Question about Garden
Unit is a wood splitter (American Wood Splitters) with a Briggs & Stratton, Model 130202, Type 0985-01, Code 80073107. I need a diagram and parts list for the throttle and governor linkage.
  • 5 more comments
  • rhcjac66 Sep 01, 2010
    I found http://bsintek.basco.com/BriggsDocumentD... but unable to isolate the throttle and governor linkage as pertains to the "American Wood Splitter" from the material.
    Ron
  • rhcjac66 Sep 08, 2010
    Excellent.
    Thanks
    Ron
  • rhcjac66 Sep 09, 2010
    The issue is #629, "sprint throttle return". Is there something that shows how/where the spring is installed (attached)?
    Thanks
    rhcjac
    The issue is #629, "sprint throttle return". Is there something that shows how/where the spring is installed (attached)? Thanks
    Is there a diagram/picture that shows 629 installed?
    Thanks
  • rhcjac66 Sep 10, 2010
    "hello, you could try b&s.com "... I went there before I tried "FixYa". I will call B&S customer support.
    Thanks for trying.
    Thanks for your efforts, very much appreciated.
  • 19,396 Answers
Hi.
Click on link below.
Enter engine number in searc box, and open document.
If you get nothing, enter 130202 and select from list of engines.
Open support page.
Click on the Part List page.
Open Diagram and chose parts.
Click here.
Here an example on one of the 130202 engines.
Engine 130202-0127-99
If you still have troubles in locating diagrams, call Customer Support at1-800-444-7774, available Monday-Friday 8:00AM-5:00PM CST, or try the Online Support: Submit a Question
Posted on Aug 31, 2010
I have a Briggs & Stratton tiller motor 5hp that does not have points.there are two wires terminated to the coil.1 with a ring terminal and 1 with a stripped end.Where do they go?
the wire with the ring terminal will go under a mounting bolt ( ground) the other will connect to the plate at the end of the throttle cable under the insulated bit
when you push the throttle to stop , that plate will short out the wire with the stripped end and top the engine
Jan 07, 2017 | Briggs & Stratton Garden
Wiring diagram for a 250cc 11.50 briggs and stratton engine on a troy built wood chipper
http://www.briggsandstratton.com/us/en/support/faqs/horizontal-shaft-replacement-engine-specifications
Jul 11, 2014 | Parks Optical 13.5hp Briggs And Stratton...
Part no .492611 carburetor assembly (inc.key
http://www.partstree.com/parts/?lc=briggs_and_stratton&mn=130202-3129-01&dn=8994004A
Unless you broke it or lost something, rebuilding it is more better on the pocket book. Rebuilding mainly consist of long carb cleaner soak, clean air
flow tubes with piano wire and air pressure. This most times can be done without any new parts. Fix IT!
Dec 22, 2011 | Craftsman Garden
What year is my wood chipper? I purchased a Craftsman 8hp wood chipper-shredder that is silver-gray in color and all metal in construction with a Briggs & Stratton 8hp motor. The B&S motor is...
The B & S Code is the date of Mfg. This engine was built in 1994 (first two digits rep. the year), Sept.( the next two digits rep. the month) and the second day of that month. Your engine was built on Sept.2,1994. Your chipper may be one year newer as the engine had to be installed after the date of mfg. Your welcome
From North Carolina
May 17, 2011 | Heavy Machinery
I need a replacement foam air filter element for the Briggs and Stratton engine on a Didier log splitter Model 130202
you need briggs part number 27987
and assume this is a horizontal shaft engine
your local small engine shop should have one
cheers pauly46
Jan 17, 2011 | Garden
I have a Briggs and Stratton Swisher 7.0 Wood Splitter. It worked fine for about a year and a half. Now when we go to use it, and after about 1/2 an hour, the oil bubbles up and spills out, and shuts down....
That would indicate the oil is getting too hot. This can happen if the oil level is too low and the pump mixes air into the oil.
Use of wrong oil could also cause the problem.
Sep 01, 2009 | Briggs Garden
Garden Logo
138 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
