHBOOK CF-18 Tablet PC
Panasonic TOUGHBOOK CF-18 Tablet PC Logo
545 people viewed this question
Top Panasonic Tablets & eReaders Experts
Michael Galve
Michael Galve
Piyal Perera
Piyal Perera
Jerry Umali
Are you a Panasonic Tablet and eReader Expert? Answer questions, earn points and help others
