Back to:
Tags:
Clock Radios
Generic problem for all Clock Radios
How to set time (by 4 users)
posted by praise37 on May 09, 2008
I have the emerson compact disco alarm clock radio. I have lost the direction on how to set the clock. Please tell me or show direction how can set the clock.
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
3 Other Users Have The Same Problem
Comment by Guest, posted on Sep 11, 2008
I can't set the time or alarms or anything because I cannot read the white button labels on the device. I've tried pressing all the buttons trying to find the magic one but have yet to be successful. Where can I find a diagram to show me what button is what?
Comment by Guest, posted on Aug 29, 2008
I've forgotten how to set the time--I haven't used it for quite a while.
Comment by jnj2000, posted on Jun 22, 2008
I cannot set the clock for this radio, I also tried clicking on the link but it will not open.
Solution #1
posted on May 14, 2008
Not Rated (0)
Colossus023
Rank:Master Master
Rating: 88%, 24 votes
Most of the time when setting clock radios you have to press a combo of buttons in order to go through the settings. Many times you just need to press and hold the clock time button for a few seconds(normally between 3-6 seconds) and then the clock display will flash. When this happens you should be able to go through the hour and second numbers to set the time. After that you would probably need to hold the clock button again to stop the flashing to keep the setting you just did.
If this method does no work try a combo method by pressing the clock button and another button together for a few seconds to see if that works.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on how to set time:
I don't want to Accept this solution
Can you Help with these Clock Radios problems?
Spectra KT2057 Clock Radio
the cd player worked fine I shipped it clock radio and now...
Bose Wave Radio
Where can I find a copy of the owner's manual for a Bose...
Emerson Smartset Clock Radio
I have 2 clocks. One is 5 minutes off and the other is 10...
Bose Wave Radio
the eye thing in the cd player goes to the right, gets...
Timex (T307S) Clock Radio
i dont know how to set the clock or alarms.
Loading problems.
Repair Service
Find Clock Radio Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Home Media Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
