Question about Samsung Refrigerators
I had purchased samsung refrigerator of model SR-32 EMB, 310 liters almost 9years back. All along it has given trouble free service Recently the compressor failed and a new one is replaced by your authorised service center at Hyderabad. The problem is the water is not getting drained automatically as earlier. The technician arranged an outlet tube at the backside and the water gets collected in the container provided by us .Everyday the water is to be collected and thrown outside. sometimes the water also leaks under the refrigerator. The mechanic says in earlier models the water used to get collected in the disc fixed on the compressor but the new model there is no provision.Now it is like a frost model although it is a defrost model.How long we have to put up with this nuisance? Is there no remedy?Cant the company do something in this matter? we are based at Hyderabad. Pl advise immediately. My email address is nslnarasimhaswamy@yahoo.co.in
aborcass
  • 2651 Answers
SOURCE: Loud banging noise and water leaking
not much can be done about compressore noise, short of replacing it. but your drain issue is easily fixed, with that whirlpool heat strap you mentioned.it actually wraps around the heater in frezer section and the idea is that when the unit goes into a defrost cycle(3 or 4 times a day) the heater heats the strap(which runs into drain tube) up as well, preventing tube from freeezing up and eventually backing up into your freezer floor
Posted on Feb 24, 2008
aborcass
  • 2651 Answers
SOURCE: defroster leaks
you have a clogged defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wirearound the heater( black calrod heater right above the drain trough) and stick it in the whole maybe an inch or so. now everythime the heater comes on to defrost it will prevent the hole from freezing over
Posted on Feb 25, 2008
aborcass
  • 2651 Answers
SOURCE: Refrigerator/ water collecting under veggie bins
sounds like you do have a clogged drain tube, its self defrosting but the defrost water is pooling under hte crispers instead of in the drain pan under unit.so you ll either have to remove hte rear panel of freezer and locate the drain trough/ tube, and defrost it allowing for water to drain down, o rclear all the tube leading down to the drain pan.
Posted on Mar 21, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: Water leak from my Kenmore refrigerator
Your problem is most likely a clogged drain line. Which is located in the back bottom of the freezer a little hole. Run some hot water down it with a spray bottom and it should resolve your issue. Also yes a Tech will be able to fix this problem
Posted on Jun 01, 2009
woodchuck789
  • 4070 Answers
SOURCE: How do I unclog defrost drain on a model TBX18W?
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Posted on Sep 26, 2009
I have a Samsung side by side refrigerator Model No: RS21DCSV. The water and ice dispenser are working. However, the water is no longer chilled?
Water is stored in a tube bundle located behind the crisper drawers (bottom, back of the refrigerator) and is chilled to the temp of the refrigerator (perhaps 40 degrees F). This tubing holds approx. 16-32 ounces (less than a liter) and incoming water pushes the chilled water to the dispenser, but also begins to warm the output water temps.
The only way to get colder water is the set the refrigerator to a lower temperature. But be careful that the temps are not so low as to cause other food items to freeze.
Sep 30, 2016 | Samsung Refrigerators
Over time, the vegetable bin and shelves on the door of my samsung refrigerator model ra-18fhss have given out. the refrigerator itsef is still okay so I would just like to find out where i can purchase...
Go out to and go to appliances center and ask a promodizer that carry your refrigerator brand ( Samsung Promodizer ) they will give you a list of the authorized service center that sell a parts of the unit. Obtain a copy from them then call the service center ask if they do sell the one that you look for.
I do hope I help you with your problem.
Jun 11, 2011 | Refrigerators
Unlock samsung t 629
Hello. In order to unlock this samsung product, take it into your phone store along with a photo ID. They will unlock it for you and set it to whatever lock code you choose. Joe
Thanks for choosing Fixya!
Jan 13, 2011 | Samsung CoolTech Plus / Basic Bottom Mount...
My viking refrigerator freezer won t freeze
A lot of problems have been reported with this model,with the defrost timer not moving,Like a clock stopping,the defrost timer has stopped,and won`t allow the compressor to freeze the freezer unit.Most likely not to cool in the refrigerator either is it?If I can help anymore,let me know,but have the defrost timer checked or replaced.
Jun 12, 2009 | Viking 42 in Built In Professional...
I want to purchase refrigerator which is best
single alot more organized a spacious, whirlpool has been ok here so far
Mar 07, 2009 | Sanyo SR-3620 Compact Refrigerator
Chilled water stopped .chiller frozen in bottom of fridge
SR-32 EMB MODEL, FREEZER OK, BOTTOM NOT COOLING PROPERLY. ADVICE SETTINGS
May 28, 2008 | Refrigerators
SAMSUNG Nearest service center in hyderabad
Samsung service centre is located in ameerpet, Hyderabad, in Ground floor of Elephant house. Contact No's: 040-66820252, 040-30308282, 9912237601
Feb 19, 2008 | Samsung YP-K3 MP3 Player
Refrigerators Logo
327 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
