Question about Carrier 38BRC048 Air Conditioner
Help!! No cooling, just fan!!!
I HAVE A LESS THAN 2 YEARS OLD AIR CONDITIONING (MODEL#FA4BNF036) THAT HAS STOPPED COOLING. I SEE NO LEAK AND HAS BRAND NEW FILTER. IT'S A SINGLE UNIT FOR CONDOMINIUMS. i THINK THAT THERE SHOULD BE A WARRANTY STILL, BUT TO GET TO SERVICE IS BEING A PAIN. CAN ANYONE PLS GIVE ME AN IDEA HOW TO GET IT WORKING AGAIN?
tHANK YOU
Comment by CAAAPEREIRA, posted on May 08, 2008 Yes, I can hear the fans running, but I will have to open the panels to verify everything else. The thermostat shows cools and I have programmed it for the temperature to hit 70F. But the temperature does not go below 79F. Does these kind air conditioning have internal fuse? My apartment lights blinked yesterday and I notice that after that the air conditioning stopped working properly. I pressed the "Reset" button on the digital Thermostat which displays "cooling" but it acutally does not! I HAVE A LESS THAN 2 YEARS OLD AIR CONDITIONING (MODEL#FA4BNF036) THAT HAS STOPPED COOLING. I SEE NO LEAK AND HAS BRAND NEW FILTER. IT'S A SINGLE UNIT FOR CONDOMINIUMS. i THINK THAT THERE SHOULD BE A WARRANTY STILL, BUT TO GET TO SERVICE IS BEING A PAIN. CAN ANYONE PLS GIVE ME AN IDEA HOW TO GET IT WORKING AGAIN?
tHANK YOU
  • 1 more comment
  • theider Jun 13, 2008
    I am having the same issue. My AC Unit is Model # BRCQ0361BD
    Here's what keeps happening: okay even when unit runs ALL day (set at 70*) it never ever cools down past 80 (even if we lower setting to 65*).
    The air from the vents comes out at about 60* but some vents work, some don't. ( I live in a mobile home).
    Also, to kick the air back on once it hits 80* I have to turn the thermostat to at least 60* befire it kicks back on.
    I have tried cleaning the outside unti as well as the A-Coil inside. Is my thermostat broken? low on Freon (NOT freezing up), etc.
  • cgarcia737 May 19, 2009
    My air conditioner runs but it does not cool. I, too, set it for low but it isn't getting below 81º
  • sbev119 May 11, 2010
    the thermostat controls just shut OFF. It stopped.
    Scholar:
  • 149 Answers
You probably have a defective contactor or start capacitor on condensing unit. if you pretty handy with wiring go to the condensing section open the panel. you should see a contactor (it's the little black piece with all the wires) check the condition of it. next to it is a capacitor and by the problem that you describe it could be that. check it if it looks bloated there's your problem just go an get an combination capacitor and wire up. (make sure the power to unit is off first. any other questions email me @ hvac.tech7872pr@gmail.com
Posted on May 09, 2008
  • Alexander  Figueroa
    Alexander Figueroa Jun 11, 2008
    they ask for a solution i give a solution, i advised if your handy and i always tell to shut power off first
    and i always told to open and look not touch if they see it they have an idea of what is wrong and not to get ripped off and then call for help sorry if it ticks you off
    Novelist:
    Champion:
  • 230 Answers
It sounds to me that it is one of two issues.
1) the compressor is not on. (You may see the fan running though it is not the compressor)
2) there is a refrigerant problem
Either one of these issues have multiple reasons for failures. We really need more information to give you the help you need.
Posted on Jun 15, 2008
  • 95 Answers
Refritech08, what in the h*ll are you doing telling someone to open up the condensor and play with contactors and capacitors. Just like to imagine the expression on their face when they grab a couple of wires or the bang when they play with the cap. What you are saying is very dangerous and very unproffesional to post in a public forum. Sure it's no problem for a tech to check these components but for the average joe who doesn't know a run cap from an apple it is really dumb to encourage them to play inside the unit.
