Question about Fusion MS CD600G TrueMarine Stereo by
I recently installed a new marine stereo Fusion MS-CD60, it all worked fine for a couple of hours, then when playing a CD the sound started cutting out, not long after that the sound stopped altogether and the screen displayed "ERROR 2", the radio & aux still work fine
    President:
  • 4,070 Answers
Hi! Usually the error 2 from the fusion means that the cd has scratches or the cd is unreadable. By then it will stop and will display the error. One thing that can cause this is if the optical lens is dirty so I strongly suggest that you run a cd lens cleaner then insert a disc that is free from scratches. This will resolve the problem. Hope this helps and thank you for using FixYa!
Posted on Aug 31, 2010
Everything works on my stereo system,but there is no sound
Car Stereo Head Unit Install ** No Sound ** Amp Not ...
? 10:41
https://www.youtube.com/watch?v=wQ9bSdJGMjg
Mar 23, 2014 - Uploaded by PSYCHOTICNORMAN
Video for those who installed their head unit correctly, but got no sound / factory amplifiers not turning on. ... Car Stereo Head Unit Install ** No Sound ** Amp Not Turning On ** work around. ....Did everything to the letter on a 2001 Chrysler Town and Country and while I do have audio, my audio is cutting in ...
Everything works on my stereo system,but there is no sound ...
www.fixya.com/.../t26059653-everything_works_stereo_system_but_no
1 hour ago - everything works on my stereo system,but there is no sound lxi 4cd canger - Chrysler 2001 Concorde question.
Chrysler Concorde radio works but no sound Questions ...
www.fixya.com > ... > Cars & Trucks > Chrysler
Chrysler Concorde cars & trucks radio works but no sound questions and answers. ... Fixya - Solutions for Everything ... My 2002 concord lxi when ... CAR STEREO HAS POWER BUT WILL NOT OPPERRATE ... Question about 2001 Concorde ... ...sound from radio thru speakers Is there any popping when playing a CD or ...
Jan 19, 2016 | 2001 Chrysler Concorde
I need instructions on how to install an after market stereo in a 2006 Ford Fusion SEL.
Buy a metra dash kit and it will have step by step instructions,you will need harness too ,donot cut factory wires.!!!!!!!
Jun 03, 2010 | 2006 Ford Fusion
I bought a boat with a clarion cd/stereo head unit. I noticed a problem while trying to play the radio that the speakers continually cut out. I get music for 2-3 seconds, then a popping sound, followed by...
try taking antenna lead out of set and put a length of wire into the center hole were the antenna fits then scan,you should pick up at least one station,if you do fit a new antenna,if not try switching off any traffic anouncement services on the set ie press and hold button marked either ta/rds/tta/ast
Topspark
Aug 21, 2009 | iLO XM-MP3-CD Car Stereo
The radio/cd player on my 01 yukon loses the sound randomly. Some times it works fine then othertimes it does it a lot. This all started a month ago. Before then I'd had no problems. I talked to a guy at a...
sounds like the amp is over heating and needs to be replaced
and yes there is most likely an amp in the system and it is eithor over powered or over heating
Jul 29, 2009 | Car Audio & Video
I just installed a Pyle Marine CD player in my street rod. It works perfectly until I start the engine, then the sound cuts out. I switched it out with another car and it works fine in the other car.
You should be looking for a large capacitor to insert in the stereo's power leads. One farad, more or less. The CD shuts off when the battery voltage drops below a certain voltage. This prevents the voltage dropping below the threshold while cranking. Available at Wal Mart, Canadian Tire, Radio Shack type stores.
How to link:
http://wiki.answers.com/Q/How_do_you_hook_up_a_1_farad_capacitor_to_your_amp
Picture of one:
http://www.amazon.com/Pyramid-CAP160DBL-1-6-Farad-High-Performance-Capacitor/dp/B000MCKAYW?tag=dogpile-20
Jul 15, 2009 | Car Audio & Video
Citroen Saxo CD Player will not play when engine running
The car stereo has 2 +12V inputs: the constant batt input and the key in one.
So actually the stereo is always connected to +12V, even in standby.
When you turn your key, the key in input also starts, thus starting your stereo instantly.
When you turn the ignition on, the key in input is switched off for a couple of seconds, so that all the power goes to starting your engine.
After that key in input should be back on - this is your problem here.
One possible solution would be to cut this wire out, and split the RED battery +12V cable so that it enters in the key in input as well. Check wiring diagrams!.
Test this with cables out (without reinstalling the whole thing back in) and if it works.......leave it and put everything back in.
Only downside is, you have to turn off the radio by hand when you exit your car - or you could lose all battery power !
Jan 16, 2009 | Car Audio & Video
No output from speakers in car.
Sounds like a couple speakerwires could be crossed/shortcurciting somewhere...;)
Oct 01, 2008 | JVC AM FM CD DET FACE CAR STEREO
Is this considered clipping in marine boat stereo help!!!!
if your radio is puiing more power your ground might not be good enough, use the same spot but remove the ground and rough it up a little on the base with some sand paper or add a metal o ring to get a better ground.
Jul 30, 2007 | iLO XM-MP3-CD Car Stereo
XDM6825 Not Playing MP3s in Stereo
if you have a FM MODULATOR installed too,some ones no transmiting in stereo mode, try changeit
Feb 14, 2007 | Dual XDM6825 CD/MP3/WMA Player
Fusion MS CD600G TrueMarine Stereo by Logo
197 people viewed this question
Top Fusion Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Fusion Boating Expert? Answer questions, earn points and help others
