Question about LG LSC26905TT Side by Side Refrigerator
The fridge side is freeging - LG LSC26905TT Side by Side Refrigerator
  • LG Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 01, 2010
ONLY DISPLAYS TCL LOGO TV FREEGES
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Feb 04, 2016 | Televison & Video
How does a side by side domestic fridge work
Freezer one side, refrigerator the other side. Compressor is in the bottom at the rear. Often ice and water dispensers in the door.
Jan 23, 2016 | Refrigerators
Ice builds in fridge everything goes freege with ice
sounds like your thermostat is not working or the temp control is set too cold. Check temperature setting and it should be about mid range. If it is the thermostat a technition will have to replace it
May 12, 2014 | Refrigerators
Samsung fridge coils frozen over on refrigerator side.
Not sure what the ohms should be,but ckeck coils for damage you may have a leak
Dec 07, 2013 | Refrigerators
WE HAVE 12 YEARS OLD MODEL TPX24 BP, WHEN WATER LINE IS OPEN AND WATER DISPENSER IN USE, THERE IS LEAKING OCURES FROM UNDER THE FREEGE PLEASE HELP
You have a bad "water inlet solenoid" that needs to be replaced. It is located on the rear, bottom left side of the unit. It is really simple to replace. Here is a link to the part you need. Below is a video to show you how to replace it.
Aug 11, 2011 | Refrigerators
Kenmore side by side fridge. Green temp light flashing for fridge side, freezer side working fine. Fridge side not cooling.
possibly frosted up at the air door between the fridge and freezer, or the fan in the freezer is not pushing cold air into the fridge side, if you can not hear a fan running in the freezer when the fridge is running (compressor on) then change out the fan
Jul 18, 2011 | Kenmore Side by Side Refrigerator
Hello, refrig is getting warm 57 deg, the freezer side is ok what now
chaeck the temp of that room where you freege keep.
it can be chaces of high condensation
you put much more hot or warm products accros the limit
if in your freeze has a water heater and it continuous on with out signal of the solenoied valve
comp over heat
lake of refrigerant
Feb 23, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
I'VE GOT WATER UNDER MAYTAG FREEGE,I KNOW there have to be some place where i can pour water to unblock it.
You need to access your drain pan. To do this you need to remove your freezer panel and your drain pan will be located under your evaporator coils. You can use a turkey baster with hot water to clear it with hot water. Once its clear you will want to dump an additional cup of water down it to make sure its clear. This will take care of your frozen drain line.
Good luck _MJ_
Feb 14, 2010 | Maytag MSD2756G Side by Side Refrigerator
LG LSC26905TT Side by Side Refrigerator Logo
71 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