Posted on Jun 10, 2008
2 Suggested Answers
  • 182 Answers
SOURCE: Help!! No cooling, just fan!!!
sounds like the unit is low on charge.you will need a pro to check it
Posted on Aug 05, 2008
My cooling fan on my 2002 Lincoln ls 3.9 is hydraulic and I believe it's going out.. Is it a good idea to replace it with an electric cooling fan plyz help
I can only say that if this system uses the old style oil filled fan clutch that has been used for over 50 years, the method of testing is to measure fan shaft rpm against engine rpm. When the air temp is cold, the fan clutch is suppose to slip to prevent over cooling the engine. If the fluid runs out from a leak, the blade clutch can no longer lock and you lose air flow.
The electric fan is an option, but many cars have both systems because there is just too much heat to get rid of. Room is always a problem. Some electric fans have 2 speeds, largely dependent on getting sensors to work at 2 different temperatures.
Aug 25, 2015 | Lincoln Cars & Trucks
Air Conditioning broken - fan still works
Probably a control board failure. If the modes don't work and the fan auto/on works, I'd say the circuit board has failed. Does the fan turn on when cool is selected? If not, 99% sure it's the board. If it does, it's probably a compressor component issue. Window units are considered throw aways.
Aug 31, 2017 | GE Heating & Cooling
I have a blizard split model 10.5 years old in a caravan. model sa101 the air feels cooler but seems to have no noticable difference in actual temperture and compressor seems to run continuously ...
Please understand first, air conditioning system not only cooling the area but also removing the heat. If heat in the room stays constantly, even 24 hrs running a/c couldn't cool the room.
Now, why the a/c could not cool the room or remove the heat from the room.
Check air filter, evaporator coil and blower wheel for clean. If not service the unit immediately. And also check indoor fan motor rpm. If rpm is low, replace fan capacitor. Check for gas pressure to confirm no leak or running with short of gas. It's advisable to service both indoor and out door once in 6 months at least. Otherwise, your electric bill will kill you lot. Thanks.
Jan 31, 2011 | Electrolux Heating & Cooling
Fan works, air conditioning does not. Try resetting the power (in the proper sequence - outdoor unit followed by indoor unit). Air conditioning came on briefly (less than a minute) than stopped, leaving...
Without seeing the unit,
1 - the condenser fan (which is in the outdoor unit) could be blown. This would cause the unit to go off on high head pressure.
2 - it could be low on refrigerant, which makes it do nothing but blow room temperature air around. The unit would go off on low pressure
3 - the filter is dirty, blocking the cooling
4 - the compressor could be shorted, or a corroded wire somewhere that feeds the contactor
Mr. Slim Ductless Splits are the best on the market and should only be repaired by a trained technician.
Hope this helps.
May 28, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Suddenly stopped cooling
ck for ice in back of freezer / it sounds like the defrost heater has failed of a evap fan. ice may be blocking coil or the fann is not moving the air .. ****
Jan 18, 2010 | Refrigerators
GE Eterna stopped cooling. Not even 2 years old!
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Check the fans especially the condenser fan. The noise if you listen close is probably the klixon cycling because the compressor is hot. If the condenser is plugged (real dirty), sign of a clean house, and/or the condenser fan is bad you will not get cooling. If the condenser fans operating properly and the fans inside the freezer and refrigerator are operating that would indicate serious problems assuming the compressor is operating.
Good Luck,
Gilshultz
Dec 01, 2009 | GE Refrigerators
After switching from heating to cooling - air won't come on
It sounds like the fan relay in the stat itself is not closing when you make the switch over. If you have had the stat for less then 5 years it is covered. Honeywell has a full 5 year warranty on their focus pro stats, and would replace it free of charge.
Apr 02, 2009 | Honeywell Focus 6300B 5-2 Days...
Aug 04, 2008 | Heating & Cooling
NO COOLING
Hmm.this will require a few questions for you to answer. first does all the fans run, condenser fan??? indoor blower? and does the compressor humms, when you turn it on?
May 08, 2008 | Carrier 38BRC048 Air Conditioner
Carrier 38BRC048 Air Conditioner Logo
579 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
